The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #451 of 7143 Old 07-25-2009, 05:14 PM
J0HNNY H0PK1NS's Avatar
Quoted: 17 Post(s)
Originally Posted by Bazzy View Post
- Does anyone know of any good deals from an authorised dealer for the 600M?
Bazzy!
Originally Posted by bodosom View Post
Talking about where to buy a TV is against the "rules". Marketing of any sort is not allowed. This includes the forum sponsors. The KRP FAQ notes this among other things.
there he goes selling the FAQ again.
not being mean or rude but maybe we should stop asking questions and just refer to the FAQ
a nicer way of saying it would be... just do a search on google or another engine and you could also possibly look on the manufacturers website for a reference to a supplier.
No selling there, just 'helpful' assistance.
Everything else < Kuro PLASMA
J0HNNY H0PK1NS is offline
post #452 of 7143 Old 07-25-2009, 06:58 PM
jaffies's Avatar
A couple of questions:
1. Anyone know a idiot-proof way of connecting a KRP to a network? It's seems like I have everything set up correctly, but nothing.
2. I'm halfway through the DVD burn-in process, and the monitor seems to be running pretty hot. Is this normal?
jaffies is offline
post #453 of 7143 Old 07-25-2009, 07:03 PM
amheck's Avatar
Quoted: 22 Post(s)
Yes on #2. I haven't tried #1.
amheck is offline
post #454 of 7143 Old 07-25-2009, 07:47 PM
jbrady3324's Avatar
Quoted: 99 Post(s)
Liked: 39
Make sure you have the IP-Control enabled on the Kuro. I made this mistake
LG 65OLEDC7P
Pioneer KRP-500m
Next Level Acoustics HDMONs LCR, CI-IC44A In-Ceilings, CI-HV10 subwoofer
M&K LCR-750s, M-4T Surrounds, V1250thx subwoofer - FOR SALE!
Wharfedale Denton 80th Anniversary
Sennheiser HD800 & Grado PS1000 headphones
jbrady3324 is offline
post #455 of 7143 Old 07-26-2009, 07:51 AM
-Kevin-'s Avatar
Originally Posted by tbird8450 View Post
It sounds like you're seeing compression artifacts to me, especially if you only notice the shimmer during movement. Again, that's a source problem and not a TV problem.
I've never seen a Harry Potter Blu-Ray so I'm not sure if those movies are particularly bad in that area.
Again, you can test this with a game as you should never see compression artifacts while playing (cutscenes and such notwithstanding).
Okay, after further testing I can in fact see the effect during games. It is a very subtle noise or shimmering. It is mostly visible on solid, brighter colored material. I notice it even on the white bar anti IR "video pattern." You really have to be close to the TV to notice it. My normal seating position is about 6.5' away from the TV. The closer I get to the TV the more noticeable it is.
I wonder if this might be the aforementioned "pulse-width modulation" at work here?
-Kevin- is offline
post #456 of 7143 Old 07-26-2009, 08:21 AM
Jim_In_Boston's Avatar
I just want to say Thank You to Elite-home and Bodosom for their help in finding out what RGB refers to.
Jim
Jim_In_Boston is offline
post #457 of 7143 Old 07-26-2009, 09:32 AM
Quaxtros's Avatar
I would greatly appreciate it. Thank you!
Quaxtros is offline
post #458 of 7143 Old 07-26-2009, 09:58 AM
surap's Avatar
1233 mm.
I dont know how to measure inch..sorry
surap is offline
post #459 of 7143 Old 07-26-2009, 10:32 AM
Quoted: 17 Post(s)
by bezel width you mean full monitor width or bezel meaning the rim around the display itself?
post #460 of 7143 Old 07-26-2009, 10:40 AM
dtowntke's Avatar
how accurate is optimum mode?
dtowntke is offline
post #461 of 7143 Old 07-26-2009, 10:45 AM
bodosom's Avatar
Quoted: 285 Post(s)
Liked: 122
It's probably not clear enough but the "architectural" drawings referenced in the FAQ contain most of the interesting measurements.
In this case total width is 1233mm (48-17/32") and the screen width is 1111mm (43-3/4"). The width of the vertical bezel would then be 122mm (4-25/32).
bodosom is offline
post #462 of 7143 Old 07-26-2009, 01:33 PM
jbrady3324's Avatar
Quoted: 99 Post(s)
Liked: 39
Not very at least on my set. Too cool
LG 65OLEDC7P
Pioneer KRP-500m
post #463 of 7143 Old 07-26-2009, 03:13 PM
BetTheRiver's Avatar
I had decided on getting a 500M and was about to pull the trigger. Then yesterday my wife and I were in a BB. We stood at approximate viewing distance (say 10-12 feet or so) with a 50" set right over a 60" display, and I asked her which she thought would work best in our relatively small living room. To my great surprise, she said the 60".
So . . . the 500M is regarded as a better display, though it's not clear how significant the improvements are in a real-world situation, and would be about $800 less expensive; the cost difference is not a deal-breaker but hey, $800 is $800. The 600M has, obviously, a lot of extra real estate in its favor.
In either case, the display will be professionally calibrated and will have the ISF patch.
Thoughts? Are the improvements in the 500M enough to tip the scale, or would I likely not really notice the difference?
BetTheRiver is offline
post #464 of 7143 Old 07-26-2009, 03:46 PM
Magnus_CA's Avatar
This is a very personal choice but IMO the larger size far outweighs the difference in PQ. If you've got the room for it go for the 600, especially at your viewing distance. You won't be sorry.
Magnus_CA is online now
post #465 of 7143 Old 07-26-2009, 03:52 PM
amheck's Avatar
Quoted: 22 Post(s)
+1 for sure. I'm at around 16-17' and definitely wish my 600M was bigger.
amheck is offline
post #466 of 7143 Old 07-26-2009, 04:08 PM
Quaxtros's Avatar
Sorry for not being clearer. What I wanted to know is the width of the bezel on the left and right sides that frame the glass.
Quaxtros is offline
post #467 of 7143 Old 07-26-2009, 04:15 PM
Quaxtros's Avatar
Thank you. So the bezel width is about 2 1/2 inches on each side that frame the glass on the left and right sides.
Quaxtros is offline
post #468 of 7143 Old 07-26-2009, 07:52 PM
whityfrd's Avatar
Quoted: 63 Post(s)
Liked: 52
i noticed this measurement while hanging my 600m. and when looking at it at times the bezel seems a little beefy. kinda looks like a big block at times and is somewhat distracting.
whityfrd is offline
post #469 of 7143 Old 07-26-2009, 08:16 PM
tony9's Avatar
simple search result from the Pioneer website:
http://www.pioneerelectronics.com/ep...s/KRP-600M.pdf
tony9 is offline
post #470 of 7143 Old 07-26-2009, 08:36 PM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
So we all know that the black levels on the 600M aren't in the same league as the 500M...but when everyone says that they are "lighter", does that mean that it's the equivalent of the other 9g models?
That's what I've always assumed, but I just wanted some feedback.
hhaller is offline
post #471 of 7143 Old 07-26-2009, 08:48 PM
bodosom's Avatar
Quoted: 285 Post(s)
Liked: 122
Links to the manual and brochures are listed in FAQ. Both have overall dimensions and screen diagonal but omit the screen height and width. And no one wants to break out the trig.
bodosom is offline
post #472 of 7143 Old 07-26-2009, 08:57 PM
bodosom's Avatar
Quoted: 285 Post(s)
Liked: 122
That appears to be the common belief but I've never seen any numbers from Pioneer for minimum luminance. I don't think they publish contrast ratios either.
bodosom is offline
post #473 of 7143 Old 07-27-2009, 04:40 AM
eloon's Avatar
I had originally been planning on getting a Panny 54V10 because I found somebody who was going to practically give it to me.
Now I'm starting to reconsider to go with a 600M.
My real question/problem is that I can't figure out really what I'm giving up. The 141/151 are going to be out of my budget, which is what attracted me to the 600M. I'm willing to pay more for it for better PQ and bigger size, but I still haven't decided if I'm going to be willing to pay what they're asking.
I understand there's no antenna. I had been thinking of getting an OTA hd antenna. I'm guessing that means I need some kind of converter box as well, that would feed the AVR, which would feed the monitor? I'm thinking there is also no upconverting features in the 600M, so I would need to factor in the extra cost of getting a better upconverting AVR as opposed to letting the tv do it instead. I know the other things like no stand as well.
I'm just trying to figure out what other things I'm missing that could potentially sway my decision one way or another.
eloon is offline
post #474 of 7143 Old 07-27-2009, 05:17 AM
cajieboy's Avatar
Quoted: 125 Post(s)
Liked: 69
If you're wanting to go the OTA HD Antenna route, then you're looking at the wrong TV. The 600M is a reference monitor w/no internal tuner. The Pioneer Elite 151 has the internal tuner and the ISFcc modes, etc. You could possibly go buy an external HD Tuner to hookup to your TV, so factor in that cost as well. Pioneer's internal video processor is one of its best features, so it would defeat your purposes to bypass it.
cajieboy is offline
post #475 of 7143 Old 07-27-2009, 05:55 AM
eloon's Avatar
Maybe I should clarify. I've already got bluray, uverse, 360 with HDMI. The OTA HD antenna is just something else I've thought about trying due to it's relatively cheap cost. Almost more as a fun project to get it hooked up and see what it does. Definitely not in the plans right now, I just want to know if it's even do-able. Which I'm thinking it should be with a converter box hooked to the AVR.
My concern on the upconvert lies with the Wii, which is my only non HDMI source into the receiver. I had been debating the 919 and 1019 receiver, but had decided to get the 919 and let the tv do the upconverting of the Wii source. I wanted to make sure the 600m monitor would still do all of that the same as the tv would have.
eloon is offline
post #476 of 7143 Old 07-27-2009, 06:02 AM
bodosom's Avatar
Quoted: 285 Post(s)
Liked: 122
If you haven't read the KRP FAQ that's a good start.
...I'm thinking there is also no upconverting features in the 600M
The native panel formats are 1080p/60 or 1080p/72. All 9G Kuros will accept a wide range of standard formats from 480i to 1080p/60 and reformat as necessary.
bodosom is offline
post #477 of 7143 Old 07-27-2009, 06:22 AM
eloon's Avatar
Thanks for putting that together. I have read it. More than once actually. Never claimed to be great at reading for content though. My questions were really around the features of the monitor, or lack thereof. This is as opposed to the ISFccc calibration, speakers, and stands that the FAQ covers in depth among other things.
Primarily I want to know what I'm sacrificing to get better PQ and bigger size, albeit for more money. If I have to spend $4k+ on a 141 or 151 then I'm likely going to go with the v10 for less than half. I was hoping that the 600m would be a good middle ground. Just trying to figure out what I'd be getting myself into, know what I mean? The monitor route just seems to be a different beast.
eloon is offline
post #478 of 7143 Old 07-27-2009, 06:49 AM
bodosom's Avatar
Quoted: 285 Post(s)
Liked: 122
The Kuro comparison tables have a comprehensive listing of the differences.
I'm somewhat at a loss. I'm not aware of any significant difference between the Kuro monitors and Elites that isn't noted in the comparison or in the first section of the FAQ. Perhaps you could be more specific?
I think comparing Kuros to non-Kuros is an apples to oranges sort of thing and isn't fair to either party.
bodosom is offline
post #479 of 7143 Old 07-27-2009, 07:07 AM
cajieboy's Avatar
Quoted: 125 Post(s)
Liked: 69
The 600M are a real deal in my books because you are able to get a 60" Pioneer Kuro for a lot less coin than their Elite cousin, the 141. Most people who buy a 60" display for their Home Theater, already own or plan to immediately own an HT AVR and speaker system. Therefore, you're saving a bundle by not having to include those features in a display that you probably would not use anyway. The 600M does have a little amp for playing those optional TV speakers should you want to use that option for news, etc. w/o having to turn on your AVR & HT speakers. You can buy the optional speakers from Pioneer, or go to Ebay, etc. to purchase the 151 speakers that some people have put on there at a reduced price. Hope this helps. Good luck.
cajieboy is offline
post #480 of 7143 Old 07-27-2009, 07:26 AM
Kimwyn's Avatar
Everyone, i think eloon is asking probably the same question i asked. since the 600M has no internal tuner for TV, would running the cable box through an AV receiver solve the problem of showing cable TV???
cause this is exactly what i plan to do. I have a cable box currently (SD of course) with an antennae outside the house. i plan to hook the antennae up to the cable box, then from the cable box run composite cables to the AV receiver (Pioneer 919) and then run HDMI cable to the monitor (500M). would that solve the problem so i could get TV to show on the monitor?
Kimwyn is offline
