If you so desire, please continue the discussion here from this part one thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1102574
Originally Posted by jbrady3324 /forum/post/16813900
That is my current set up. With Xbox using RGB/expanded, I have to switch the Kuro to use RGB (16-235) to get the correct black levels. Should this not be the case?
Originally Posted by 5150Joker /forum/post/16810675
Have you mounted yours already? My 500M is still sitting in it's styrofoam box since I'm waiting on my swivel mount to be delivered.Too bad a few vents are blocked off by styrofoam else I'd have started the break in process with the TV still in the box. I did plug it into my comcast HD box today to give it a test run and it looked great! Can't wait to get everything setup.
Originally Posted by jdbimmer /forum/post/16814027
That shouldn't be the case, but... Is the Xbox the only issue with this setup this way? Is it with games or do you have HD-DVD too? If everything else works accept Xbox, try the setting it first to RGB Intermediate. If that's not good, set it to YCbCr 709 too, and leave everything else they way I said earlier.
Originally Posted by jbrady3324 /forum/post/16814078
Yeah the Xbox game seems to be the issue ( not usng hd-dvd ). I have not played a game with the PS3 yet to see if it runs into the same issue. I thought the issue with the KRP is it cannot auto pick up RGB 0-255 signals correctly..
Originally Posted by jdbimmer /forum/post/16814400
That doesn't makes sense as that would mean that the Xbox Expand (0-255) ouput needs a display set to 16-235. Are you positive the XBox is set to Expanded? In any case, Game video levels are not the most stringently followed standards. If all your XBox games look wrong with the Xbox set at RGB Expanded (0-255) and the KRP set to Auto (RGB 0-255), then set the Xbox to YCrBr709 and it should all work.
Originally Posted by expresso712 /forum/post/16814068
what kind of swivel stand did you get ? can you PM the model of the stand etc. - where you got it and how much it cost you ?
thanks
Originally Posted by jbrady3324 /forum/post/16814465
I know it is definitely set for Expanded. Halo 3 and Left 4 Dead both need the Kuro to be set on RGB 16-235. I'll take a look tomorrow. Hopefully I have overlooked something.
Do you own an Xbox?
Originally Posted by 5150Joker /forum/post/16814628
I purchased the Pioneer PDK-1012 swivel stand for $38 off eBay + $25 shipping. The guy was supposed to have shipped it on Monday and it should've been here by now so now I'm hoping it at least gets here by tomorrow.
Originally Posted by thegamer36 /forum/post/16815289
I currently have this mount: http://www.premiermounts.com/product.asp?PartID=1156
Will this mount work with the 600M? Thanks.
Originally Posted by tantowitty /forum/post/16814940
1. I am looking into the KRP-WM02 "Ultra Slim Profile Wall Mount". I'm curious if anyone is using this mount and if so does it allow sufficient air movement for proper cooling.
2. I want to protect my investment so I talked to a few engineer type people at work and one highly recommended buying an 'automatic voltage regulator & surge protector'. ..What are others using to protect their new toy? Thanks!
Howdy... Long time listener second time caller....
I have two questions about my new KRP-500:
1. I am looking into the KRP-WM02 "Ultra Slim Profile Wall Mount". I'm curious if anyone is using this mount and if so does it allow sufficient air movement for proper cooling. Since it is designed by Pioneer I would "assume" they have researched this and it is a non-issue. Any opinions on this? Also the installation instructions show a safety wire used to prevent the display from falling even if it is pulled off the mount. Has anyone installed this backup safety cable? Where did you get the cable and wall hardware?
Originally Posted by abc123puck /forum/post/16815821
yo d-nice, when is the next time your going to be in south Florida for a calibration?
Originally Posted by whityfrd /forum/post/16816864
Did someone kill the m series settings thread? I dont see it anywhere.
Originally Posted by Kimwyn /forum/post/16815675
i was thinking the exact same thing....i want to leave it in the box and run the break in process from there because the wifey would not allow me have a TV just running without be able to fully use it. so cant you run the break in process with the unit still in the styrofoam???
Originally Posted by Phat Ham /forum/post/16817130
yeah i was looking for it since I just got my 600m. It shows up in the google search but when you click on it "no thread specified"
