Vizio On/Off Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-08-2009, 11:16 AM - Thread Starter
MLKstudios's Avatar
Hi All,
I got my gf a 37" Vizio plasma from Best Buy. It has worked fine for a few months but now, it clicks on and off a few times (increasing to a dozen) when turned on. Eventually it stays on -- but it goes on, off, pause, on, off, pause, on, off, pause, etc. anytime it is turned on.
I have tried un-plugging it for a while and replacing the batteries in the remote (two different remotes do the same, so I don't think it's a signal problem).
Any ideas what the cause might be? It's now about 6 mos. old. When turned off, there is no issue. It happens only when turned on.
Thank you.
MLKstudios is offline
post #2 of 21 Old 05-08-2009, 11:21 AM - Thread Starter
MLKstudios's Avatar
Added note. If it has a been on a while (warmed up), and turned off, then on. It does fewer On/Off's, before it stays On. Maybe two or three.
post #3 of 21 Old 05-09-2009, 07:22 PM - Thread Starter
MLKstudios's Avatar
I know it's not a high end plasma. We got it for a steal.
But, I hope someone has had a similar experience and can chime in.
Thank you.
post #4 of 21 Old 05-10-2009, 06:34 AM
dustwvl's Avatar
I know you said it does not seem to be the remote, but does it do the same thing if powered on from the power button on the TV?
dustwvl is offline
post #5 of 21 Old 05-10-2009, 06:47 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by MLKstudios View Post
I got my gf a 37" Vizio plasma from Best Buy.....
I think that Vizio is an LCD TV, not a Plasma TV. Vizio doesn't make a 37" Plasma. What's the model number of the TV?
Is it possible that the power button on the remote is sticking or something? Turn the TV on then immediately place the remote in a drawer and see if the TV still turns on and off.
But it sounds like the TV needs to be repaired, hopefully they have parts available.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 21 Old 05-10-2009, 08:17 AM - Thread Starter
MLKstudios's Avatar
Thank you both for replying. It is a plasma (unlike my 3 year old Pannys, it already has some burn in). Model #VP322. Maybe 32", but looks 37"?
It does the same with the power button. It's only 6 mos. old, so it might still be under warranty. But, I was hoping someone had been through this (and knew what causes it), so I could avoid hauling it in. It's not that big, but quite heavy.
BTW I made sure it was plasma when we bought it, because of the PQ of the Panny plasmas I own. I got the colors right and it shines with an HD signal, but burn in is bad.
post #7 of 21 Old 05-11-2009, 02:48 PM - Thread Starter
MLKstudios's Avatar
It's been getting worse, so I'll have to take it in. But, hoping in one last post, someone might know what the cause is?
Last time I turned it on, it took 40 or so clicks before it stayed ON.
post #8 of 21 Old 05-11-2009, 05:08 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
That's the model number for their little 32" Plasma. It's definitely not a 37 incher
IIRC this TV has a one year parts and labor warranty. It might even be "in-home" service. Check your owners manual - the info should be there.
Shhhh - the owners of this TV get pissed when someone says it got burn-in, or that it's junky
Randy
post #9 of 21 Old 05-11-2009, 05:55 PM - Thread Starter
MLKstudios's Avatar
Thank you Randy, Yes it is a 32".
I will definitely check the owner's manual for warranty info. If CNN would go HD, burn in wouldn't be a problem. Why are they still broadcasting in SD?
My Pannys give me a few minutes of "retention" that becomes unnoticeable rather quickly. This Vizio does have those deep, rich plasma colors, but no grey bar or stretch-to-fit mode, and the CNN logo is visible on every channel.
I'm at her place now and she has a second SD TV we could watch while this is being repaired. But, I'm spoiled by the Pannys. Basically, I got it for her so I could watch a decent picture when I visit.
Hopefully, they'll come out to fix it.
Thanks again,
Matthew
post #10 of 21 Old 05-11-2009, 06:03 PM
Zues's Avatar
You probably have the sleep timer activated. Check your menu.
Zues is offline
post #11 of 21 Old 05-11-2009, 06:22 PM - Thread Starter
MLKstudios's Avatar
I checked the Sleep Timer setting, and it was Off. But, I did discover an Image Cleaner just below. That might help get rid of the logo.
I also Rest All Settings, but that didn't help. Any other ideas will be appreciated.
And thank you Zues, for replying.
Matthew
post #12 of 21 Old 05-11-2009, 06:35 PM
Farland's Avatar
I get CNN in HD on comcast. They still have those annoying logos everywhere though.
Farland is offline
post #13 of 21 Old 05-11-2009, 07:18 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
How do you come up with sleep timer? The symptoms he describes (goes on, off, pause, on, off, pause, on, off, pause, etc, then ultimately stays on) don't sound like any sleep timer i know of
Randy
post #14 of 21 Old 05-11-2009, 09:52 PM - Thread Starter
MLKstudios's Avatar
Thank you again Randy. Even a miss-diagnosis is welcome, as it eliminates possibilities.
I'll have my gf find the warranty, and call BB tomorrow.
post #15 of 21 Old 05-12-2009, 06:51 AM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
You got this TV at BB? I thought your model was only sold at Walmart and maybe Sam's Club, but not BB. BB sold the Insignia version of this TV.
Fiddle with the power switch on the TV itself and make sure it's not sticking.
Randy
post #16 of 21 Old 05-12-2009, 09:38 AM - Thread Starter
MLKstudios's Avatar
You're right again, it was Walmart. I had her check.
Will try the power button. Thank you.
post #17 of 21 Old 05-12-2009, 10:25 AM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Ah, i thought so.
Another thing you can try is covering or blocking the IR eye on the front of the TV - it's possible that it's seeing or sensing something that is confusing the TV, or the screen itself is interfering with the IR eye, either directly or by illuminating something in front of the TV that is reflecting back into the IR eye on the front of the TV.
Randy
post #18 of 21 Old 05-13-2009, 04:01 PM - Thread Starter
MLKstudios's Avatar
I've faxed the receipt to Vizio and should hear back in 24 hours. Today it wouldn't turn on at all, then later turned itself on -- after 40 or 50 clicks.
Thanks Randy, for your replies.
post #19 of 21 Old 05-28-2009, 07:29 PM
Rodney's Avatar
I had this same problem with my Vizio 42". It was very intermittent, sometimes not happening for weeks or months at a time. It would go off while I was watching it, and sometimes I would have to wait awhile before it would come back on. Two weeks ago it went off for good. It is out of warranty (I bought it in '06), so I took it to a shop, and the main board needs to be replaced. They quoted me $475. OUCH. Was yours ever fixed, and was it the main board? I am going to get it fixed, but I hope this doesn't repeat itself.
-Rodney
Rodney is offline
post #20 of 21 Old 06-19-2013, 06:15 PM
Kirk Hinkley's Avatar
We bought a 37 inch Vizio from Walmart in Nov. 2011. It went to our cabinand we used it to watch football bowl games over Christmas and New Years. Other than that, we used it perhaps 4 more days over the course of the year. I'm guessing we had 12 to 20 hours total on this new tv. In May, being 6 months out of warranty, we went up to the cabin where we use a Dish Network tailgator sattelite unit for reception and turned the tv on. It worked fine. When it was turned off (we were watching the NHL playoffs) it would not turn back on when tried later. Then after messing with it for quite a while, it turned on. Then wouldn't again the next day. Only a large white VIZIO appeared on the screen. Now it won't even come up with that but rather just the yellow vizio come on with the power. We've tried everything and have decided that it is junk. It wasn't a really expensive tv. We wanted it for the cabin but also wanted to buy American. Our old tv was over 20 years old and we gave it away to Goodwill. It worked fine. Are we done with Vizio? Yes. A new television, with all of this updated technology, flat screen, HD etc. should at least turn on and off when desired. The people at Vizio couldn't even guarantee that a report would be filed with their engineers or quality control people. They just kept saying that we should have purchased the 5 year warranty. I had no warranty with my old tv, and it lasted over 20 years. Enough said.
Kirk Hinkley is offline
post #21 of 21 Old 06-20-2013, 04:48 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Common fault with these 32" Vizio plasmas using an LG plasma panel are bad capacitors on the LG PSU.
tom669 is offline
