The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #4771 of 7137 Old 02-01-2010, 02:12 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
Originally Posted by smendick View Post
Quick question: do I need to worry about the RGB color space for the D-nice break in settings on the 500m? There seems to be little/no discussion about this anywhere. Seems like it is especially important to consider this issue during the break-in.
Nah.
chrisherbert is offline
post #4772 of 7137 Old 02-01-2010, 02:23 PM
smendick's Avatar
Originally Posted by chrisherbert View Post
Nah.
Care to elaborate? I am using an oppo 971hd and using the break-in slides so that I can use the D-Nice reference settings. Are you saying that the RGB color settings won't affect the reference settings no matter what color space I use?
smendick is offline
post #4773 of 7137 Old 02-01-2010, 04:18 PM
bodosom's Avatar
Quoted: 215 Post(s)
Liked: 69
The assumption is that you will use the correct color space.
bodosom is offline
post #4774 of 7137 Old 02-01-2010, 05:24 PM
William Moore's Avatar
Hello again! Thanks guys for all the tips. My set is using the PURE mode as set by an ISF calibrator (Doug Weil) who calibrated my TV back in November. I'm going to switch my Dish receiver (#VIP211) to using HDMI out to the Pioneer's HDMI in while disconnecting the RCA audio cables, but as I recall, I think most sync problems originate from my local digital OTA station which is an NBC affiliate; however, once I make this switch, I plan to document this sync problem if it doesn't clear up.
William Moore is offline
post #4775 of 7137 Old 02-01-2010, 06:52 PM
Jonesy11's Avatar
Quoted: 25 Post(s)
Liked: 26
Originally Posted by bodosom View Post
Excellent! Too bad about the lack of in-home service.
Is this always the case, no in home?
LG65B6P
Panasonic DMP 900UB
Pioneer KRP-500M
Pioneer Elite VSX-23TXH
Jonesy11 is offline
post #4776 of 7137 Old 02-01-2010, 07:40 PM
bodosom's Avatar
Quoted: 215 Post(s)
Liked: 69
I have no first hand experience with Pioneer but it sounds like it's entirely up to the actual (third-party) service provider. Some will do in-home (in their service area) some won't.
bodosom is offline
post #4777 of 7137 Old 02-01-2010, 08:20 PM
smendick's Avatar
For the sake of posterity, it was indeed correct with both DVD player and TV set to auto. Phew!
smendick is offline
post #4778 of 7137 Old 02-01-2010, 10:42 PM
shane55's Avatar
You know I recently had my 600m calibrated (to perfection by D-Nice! Thanks!). This was done for both my Oppo BDP-83 and my HD TiVo that was used with Comcast cable.
I am thinking about switching from Comcast to ATT U-Verse.
This means not only a different provider, but also a different DVR (TiVo to Moto).
Is my calibration for the TiVo going to be good with the U-Verse, or am I hosed and will need to re-calibrate?
Anyone have this experience?
shane
"Yes Eve... I like to watch." - Chauncey Gardener.
My HT Setup:
http://www.fototime.com/A0E2793180FB3D0/orig.jpg
shane55 is offline
post #4779 of 7137 Old 02-01-2010, 11:46 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Crippling a Kuro with Pew-Verse is akin to putting regular-octane unleaded in your Lexus.
vinnie97 is offline
post #4780 of 7137 Old 02-02-2010, 05:32 AM
choptalk's Avatar
Quoted: 20 Post(s)
Is it just me or is my picture just keep getting better and better?
I guess I have about 500 hrs on my set now and it seems like my picture gets a little bit better every time I turn it on.
I cant decide if its because I am getting use to a properly calibrated set(coming from a torched LCD), or if it is just getting better by getting used more.
One way or the other my set is either looking better, or the correct picture is just growing on me.
choptalk is offline
post #4781 of 7137 Old 02-02-2010, 07:20 AM
JonW747's Avatar
Quoted: 143 Post(s)
Liked: 77
Message him and ask. I wouldn't think you'd be "hosed", but there may be some minor tweaks he'd recommend. For instance he bumped up my sharpness setting some for the sake of DirecTv.
JonW747 is offline
post #4782 of 7137 Old 02-02-2010, 08:36 AM
spongebob's Avatar
Quoted: 76 Post(s)
shane
How do they calibrate to cable/sat, etc inputs? The boxes don't generate test patterns so what do they do?
bob
spongebob is offline
post #4783 of 7137 Old 02-02-2010, 09:15 AM
turbe's Avatar
Liked: 97
bob
I like how Michael Chen replies to these posts:
Originally Posted by Michael TLV View Post
Greetings
Cannot calibrate for cable or satellite. TIVO falls into that category. Nothing is reference on it ... channels and programming all vary greatly.
You take the DVD calibration and cross your fingers. You will have to adjust a bit on the fly.
Or you put a HD signal generator up to the TV ... set set it up that way ... and you still have to cross your fingers again hoping that the programming material matches this reference source. Which it may not.
regards
Greetings
As mentioned. Won't really matter since TVs are never calibrated to cable boxes or satellite receivers per se. It is done with a signal generator which represents a reference signal source. After that ... you cross your fingers and hope the tv stuff falls into line with the generator reference. If not ... you still have to play with the brightness, color, tint here and there.
regards
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #4784 of 7137 Old 02-02-2010, 10:47 AM
rumba's Avatar
shane
Is the picture quality better with AT&T? I'm unhappy with Comcast right now and thinking of trying something else.
rumba is offline
post #4785 of 7137 Old 02-02-2010, 10:52 AM
rocky1's Avatar
Hoping someone could advise me on the Spears & munsil dvd i just got to use on my 500m.I'm assuming i would use it in a particular pic setting like standard or user.Was hoping someone who has used the S&M could advise if there is a preferred pic setting when calib.w/ this dvd.I posted here due to 500m forum,if i should of posted in the calib. forum i can do that if need be.
Never used a calib. dvd so please bear with me.
rocky1 is offline
post #4786 of 7137 Old 02-02-2010, 12:16 PM
scionracing's Avatar
You can calibrate as many of the picture modes as you wish; just keep in mind that all modes will require separate calibrations. Further, not all picture modes are capable of producing high quality, accurate (linear) imagery. Out of the box, Pure mode is capable of the most accurate image, as it is derived from a professional reference Sony CRT monitor.
Beyond that, you can order the ISF patch, which provides access to the ISFccc modes. These are capable of an even more accurate (linear) image than is Pure.
S&M has a great user's manual on their site.
scionracing is offline
post #4787 of 7137 Old 02-02-2010, 12:18 PM
Quoted: 17 Post(s)
I don't think think it would matter much anyway.
post #4788 of 7137 Old 02-02-2010, 12:23 PM
shane55's Avatar
From what I have read, a lot depends on where you are and the local provider of each.
I have more reasons than just the PQ.
That said, I haven't made a decision yet.
shane
My HT Setup:
shane55 is offline
post #4789 of 7137 Old 02-02-2010, 12:25 PM
rocky1's Avatar
Thanks.I do plan on getting the patch,just cant right now.Also need to see if i could install the patch myself.I'm not computer literate.Also if yopu know do i activate the blue only mode on the 500m when using the disk?
rocky1 is offline
post #4790 of 7137 Old 02-02-2010, 12:29 PM
shane55's Avatar
Thanks all for your replies...
If I decide to actually switch providers, I'll see what the results are and worry about it then.
shane
My HT Setup:
shane55 is offline
post #4791 of 7137 Old 02-02-2010, 03:26 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
AT&T uses the most compression across all the providers due to the aging copper conduit that they insist on using. Generally speaking, they have the poorest quality of all.
vinnie97 is offline
post #4792 of 7137 Old 02-02-2010, 03:48 PM
DeanM3's Avatar
I've found some useful information on this thread, so I thought I would try to give something back.
For quite some time I've been trying to create the perfect xorg.conf for the Pioneer KRP-500M, so that I could attain perfect 24/50/60hz. The following is my xorg.conf ( tested with the KRP-500M only ) that allows perfect synced playback in all refresh rates.
I've test this with both the Boxee and XBMC (9.11 Camelot ) releases on Ubuntu 9.10. You can use a very inexpensive set of hardware ( such as an ION setup ) and have a perfect 1080p24 HTPC for your Kuro.
You can simply copy this over your /etc/X11/xorg.conf, or use the modelines for your setup.
http://pastebin.com/f219f5d21
Enjoy.
DeanM3 is offline
post #4793 of 7137 Old 02-02-2010, 07:40 PM
bodosom's Avatar
Quoted: 215 Post(s)
Liked: 69
Originally Posted by turbe View Post
I like how Michael Check replies to these posts:
Although it's more an affirmation than a solution my DVR recently gained the ability to talk to my network media server and at first glance it appears to be straightforward digital transport.
bodosom is offline
post #4794 of 7137 Old 02-03-2010, 05:39 AM
Yes, if the display offers BOM, use it instead of the blue filter for setting color (saturation and hue). While blue filters are capable of being just as effective as BOM, we don't live in a perfect world; the filter may have some light leakage, which can result in color values that are far off-target.
Compared to using hardware (meter), BOM can arguably be nearly as accurate. When BOM is used correctly, you will typically be within a single click of the values you would arrive at using a colorimeter (hardly perceptible in real-world video).
P.S. Installing the patch is very straightforward. 'turbe' does an excellent job with the whole process. It really couldn't have been easier.
post #4795 of 7137 Old 02-03-2010, 07:47 AM
rocky1's Avatar
Thanks.I'm assuming i'll turn on the BOM when ready to do the color setting and turn it back off after the settings are done?Or do i keep it on throughout when using the S&M.
rocky1 is offline
post #4796 of 7137 Old 02-03-2010, 09:42 AM
Quoted: 17 Post(s)
My experience with blue only mode is that it's almost exactly as inaccurate as using a filter -- I always get oversaturated colors when I use it.
post #4797 of 7137 Old 02-03-2010, 10:15 AM
bodosom's Avatar
Quoted: 215 Post(s)
Liked: 69
S&M have a brief about this on their site. Stacey mentioned they were reviewing their filter usability process.
As I've noted in the past I get results similar to my meter using the S&M HD pattern in BOM. I imagine there must be technique and physiological differences from person to person that make this less reliable than it can be. Fortunately there are enough posted values that one is unlikely to go too far wrong.
bodosom is offline
post #4798 of 7137 Old 02-03-2010, 10:33 AM
AudioN00b's Avatar
Got a issue with the IP control on my KRP 500m. When I try to enter a IP address into my browser I get a page not found. I am running my KRP 500m through a router and I have enabled the IP on the KRP but I'm still having issues.
AudioN00b is offline
post #4799 of 7137 Old 02-03-2010, 10:44 AM
bodosom's Avatar
Quoted: 215 Post(s)
Liked: 69
If IP Control is set to Enable then you debug network problems the same way you would for any other device on your network. i.e. does it have carrier, an ip address on the right sub-net, is your router blocking the traffic, does some other device have the same address, does ping work etc. etc. etc.
bodosom is offline
post #4800 of 7137 Old 02-03-2010, 10:53 AM
Quoted: 17 Post(s)
I've never used the S&M disc, only Avia, DVE and the AVS discs. The techniques are too simple to mess up and the the results are so consistent between the discs that I don't think it's an error on my part.
Could be a physiological difference, I guess, but I know that D-Nice predicted that the color would be 5 clicks too high using BOM and it was *exactly* five clicks too high when I used a meter.
