The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 234 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #6991 of 7130 Old 07-02-2014, 12:18 AM
denon a1xva's Avatar
Quoted: 25 Post(s)
Not yet. I will give an update asap, time and distance is the problem right now
Originally Posted by Stu03 View Post
Did you get hold of the part ?
Stu03 likes this.
denon a1xva is offline
post #6992 of 7130 Old 07-15-2014, 10:22 AM
Stickgs's Avatar
My KRP-600M has stopped working after a pretty severe Thunderstorm. By that I mean it turns on but flashes a message in the panel while on either input 5 or 6 (HDMI) that "No Signal Detected" The set was not turned on during the storm and I have always used surge protectors. Has anyone else ever run into this problem and/or know of the fix?
Stickgs is offline
post #6993 of 7130 Old 07-15-2014, 12:18 PM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
Check all the inputs.
bodosom is offline
post #6994 of 7130 Old 07-16-2014, 08:31 PM
Stickgs's Avatar
Thanks for the suggestion. I systematically tried every component seperately and the 600M is working fine. The problem appears to be with my Onkyo TX-NR1007 AV Receiver's HDMI board. I can get audio out through my Blu-ray but no picture on the 600M. I get nothing, neither audio or video out from the comcast cable DVR box. After some research it appears that Onkyo has a history of bad HDMI board issues. Have contacted them to see what if anything can be done. Thanks again!
Stickgs is offline
post #6995 of 7130 Old 07-18-2014, 06:31 PM
Actionable Mango's Avatar
Quoted: 24 Post(s)
Liked: 30
Yep, my Onkyo TX-SR606's HDMI started to go out. Replaced with a Yamaha AVR and all is good again.
Actionable Mango is offline
post #6996 of 7130 Old 07-20-2014, 09:16 AM
Quoted: 25 Post(s)
I changed the power supply (with the right tools an easy job) it took me 45 minutes, but the 500M does exactly the same: 2 blinking lights and doesn't start up.
Edit: the part number is the same (power supply 500A or M)
post #6997 of 7130 Old 07-20-2014, 09:28 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
2 red or 2 blue blinks?
tom669 is offline
post #6998 of 7130 Old 07-20-2014, 09:34 AM
Quoted: 25 Post(s)
Hi Tom. 2 red blinks.
After plugging the power cord, and pressing the power button (on the panel) there is one red steady light. Then i press the power button of the remote controle, the Kuro wants to start up but enters some sort of protection mode and then i get 2 red blinks.
post #6999 of 7130 Old 07-20-2014, 09:49 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Ok, try unplugging the Y DRIVE and X DRIVE assemblies from the power supply. Does the fault code change to 3,4,6,7,10 or 11? (I don't know for sure which one it will change to, but it should be one of these.)
Leave the TV unplugged for several minute before doing this. Do not disconnect/reconnect anything unless power has been off for more than a few minutes.
If it goes to one of those fault codes try with Y DRIVE only, then see if code is 3,8,10 or 11... if it goes to 2 blinks = bad YDRIVE (short at VSUS)
If it goes to 3,8,10 or 11 try with X DRIVE only, if you get 2 blinks = bad XDRIVE (short at VSUS)
If neither board eliminates 2 blinks it may be VADR short = probably dead plasma panel if this is the case (I really hope not!)
tom669 is offline
post #7000 of 7130 Old 07-20-2014, 09:58 AM
Quoted: 25 Post(s)
Hi Tom, thanks again for trying to help me.
I will give it a try later this week because i dont have any more time at the moment. What i know from the previous owner ( i bought the panel damaged for 100 euro) is that before the Kuro died it started to buzz and suddenly did not want to start up any more.
This seems to be the same problem but with a different model:
http://www.avforums.com/threads/pion...nking.1542076/
Ok, try unplugging the Y DRIVE and X DRIVE assemblies from the power supply. Does the fault code change to 3,4,6,7,10 or 11? (I don't know for sure which one it will change to, but it will be one of these.)
post #7001 of 7130 Old 07-29-2014, 09:06 AM
Quoted: 25 Post(s)
I have both the X board, and the Y board with me as a spare part. For now i have replaced just the X drive Assy and now the Kuro blinks 4 times. I didn't have time to change both boards.
post #7002 of 7130 Old 07-29-2014, 12:53 PM
Quoted: 25 Post(s)
I have replaced the power supply, the two boards and also the ac input with the filter. The 4 times blinking had to do because i forgot to reconnect a flat cable. Now after replacing i have the two times blinking led back again. What is there left to do? There are also some other boards in the tv.
post #7003 of 7130 Old 07-29-2014, 01:50 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Do you have a digital multimeter? To check voltages, rather than shot gun replacing boards, which will cost you nearly as much as a 2nd hand Kuro.
tom669 is offline
post #7004 of 7130 Old 07-29-2014, 02:43 PM
Quoted: 25 Post(s)
No i don't. It didn't cost me much, just a system cable and a couple of Euro's. For that money i almost have all the parts that are inside. Once i opened the Kuro up again i was like let's change these parts which i have. But there are still some boards that can be changed.
post #7005 of 7130 Old 07-29-2014, 03:30 PM
makaveddie81's Avatar
Quoted: 467 Post(s)
Liked: 273
Have you tried clearing the shutdown and power down logs and unplugging the set for 5 minutes? This worked for me when my Kuro failed to power up after it shut down due to me over adjusting one of the pots on the power supply.
I don't recall the number of blue LED flashes, but its worth the shot.
makaveddie81 is online now
post #7006 of 7130 Old 07-29-2014, 03:35 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
There is a risk with swapping parts when you do not know if they are bad. On some plasmas one board can kill another. For example the bonded Y-buffer board can potentially damage the Y-drive board. That is rare, but the possibility must be considered. So I would highly suggest your acquire a meter (they can be bought for less than 8 euro) and learn how to use it. You can check for VSUS and VDA, to see if there is a panel short or Y-/X-drive short, also you can check the KNOFSAD voltages for example.
tom669 is offline
post #7007 of 7130 Old 07-29-2014, 11:54 PM
Quoted: 25 Post(s)
How do you clear the shutdown and power down logs?
Thanks i will give that a try!
post #7008 of 7130 Old 07-30-2014, 03:20 PM
Quoted: 467 Post(s)
Liked: 273
You have to enable factory mode by issuing the FAY command, then issue the CSD and CPD commands.
If you don't have software to issue commands to your Kuro, I suggest you check out my program. The first post includes the required hardware.
Kuro Command Program
post #7009 of 7130 Old 07-30-2014, 11:38 PM
Quoted: 25 Post(s)
Thank you. I only have the "Kuro tool" written by a dutch formum member and I do have the usb-RS 232 cable. Can the software communicate with the Kuro while it's not turned on?
post #7010 of 7130 Old 07-30-2014, 11:40 PM
Quoted: 467 Post(s)
Liked: 273
As long as the red led is on yes it will communicate with it.
denon a1xva likes this.
post #7011 of 7130 Old 08-02-2014, 10:04 AM
Quoted: 25 Post(s)
I have tried the Kapture tool to see if it connects but here it doesn't. I need to select com port 13 correct?
About your new tool: sended you a pm.
post #7012 of 7130 Old 08-02-2014, 10:34 AM
Quoted: 467 Post(s)
Liked: 273
No. You must enter the com port that your computer assigned to your usb to serial adapter (usually 3, 4 or 5). You have to go into device manager and locate your adapter to get the correct com port number, but try 3, 4 and 5.
post #7013 of 7130 Old 08-02-2014, 11:45 AM
Quoted: 25 Post(s)
Thanks it did work but i must be doing something wrong because there seem to be values in the report.
post #7014 of 7130 Old 08-02-2014, 12:05 PM
Quoted: 467 Post(s)
Liked: 273
The report is empty so you might be communicating with a device other than your Kuro.
Go to device manager > ports (com&lptp) and locate your usb to serial adapter to get the right COM port.
post #7015 of 7130 Old 08-02-2014, 12:22 PM
Quoted: 25 Post(s)
It really says COM port 13 and it did run once but not anymore.
post #7016 of 7130 Old 08-02-2014, 01:18 PM
Quoted: 467 Post(s)
Liked: 273
What type of cable are you using?
post #7017 of 7130 Old 08-03-2014, 12:33 AM
Quoted: 25 Post(s)
I use these cables that work just fine with the Kuro tool connected to a KRP-500A/600A
https://www.mycom.nl/product/5176/ic...rial-cable-18m
http://www.falconcomputers.co.uk/hq/...ld-plated.html
post #7018 of 7130 Old 08-03-2014, 12:53 AM
Quoted: 467 Post(s)
Liked: 273
Are you unzipping the program before running it?
If you a 100 percent sure the cables and your adapter work with other Kuro programs and you are decompressing the file before running, then I'm afraid I can't help you.
post #7019 of 7130 Old 08-03-2014, 02:05 AM
Quoted: 25 Post(s)
Yes i did, it unzipped to an automatic.exe and a manual.exe file
I think my Kuro is really F**ked up and you helped me a lot so thanks again!!
post #7020 of 7130 Old 08-03-2014, 02:41 AM
Quoted: 25 Post(s)
I have noticed that in the last part of the report, there is something written:
37 Subcategory of 8th latest shutdown: Stop of the fan for the drive system
Could this be a fault in the Kuro? The rest of the report is empty.
