The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #391 of 7095 Old 07-23-2009, 09:23 PM
mjrgamer's Avatar
Originally Posted by Kimwyn View Post
i jus wish calibrators would go on vacation here in Barbados
They will never go to Barbados unless you pay for for round trip tickets and some drinks. j/k
The last line of defense for plasma fanatics. The only reason for defeat was companies actually have to make money from the products they sell. Damn.
mjrgamer is offline
post #392 of 7095 Old 07-23-2009, 09:40 PM
stumacdo's Avatar
Hi all,
Got my 500m successfully mounted today - looks beautiful. One problem. This is my first wall-mounted set where I've run cables behind the wall. Purchased really heavy-duty, thick Monoprice cables with not much give. Found tonight that one of the HDMI inputs on the 500m tends to lose the signal once in a while. If I "wiggle" the cable, I can usually get the signal back. In folks experience, is that typically just a bad cable or are these HDMI inputs just a little sensitive. Any advice would be great. I was psyched to get it up and running, but then to see these signal losses was pretty frustrating... Thanks !
stumacdo is offline
post #393 of 7095 Old 07-23-2009, 10:34 PM
dnavas's Avatar
I can do "any advice" I've never had a problem with a loose HDMI input, and I bought a bag of three HDMI cables that were returned (got'em cheap). If you don't need sound, you might consider an HDMI->DVI and screw the DVI connector in.
-Dave
dnavas is offline
post #394 of 7095 Old 07-23-2009, 11:08 PM
5150Joker's Avatar
Unlocked the ISFccc modes for my 500M with ControlCal today. Went smooth and was fairly simple, highly recommended!
5150Joker is offline
post #395 of 7095 Old 07-24-2009, 06:31 AM
Management's Avatar
Is the S&M Blu-Ray disc sold in retail stores or must I get it online?
Management is offline
post #396 of 7095 Old 07-24-2009, 07:30 AM
stumacdo's Avatar
-Dave
I think it might actually be the first defective cable I've ever purchased from Monoprice (and I've bought quite a few). This cable was directly plugged into the 500 from my Sat. When I pulled the cable out of the Sat and plugged directly into my PS3, the same problem occurred (intermittent signal loss). I've really diagnosed it down to 2 things - defective cable OR possible bad HDMI port. However, I'm thinking if it was a bad HDMI port that it would either work or not work (and not be sporadic/intermittent). Going to try replace the cable later today with another Monoprice cable and hope for the best. Has anyone seen cases where 1 HDMI port on the set is ok while the other is defective ?
stumacdo is offline
post #397 of 7095 Old 07-24-2009, 08:29 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
I've never seen any adjustment/assessment disc in a store. In any case as far as I know it's only on-line and only from a few outlets. You could ask on the thread.
bodosom is offline
post #398 of 7095 Old 07-24-2009, 09:21 AM
FTracy3's Avatar
600m arriving today. Have read the delivery thread but can someone explain a little more clearly how to test this without breaking it before it's mounted? Do you need to lean it up against a wall (am nervous about it sliding down, or would that be pretty secure). Flat on the ground? (don't want the cat skateboarding across it). Since I live alone I'm pretty much on my own after the delivery guy leaves. Thanks for any advice
FTracy3 is offline
post #399 of 7095 Old 07-24-2009, 09:35 AM
Management's Avatar
Thanks for the link!
post #400 of 7095 Old 07-24-2009, 09:45 AM
dnavas's Avatar
Another request for "any advice" Woot!
Well, if the 600M is delivered like my 500M was, the box is in two sections with those hard plastic strips around them. The "top" of the box descends all the way down to the ground, and is a removable shell around the bottom half. Remove strips. Open the top of the box, remove an inside liner and then slide the entire top shell off the TV. The TV will be standing in a foam-pad pan inside the bottom box. With a little maneuvering, you should be able to attach everything while it sits in the bottom box. You may need to break off a few bits of foam to get at all the connectors (I needed to when I attached the mounts).
BTW, I did not know this when mine arrived and carefully cut the top off only to then discover it wasn't actually attached to the bottom. I felt pretty stupid. The box does come with directions for removal on the side. There was a giant sticker over the English side, which might provide some excuse, but really, the pictorals would have been sufficient from the French side had I actually looked at the side of the box and not been quite so eager.
Mounting the TV on the wall without someone else is impossible unless you have gorilla arms. TV isn't heavy, but the lifting points are very wide apart.
Prior to mounting, I had the TV stored next to the wall, monitor side toward the wall. Mostly to reduce the chance of random box bits hitting the plasma on the delicate side....
Hope that helps,
-Dave
dnavas is offline
post #401 of 7095 Old 07-24-2009, 09:49 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
Congratulations on getting a wonderful monitor. I hope it all goes well.
Normally visual inspection per the delivery thread should be sufficient. If the driver will wait you should be able to get it plugged in and press the power button with the monitor in the shipping box. If it comes on and displays a no input signal message you're good to go.
Everyone is unique but I consider installing the 500M a two person job. The 600M is notably bigger and heavier so even more caution is required. Please note that the bezel is not designed to take any load.
bodosom is offline
post #402 of 7095 Old 07-24-2009, 10:02 AM
dtowntke's Avatar
i would like to unlock isf modes on my 500m can some one give me a link to where i can get the control cal
dtowntke is offline
post #403 of 7095 Old 07-24-2009, 10:03 AM
dtowntke's Avatar
how better can the picture get with the isf modes unlocked then pure mode and the pro settings
dtowntke is offline
post #404 of 7095 Old 07-24-2009, 10:03 AM
amheck's Avatar
Quoted: 18 Post(s)
I was able to test my 600m myself. While the delivery guy was taking his handtruck back out to his vehicle, I cut the 2 plastic bands off the package. Then proceed to pull up on the main part of the box and got it entirely off. You then remove some styrofoam on top of the TV, as well as a sheet of it protecting the glass.
Once you plug it in, you can turn on the main power in the lower left hand corner (it's about 2-3 inches in from the side, on the bottom of the TV - you might need to lift up the TV a little, but just grab the handles in back and it shouldn't be a problem). Then I went into the box, got the remote and batteries, and turned the power to the TV on. I saw the NO INPUT signal and was happy from there.
Do give it a good look over with a flashlight as you can stop doing all of the above if you find any cracks.
amheck is offline
post #405 of 7095 Old 07-24-2009, 10:11 AM
FTracy3's Avatar
thanks..do you lean it up against something or just vertical and hope it doesn't tip..being extra cautious here...it won't be mounted for a couple of days.
FTracy3 is offline
post #406 of 7095 Old 07-24-2009, 10:12 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
Ah, thanks for the reminder.
Ftracy3: there are two "power" switches. The one on the left is power, the one on the right is standby. You can also use the remote to put the monitor in standby. The power switch will illuminate the red "power" led, the standby button will then switch on the blue led. There are notes in the FAQ.
bodosom is offline
post #407 of 7095 Old 07-24-2009, 10:14 AM
amheck's Avatar
Quoted: 18 Post(s)
I left mine vertical for a few days before I was able to find someone to help me lift it up on the wall mount. The styrofoam on the bottom does a pretty good job of holding it upright securely. In fact, I even installed my mount rails to the TV while it was upright in the box (although I did have to remove a little styrofoam at the bottom).
I just put the original box covering back on top and told the kids not to go near it.
amheck is offline
post #408 of 7095 Old 07-24-2009, 10:17 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
The greatest risk will be while you're fiddling with the power and the buttons if you have to lift the monitor to clear the packing supports. The driver might be convinced to act as a spotter possibly with some small monetary inducement.
After you test it you should close it back up and move it out of the way. Absent an impact or earthquake it won't fall over.
bodosom is offline
post #409 of 7095 Old 07-24-2009, 10:20 AM
J0HNNY H0PK1NS's Avatar
I sent you a PM with the link.
You may want to try another word other then "better". Because this is something that may be "better" to some owners but not so much "better" to another.
I'm probably answering these questions because other members didnt like the way you came in and asked. bodosom would normally chime in
Everything else < Kuro PLASMA
J0HNNY H0PK1NS is offline
post #410 of 7095 Old 07-24-2009, 10:45 AM
dtowntke's Avatar
sorry for my wording, i guess what is the big difference between isf and pure mode ?
dtowntke is offline
post #411 of 7095 Old 07-24-2009, 10:46 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
So I find myself using ISF night about 90% of the time. Of course I used Pure 90% of the time pre-ISF. So, for me, it's more about inertia (okay laziness) than a profound visual change. In the end I wouldn't be surprised if I don't use a scheme like HDMI-5 (Blu-ray) at ISF(32fL) 98% of the time and HDMI-4 (TV) at ISF(37fL) 90%.
bodosom is offline
post #412 of 7095 Old 07-24-2009, 10:47 AM
Googling yields stunning results
ISF VS Pure
post #413 of 7095 Old 07-24-2009, 11:04 AM
dtowntke's Avatar
good article thanks a lot
dtowntke is offline
post #414 of 7095 Old 07-24-2009, 11:18 AM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
There are a number of useful links in the FAQ (including that one).
bodosom is offline
post #415 of 7095 Old 07-24-2009, 12:06 PM
you take all the glory by referring everyone to your FAQ list
post #416 of 7095 Old 07-24-2009, 01:13 PM
-Kevin-'s Avatar
Hey guys, i've had my 500M for a few days now. I've only watched a couple blu rays so far. First one was sorcerer's stone. Now admitedly that one doesn't carry the best video transfer around.
But, i've noticed a little bit of what looks like "video noise" or is it "dithering?" Is that normal for this model? Does it go away after break in? Would an ISF calibration help out? Am I just being too picky?
When I run a ps3 game I don't notice it.
-Kevin- is offline
post #417 of 7095 Old 07-24-2009, 01:16 PM
tbird8450's Avatar
Quoted: 39 Post(s)
Liked: 54
If you don't see it while gaming then what you saw was film grain/artifacts in the source.
If it bothers you you could try to engage some of the TV's noise reduction functions.
tbird8450 is offline
post #418 of 7095 Old 07-24-2009, 01:30 PM
-Kevin-'s Avatar
-Kevin- is offline
post #419 of 7095 Old 07-24-2009, 01:39 PM
bodosom's Avatar
Quoted: 154 Post(s)
Liked: 58
There are several things that may be happening. Assuming that you're feeding everything into a single port (say HDMI-1) differences in video quality from the same source in the same format are in the source ("software" or hardware). The appearance of film grain in a movie is common and that would be my first guess but it's a guess. You'd need to provide more information about your configuration for us to be more specific.
bodosom is offline
post #420 of 7095 Old 07-24-2009, 01:43 PM
irfan's Avatar
I wont give you the link since you are obviously being flat out lazy. Google WILL give you a link to Control Cal's website, if you would just make the effort to type it in and hit "im feeling lucky". Ask Turbe and use their forums to discuss it.
irfan is offline
