The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 209 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #6241 of 7137 Old 07-21-2011, 07:09 AM
dlplover's Avatar
Just out of curiosity, try swapping it into power save 2 and see if that helps at all.
I run mine in ISF w/PS2 and Orbiter2 and have never noticed anything like that. I wonder if it's some kind of mismatch between the initialization voltage and the aging of the phosphors.
One thing I also do is that because I primarily use my set to watch BR's and because I watch primarily from my HTPC, I usually just play the ts file directly from the disc with MPC-HC (instead of bothering with all the previews, "extras", and junk). When MPC-HC finishes, it just goes to a black screen and I'll often leave it like that and go do something else.
Possibly, the red tint has something to do with not displaying black versus other content?
dlplover is offline
post #6242 of 7137 Old 07-21-2011, 07:35 AM
Mac13's Avatar
Hm I will try power save 2 but kind of doubting that will do anything. What is weird is that when my PS3 goes to load a disc then the screen fluctuates between a couple different black levels until the picture actually comes on. At first it is a grayer picture and the blacks aren't as good but there is no reddish tint. Then, it switches again and becomes darker but that is when you can see the reddish tint. Then the film starts. What is the deal with the switching black levels and why is the reddish tint only on the final darker picture? Is this just the PS3 switching resolutions or something?
Hopefully that made sense and I didn't confuse everyone.
Mac13 is offline
post #6243 of 7137 Old 07-21-2011, 07:45 AM
dlplover's Avatar
Is this from off? Usually when you first switch on an input you get the blank input black (basically off), then once it initializes the voltage for content you get the deeper black. That earlier, lighter black has no bearing on content.
Mind posting your picture settings? Specifically I'm curious what contrast you're running. Might also want to see if dialing that down helps things at all. If you have the sharpness setting set very high might want to reduce that as well (if you want a sharp image, it's probably preferable to use DRE and enhancer than the sharpness setting).
dlplover is offline
post #6244 of 7137 Old 07-21-2011, 08:11 AM
phannon's Avatar
Quoted: 18 Post(s)
Liked: 25
Mac13:
I agree, the "tint" is starting to annoy me. It is not noticeable most of the time, but get a really dark scene, e.g. the recent Harry potter movies and it stands out and as you say once you see it, it is hard to ignore....sometimes you can...but... If the monitor is switched to an unused input you can usually see the red tint (though, sometimes it does not seem as noticeable!!??) and you cannot remove it from here using the white balance controls no matter how much you change the adjustments. When you adjust the blue cut up to +8 or so on a letterbox movie, you turn the active area blue and the tint disappears to a blue/grey glow (more or less like I remember the bars in dark scenes before the tint.) I still have a month to go on my Canadian 3 year warranty, so I want to see if there is a fix before the time runs out. My dealer /repair guy knows about the problem and hopefully it will be on record if a fix (or problem) is found.
dlplover:
I use powersave 2, pure mode and have all enhancements turned off. I have gone through the adjustments, turning things on and through settings but with no encouraging results. It makes no difference if one uses component or HDMI. It seems to be mostly seen on "0" black. The other evening I watched a 1.85:1 movie and did not notice any letterbox bands during the movie...but during a rather dark scene, a crimson bar could be seen in the bottom letterbox (a cm or two high?) but no noticeable tint in the picture! I rarely even notice the bars at any time on 1.85:1 presentations, this was one of the times when it was standing out a bit more than normal. Maybe now that this has been mentioned everyone will start seeing "red tint"...mass hallucinations!
Cheers,
P.E.H.
phannon is offline
post #6245 of 7137 Old 07-21-2011, 08:34 AM
Mac13's Avatar
Haha. Ya I was wondering if this still occurred while using a component connection as I tried both of my HDMI inputs. I guess it does, thanks for the info. Kind of funny you mentioned Harry Potter because that is what I have been watching. I thought it could just be the source but I have noticed it while watching Band of Brothers and while watching cable as well.
dlplover I am using D-Nice's exact Pure settings ( http://www.avsforum.com/avs-vb/showt...9#post14384909 ) so I would think that would be fine. I notice the blackness change when I select the DVD to play in the PS3. It is after I have turned everything on. It is when it goes to boot up the DVD and start displaying content.
Mac13 is offline
post #6246 of 7137 Old 07-21-2011, 10:25 AM
NateTTU's Avatar
I haven't visited this portion of the forums in a while so please bare with me as this might be a pretty old topic.
A long while ago D-Nice mentioned the ability on some 600M panels that he could unlock/change something that would bring down the MLL to the same level as the 500M panels. Was there any additional information on this and maybe which panels it might apply to?
I'm looking to get my set calibrated, unlock ISF modes, and do this as well it would be a pretty nice upgrade and I think I could convince the wife to let me do this.
NateTTU is offline
post #6247 of 7137 Old 07-21-2011, 12:36 PM
hhaller's Avatar
Quoted: 72 Post(s)
Liked: 51
Well if you're looking to get your set calibrated, why don't you contact D-Nice and kill two birds with one stone?
hhaller is offline
post #6248 of 7137 Old 07-21-2011, 05:27 PM
NateTTU's Avatar
I sent him a pm a while ago and didn't hear anything back. Figured he gets a lot of those so I was hoping to get an answer here instead. That way the next time I send him something it will be to schedule the calibration appointment instead of bothering him with questions. depending on the answer to my question might also change my mind, at least for now, about the calibration.
NateTTU is offline
post #6249 of 7137 Old 07-21-2011, 06:19 PM
Iorek's Avatar
Quoted: 12 Post(s)
I tried contacting D-Nice about a calibration a number of times but got no response
Iorek is offline
post #6250 of 7137 Old 07-21-2011, 06:26 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 31
Did either of you guys try emailing him? As PM's sent through AVS are not at all a sure fire way to contact him.
Johnla is offline
post #6251 of 7137 Old 07-21-2011, 06:28 PM
Iorek's Avatar
Quoted: 12 Post(s)
I did.
Iorek is offline
post #6252 of 7137 Old 07-21-2011, 06:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Email D-Nice here:
audiovideofidelity@gmail.com
htwaits is offline
post #6253 of 7137 Old 07-21-2011, 06:45 PM
D-Nice's Avatar
Quoted: 691 Post(s)
Liked: 1487
Nate,
Unfortunately I never received an email from you. Please send another via my signature.
D-Nice is offline
post #6254 of 7137 Old 07-21-2011, 06:46 PM
D-Nice's Avatar
Quoted: 691 Post(s)
Liked: 1487
+1. AVS PMs are the absolute worst way to contact me. Use my signature to contact me.
D-Nice is offline
post #6255 of 7137 Old 07-21-2011, 06:47 PM
D-Nice's Avatar
Quoted: 691 Post(s)
Liked: 1487
D-Nice is offline
post #6256 of 7137 Old 07-21-2011, 08:01 PM
NateTTU's Avatar
E-mail sent. Thanks.
NateTTU is offline
post #6257 of 7137 Old 07-21-2011, 08:25 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Originally Posted by D-Nice View Post
d-nice@audiovideofidelity.com
Thanks. I'll update my address book.
htwaits is offline
post #6258 of 7137 Old 07-21-2011, 08:36 PM
Iorek's Avatar
Quoted: 12 Post(s)
D-Nice, I also sent another mail. Could you please let me know if you're not receiving it? I'd really like to get my TV calibrated by the best!
Iorek is offline
post #6259 of 7137 Old 07-22-2011, 07:37 AM
blb1215's Avatar
D-Nice,
I also just sent an email.
Barry
blb1215 is online now
post #6260 of 7137 Old 07-22-2011, 08:55 AM
dlplover's Avatar
How often do you notice it. Is it only on specific content or on a wide variety? It's pretty worthless to compare cable since it's different providers, but if there's specific movies you notice on, I could check on mine to see if it's just poor master or something. Actually, if you have an IPS LCD monitor for your computer, you could probably check that for yourself either by playback on pc or through an adapter from your ps3 (if your monitor won't take hdmi).
The way the PS3 works, I think it has a separate "module" for the DVD/PS3 playback. Like it disconnects from the monitor and then reconnects which is why you're temporarily at the blank input screen.
dlplover is offline
post #6261 of 7137 Old 07-22-2011, 09:11 AM
leroyjr1's Avatar
*help needed*
How do I check the panel hours on my 500m?
leroyjr1 is offline
post #6262 of 7137 Old 07-22-2011, 09:34 AM
dlplover's Avatar
Originally Posted by leroyjr1 View Post
*help needed*
Kuroreader via network interface is probably the easiest method. It's in one of the tabs.
dlplover is offline
post #6263 of 7137 Old 07-22-2011, 10:10 AM
leroyjr1's Avatar
Directions?
leroyjr1 is offline
post #6264 of 7137 Old 07-22-2011, 10:12 AM
dlplover's Avatar
Directions?
http://www.avsforum.com/avs-vb/showthread.php?t=1175615
Don't try to use it to adjust ISF though. You need to use KuroControl for that.
dlplover is offline
post #6265 of 7137 Old 07-22-2011, 10:34 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Change kuro to your name or ip address and go to this link:
http://kuro/cgi/service_right.cgi
Don't forget to read the FAQ
Originally Posted by The KRP FAQ View Post
  1. Q. How can I check my usage time (hours on), power count, serial number or retrieve the SD/PD Failure code?
    a. You have to configure your KRP for network access, attach it to a network or directly to a PC and then open this link: http:///cgi/service_right.cgi where is replaced with the IP address of your KRP -- EZ Hours. You can also check the hours with jdbimmer's KuroReader program (see below) and via the serial port with Chelsea_Fan's piotime
bodosom is offline
post #6266 of 7137 Old 07-23-2011, 04:56 AM
surap's Avatar
Mine does it also. I think it is switching resolution. Maybe you have different picture settings for different resolution?
surap is offline
post #6267 of 7137 Old 07-23-2011, 08:50 AM
Mac13's Avatar
No I think they are the same. It wouldn't make sense for one to have better black level but a reddish tint and then the other be more grayish.
Mac13 is offline
post #6268 of 7137 Old 07-23-2011, 11:07 AM
Ronmck's Avatar
Guys, I could be wrong about this but it seems to me that this could be related to greyscale calibration.
Ronmck is offline
post #6269 of 7137 Old 07-23-2011, 11:35 AM
Mac13's Avatar
Not so sure about that because I think I heard about a few people that had their sets professionally calibrated and it didn't get rid of the red tint. I wish you were right though.
Mac13 is offline
post #6270 of 7137 Old 07-23-2011, 12:51 PM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Yes.
bodosom is offline
