The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #7021 of 7137 Old 08-03-2014, 02:21 AM
makaveddie81's Avatar
Quoted: 482 Post(s)
Liked: 274
Originally Posted by denon a1xva View Post
I have noticed that in the last part of the report, there is something written:
37 Subcategory of 8th latest shutdown: Stop of the fan for the drive system
Could this be a fault in the Kuro? The rest of the report is empty.
Interesting. So the program is talking to your Kuro and your Kuro is just responding to one command.
If you have kuro control, if you have kuro control (and it works on your tv) issue the qpd and qps commands and reply with their output.
makaveddie81 is offline
post #7022 of 7137 Old 08-03-2014, 02:35 AM
Quoted: 482 Post(s)
Liked: 274
Actually that is the shutdown log that is generated by the qsd command. So the error message that you posted might shed some light into what ails your kuro.
The program is working as intended. Your kuro is simply not responding to any commands due to its current status.
post #7023 of 7137 Old 08-03-2014, 02:45 AM
denon a1xva's Avatar
Quoted: 25 Post(s)
I have downloaded the program Kuro control, but what do you mean with "issue the gpd and gps commands" ? I only see ISF settings? Do i have to enter the commands somewhere?
denon a1xva is offline
post #7024 of 7137 Old 08-03-2014, 02:50 AM
Quoted: 25 Post(s)
I missed this post. Yes there might be a problem with a cooling fan as far as i read it.
post #7025 of 7137 Old 08-03-2014, 04:36 AM
bberns22's Avatar
Quoted: 45 Post(s)
Liked: 37
151D - 2100 Hrs - Calibrated -
ID:	194458   Click image for larger version
bberns22 is offline
post #7026 of 7137 Old 08-03-2014, 05:47 AM
craigyboy's Avatar
Quoted: 37 Post(s)
Liked: 91
your point is?
craigyboy is online now
post #7027 of 7137 Old 08-03-2014, 05:55 AM
bberns22's Avatar
Quoted: 45 Post(s)
Liked: 37
Originally Posted by craigyboy View Post
your point is?
Thts just it - 2008 - 2014 adios Kuro
bberns22 is offline
post #7028 of 7137 Old 08-03-2014, 10:08 AM
Quoted: 482 Post(s)
Liked: 274
Selling it or?
post #7029 of 7137 Old 08-21-2014, 07:08 PM
Y2JDMBFAN's Avatar
Quoted: 666 Post(s)
Liked: 226
What is the reccomendation to set the color and tint when calibrating? I have read that both blue only mode and blue filters with the AVS 709 disc are not accurate. I have an i1Pro, can I use it and Calman to set the color and tint?
Y2JDMBFAN is offline
post #7030 of 7137 Old 08-23-2014, 11:47 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
Yes.
bodosom is offline
post #7031 of 7137 Old 08-23-2014, 03:10 PM
Y2JDMBFAN's Avatar
Quoted: 666 Post(s)
Liked: 226
Originally Posted by bodosom View Post
Yes.
Any hints on which pattern or parts in Calman to use?
post #7032 of 7137 Old 08-29-2014, 04:49 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
A 600M, stand, manual, remote, no speakers with one HDMI not working.
No idea of the hours. No visible image burn or red tint
.....worth $1400?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #7033 of 7137 Old 08-29-2014, 05:54 AM
8mile13's Avatar
Quoted: 1545 Post(s)
Liked: 865
.....worth $1400?
I bought me the 500m for 1,000 euro a week ago. No stand and no speakers. Not much usage, less than 2000 hours i think. No burn-in or red tint. So i was in a similar boat.
Anyway it is very risky to buy a Pioneer Plasma since it is five years out of bussiness and lots of their Plasma's have lots of hours on them. I would only buy one if it has less than 5000 hours, no visible image burn or red tint. One inactive HDMI input is less relevant imo. To me $1,400 sounds like a good deal, more than 5000 hours is a dealbreaker for me.
8mile13 is offline
post #7034 of 7137 Old 08-29-2014, 06:45 AM
spongebob's Avatar
Quoted: 39 Post(s)
.....worth $1400?
You buying or selling?
spongebob is offline
post #7035 of 7137 Old 08-29-2014, 07:30 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Buying
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #7036 of 7137 Old 08-29-2014, 09:16 AM
craigyboy's Avatar
Quoted: 37 Post(s)
Liked: 91
5000 hours is nothing, wouldn't worry about that,its the image that counts
post #7037 of 7137 Old 08-29-2014, 11:02 AM
8mile13's Avatar
Liked: 865
Well. It is my money. I would not feel comfortable buying a five year old heavy usage TV..
8mile13 is offline
post #7038 of 7137 Old 08-30-2014, 05:41 AM
umass66's Avatar
Quoted: 54 Post(s)
Liked: 26
please help with this question.
When adjusting brightness it is helpful but not essential if your display can display below black when using a test disc.
how do you display below black on a krp-500/ krp-600m. even if i go below 0 on brightness, i don't see below black bars on test discs.
My real old panasonic plasma could easily do this.
umass66 is offline
post #7039 of 7137 Old 08-30-2014, 06:00 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
Not to agree with your premise but the simplest way to see below 16 is to change quantization to IT. The difficulty should be on a par with your "real old panasonic".
bodosom is offline
post #7040 of 7137 Old 08-30-2014, 09:53 AM
umass66's Avatar
Quoted: 54 Post(s)
Liked: 26
could you explain above in less technical language. thanks.
umass66 is offline
post #7041 of 7137 Old 08-30-2014, 10:25 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
Change the (HDMI) input signal type from 3 (RGB16-235) to 4 (RGB0-255).
However if you're just trying to set the black-level ("brightness") without regard to overall gamma then get a test pattern with 1%, 2%, 3%, 4% etc. bars and use the difference between 0% and 1% or 2%.
I'd suggest the Spears and Munsil disk (either edition) but in any case you should read their adjustment documents.
E.g. http://www.spearsandmunsil.com/portf...tness-control/
Poynton's black level note is also useful background although, strictly speaking, it's about analog not digital devices.
Greater depth regarding all this and more can be found in Poynton's columns for SpectraCal.
bodosom is offline
post #7042 of 7137 Old 08-30-2014, 04:12 PM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Using RGB16/235 will give you the best image quality and it's neither helpful or essential to see below (16) black, KRP's are usually 0 or +1 for brightness.
-Hitman- is offline
post #7043 of 7137 Old 08-31-2014, 11:23 AM
CeeBoogie's Avatar
I have a sony str dn1040 receiver and would like to know if I can force feed the rgb 16-235 signal type. I have the monitor currently set to auto and when I use my pc the picture is washed out unless I switch it to rgb 16-235. So I'm wondering if there's a way to set the actual receiver to rgb 16-235.
CeeBoogie is offline
post #7044 of 7137 Old 08-31-2014, 12:14 PM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
Originally Posted by CeeBoogie View Post
... if there's a way to set the actual receiver to rgb 16-235.
You have to force at the KRP. That's the "bug". See the FAQ for more information.
bodosom is offline
post #7045 of 7137 Old 08-31-2014, 02:33 PM
CeeBoogie's Avatar
When I set the krp to 16-235 the tv is way off I think? I'll have to wait till I get back home
post #7046 of 7137 Old 09-01-2014, 04:52 AM
umass66's Avatar
Quoted: 54 Post(s)
Liked: 26
can you avoid the bug by setting the blu ray player to 16-235 rgb and the krp-500m to 16-235 rgb
umass66 is offline
post #7047 of 7137 Old 09-01-2014, 06:50 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
Colorspace issues? See the FAQ.
Yes. There are various choices, the optimal one depends on the upstream (stb/player/avr) capabilities.
bodosom is offline
post #7048 of 7137 Old 09-04-2014, 06:53 PM
DCG35holla's Avatar
The bug never seemed to affect me unless I played my PS3, then I had to make sure the PS3 was set to Full or Limited (can't remember which one).
DCG35holla is offline
post #7049 of 7137 Old 09-05-2014, 07:21 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Will the 6020 speakers fit/work on a 600M?
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #7050 of 7137 Old 09-05-2014, 08:35 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
RGB input has two quantization choices. CE (16-235) or IT (0-255). If the quantization bit isn't set the display manufacturer picks one. Typically you'd pick CE if was HDMI, IT if it was VGA and flip a coin if it was DVI. For the 9G monitors Pioneer opted to always select IT. So if both ends are AUTO and the source sends RGB-CE but doesn't set the quant. bit then you get a color-space mismatch and grey blacks.
So don't use AUTO or set the quant. bit when sending RGB-CE and (almost) nobody sets the quant. bit.
The problem is some devices (e.g. DirecTV HR-24) will only send RGB-CE and some devices will only send YUV flavors. I previously dealt with this by having a dual output AVR, by setting one HDMI port to AUTO, the other to RGB-CE and using remote control macros to to match everything up. Currently I have no* RGB only devices so all sources are set to YUV and I only use the AUTO input.
*Okay so that's a lie but just barely.
bodosom is offline
