Panasonic 11G/12G/13G black levels have seemingly doubled overnight? - Page 364 - AVS Forum | Home Theater Discussions And Reviews
 322Likes
post #10891 of 11918 Old 08-25-2013, 10:04 AM
moondog46's Avatar
Brilliant! Thanks for the excellent mini-guide. The only difference on my (US) set is that the cover is oriented vertically, but it popped out easy-peasy once I applied the flathead, so I was able to answer the poll.
This whole thing is quite amazing.
Good going, internet!!
audiodane likes this.
moondog46 is offline
post #10892 of 11918 Old 08-26-2013, 08:39 PM
Lessbones's Avatar
has anyone attempted mironto's method on an S10 model? I was trying last night for quite a while with an arduino and getting no readings from the eeprom. I was using a janky system for my connections to the tv, but given the amount of different ways i tried it, it seems like something should have happened... When the wires were connected up the panel would stay black and the light would blink, but I never saw any info come into the serial monitor.
maybe there should be a separate thread for this kind of issue (or is there already?)
im on a north american model btw...
Lessbones is offline
post #10893 of 11918 Old 08-27-2013, 07:48 AM
mironto's Avatar
Liked: 33
It should be possible to do it on NA S10 as well. What Arduino board do you have? Did you disable internal pull-up resistors prior to hooking up the Arduino to the TV? I would double-check the wiring and maybe get a testbed to test reading/writing from test EEPROM to make sure that there's nothing wrong with the Arduino.
Panasonic plasma black level restoration
Step-by-step guide for restoring the initial MLL on a Panasonic G10 plasma
mironto is offline
post #10894 of 11918 Old 08-27-2013, 07:52 AM
Steve Kuester's Avatar
Quoted: 77 Post(s)
Liked: 108
clktmr (the original poster who reset black levels) had an S10 - although I believe a european model - and mironto had a european G10. I tried it on my north american V10 and it worked. Based on those 3 examples, I would think that it should absolutely work on a north american S10.
I am unfamilliar with a "janky system", but if it is anything like my homemade harness, my first thought is to doubly verify that you have the correct pins on the TV's service connector going to the correct pins on the arduino.
I'm trying to think of anything that could be easily forgotten, all I can think of right now would be to ask if you disabled the internal pull-up resistors in the arduino?
EDIT: looks like mironto just beat me to it.
I turn the sharpness on my TV all the way up, because that's how I like my picture... real sharp.
Steve Kuester is offline
post #10895 of 11918 Old 08-27-2013, 09:27 AM
degobah77's Avatar
Liked: 55
I have an old 50G10 that I'd like to restore if anyone actually makes that shippable mod device...
Boom
degobah77 is offline
post #10896 of 11918 Old 08-28-2013, 04:01 PM
Lessbones's Avatar
I did disable the resistors-- I commented out the indicated lines in twi.c, but I was confused about the rest of this step-- it then says "Save the file, re-compile, and upload the code to the Arduino board." What is being recompiled at this point? I assumed this meant that any open sketch would now use these parameters or something (in my case I had the read_eeprom sketch open as per the tutorial) and you can just re-hit "compile and upload".
I have the same Funduino clone that mironto is using in the tutorial-- so since it is relatively cheap (and maybe the QC isnt very high) I probably should check with the test eeprom. I was just hoping to get away without having to wait for things to show up in the mail... rolleyes.gif
at least I didn't damage the tv
post #10897 of 11918 Old 08-28-2013, 05:21 PM
mironto's Avatar
Liked: 33
You need to exit Arduino IDE before editing the twi.c file. Open the file, comment the lies, save. Then launch Arduino IDE. Open sketch. Compile and upload to Arduino. Connect to TV.
Hopefully this will fix the issue.
mironto is offline
post #10898 of 11918 Old 08-28-2013, 08:22 PM
Lessbones's Avatar
ok great, thanks, will give that a shot.
post #10899 of 11918 Old 08-29-2013, 02:31 AM
Elix's Avatar
Quoted: 223 Post(s)
Liked: 102
@audiodane, I'm in. I have a European GT20 but I believe it's all the same.
Elix is offline
post #10900 of 11918 Old 08-29-2013, 04:14 AM
mironto's Avatar
Liked: 33
Can you check the back of the TV under the black plastic cover, if you ha both A17 (20 pin) & A18 (11 pin) connector, or just the A18 one?
mironto is offline
post #10901 of 11918 Old 08-31-2013, 03:50 AM
bendergender's Avatar
Hello, I have a 46G10, this Arduino is correct for the operation?
http://articulo.mercadolibre.com.ar/MLA-469690577-arduino-uno-rev3-_JM
bendergender is offline
post #10902 of 11918 Old 08-31-2013, 05:05 AM
mironto's Avatar
Liked: 33
Yes, that Arduino is the exact model I used in the guide.
mironto is offline
post #10903 of 11918 Old 08-31-2013, 08:05 AM
Thanks Mironto!
And this?
http://articulo.mercadolibre.com.ar/MLA-470129758-24c64-a24c64-24-c64-24-c64-memoria-eeprom-64-k-bit-dip8-_JM
post #10904 of 11918 Old 08-31-2013, 08:31 AM
mironto's Avatar
Liked: 33
The one you need is M24C64. I don't uderstand the description but I don't think A24C64 speaks I2C.
mironto is offline
post #10905 of 11918 Old 09-06-2013, 09:32 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
Thanks for the feedback Elix!  Working on code right now, actually..  Hope to be debugging first prototype hardware in the coming week.
This really does help greatly if you have a chance to answer that question-  I have limited data on non-US models.  It seems the vast majority have both connectors, and two people so far have indicated that they have A17 only and A18 only.  I may just have to figure out a way to include both connectors.  The trick will be doing it elegantly without over-complicating and over-costing.  I'm actually postponing that decision for now and working on functionality.  "undo" functionality and thinking about selectable reset points.  (in case your set actually does need to be set to the first correction point rather than all the way back a zero.)  I don't have any evidence that this is necessary however, so I'm also wrestling with whether or not to spend time and effort on those features.  Part of me says that should wait for v2.  Part of me thinks people may not be happy if they buy one and 6 months later a newer version exists..  ...
cheers,
..dane
audiodane is offline
post #10906 of 11918 Old 09-11-2013, 10:04 PM
cbgoodbuddy's Avatar
Hi Mironto-- Thanks for your detailed guide, it's great!
Now that you've reset your MLL timer and have had some time to let it change again, can you tell what those EEPROM bits mean now?
Craig
cbgoodbuddy is offline
post #10907 of 11918 Old 09-12-2013, 02:24 AM
mironto's Avatar
Liked: 33
I wish I could decode them but no luck so far. But it's definitely operation hours and on/off cycles stored in those bytes. I already did a second reset and here is what I found out so far:
1st reset at 5264:00 hours:
0x13 0xc5 0x47 0x88 0x11 0x4a
0x11 0x4a = 00010001 01001010 = 4426 on/off cycles
0x13 0xc5 = 00010011 11000101 = 5061 which is close to 5264 h
The remaining bytes 0x47 0x88 must somehow make up those 203 hours (5264 - 5061)
2nd reset at 5346:00 hours (I did not reset the second counter so the actual hours between 1st and 2nd reset = 5346 - 5264 = 82 h):
0x00 0x4a 0x01 0x2c 0x00 0x6c
0x00 0x6c = 00000000 01101100 = 108 on/off cycles
0x00 0x4a = 00000000 01001010 = 74 which is close to 82 h
The remaining bytes 0x01 0x2c must somehow make up those 8 hours (82 - 74)
If any of you will be doing reset, please note the actual hours from service menu and the values read from EEPROM so we can get more data to help decode the algorithm used for storing the hours.
mironto is offline
post #10908 of 11918 Old 09-13-2013, 03:15 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
based on that information alone, here's an absolute stab in the dark (ha!)..
0x13c5 = 5061 hours
0x4788 = 18,312 minutes (or, 305.2 hours)
0x114a = 4426 power cycles
The total hour count would then be 5366.2 hours, close(r) to your 1st estimate.
0x004a = 74 hours
0x012c = 300 minutes (5 hours)
0x006c = 108 power cylces
The total hour count there would be 79 hours, also close(r) to your 2nd estimate.
The question is, how sure are you of your 1st and 2nd hour-count estimates?
IF the middle two bytes are minute counters, then you should be able to re-read your values after even, maybe, 15 minutes, and see the middle two digits changing.  Of course, this is a total guess and I could be absolutely wrong!  :)   It would make sense at least to count minutes, since loosing so many fractional hours over thousands of power cycles could really get any compensation algorithm thrown off pretty bad...
..dane
EDIT- to add:
Alternatively, the middle two bytes could be bit-split..  it only takes 6 bits to count up to 63 (enough to count up to 59 minutes and then reset back to zero).  The remaining 2 bits in the fourth byte could roll into the third byte, as follows:
0x4788 = 0100_0111_1000_1000
six LSbits = 00_1000, or 0x040 = 8min
remaining 10 bits = 0100_0111_10:
padded to 16bit = 0001_0001_1110 = 0x11E = 286 hours
So your two data points would be:
0x13c54788 = 5061hrs + 286hrs + 8min = 5347hrs, 8min
0x004a012c = 74hrs + 4hrs + 44min = 78hrs, 44min
or the reminder 2 bits could stand alone:
0x13c54788
0001_0011_1100_0101_0100_0111_1000_1000
or, regrouped,
0001_0011_1100_0101_0100_0111,10,00_1000
0x13c5,0x47,0x2,0x08
= 5061hrs + 71 hours + 2 hrs + 8 min = 5134hrs, 8min
0x004a012c
0000_0000_0100_1010_0000_0001_0010_1100
or, regrouped,
0000_0000_0100_1010_0000_0001,00,10_1100
0x004a,0x01,0x0,0x2c
= 74hrs + 1hrs + 0hrs + 44min = 75hrs, 44min
Just goes to show that we really need more information.  Being able to watch it "tick" would be great.
But all of this begs the question, do we need to know?  I suppose that all depends on if the anti-aging algorithm is really necessary or not..  And we may need a statistically large sample size to know that. :(
..dane
post #10909 of 11918 Old 09-14-2013, 11:11 AM
mironto's Avatar
Liked: 33
My first reset hours are pretty spot on, might be just a few minutes difference between reading the hours in service menu and reading the EEPROM values. Inthe second reset the difference is also really close, 5 minutes tops.
Sorry to spoil your calculations, but on the first reset I had 5264 hours. 5346 hours were at second reset. Also, it does not make sense to count minutes over 60. How would you then decide, what would be represented in hours counters and what in minutes? This would also make the code too complicated, making some modulo 60 calculations and adding to hours counter. It must be something simple with bit shifting.
One more thing: as I mentioned previously, on my european G10 I never saw any other minute values than 0,15,30, and 45. Maybe this is different on NA models and they show also full minutes? Could somebody with US set read the hours in service menu to check?
mironto is offline
post #10910 of 11918 Old 09-14-2013, 01:02 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
Sorry to spoil your calculations, but on the first reset I had 5264 hours. 5346 hours were at second reset. Also, it does not make sense to count minutes over 60. How would you then decide, what would be represented in hours counters and what in minutes? Thhis would also make the code too complicayed, making somemodulo 60 calculations and adding to hours counter. It must be something simple with bit shifting.
Ha ha ha.. no worries Miro..  I had forgotten about you mentioning the counting in 15minute increments.  That actually makes a lot more sense to be because EEPROMs have finite write cycle limits (usually either 10,000 or 100,000 writes over their life), so storing minute-by-minute would be a bit extreme.  Hysterically, I also forgot that you were reading from the service menu before reading the eeprom values.  It's obvious now that I had no idea was I was talking about.
In a week or two when I hook back up to my TV, I'll try to remember to make some successive measurements.
sorry to have gone so far into left field with my last post..
..dane
post #10911 of 11918 Old 09-14-2013, 02:35 PM
mironto's Avatar
Liked: 33
I am not sure about those writes but I guess they are plenty for the life of the pannel. I think it was clktr who mentioned that he had the I2C master connected to the TV while operational and he saw the bits changing as seonds passed. I guess it does not matter after all, my guess is you could store any bits on those addresses and TV would figure out what the hours are as long as the number is high enough to trigger the rise.
mironto is offline
post #10912 of 11918 Old 09-16-2013, 11:14 AM
Elix's Avatar
Quoted: 223 Post(s)
Liked: 102
Elix is offline
post #10913 of 11918 Old 09-16-2013, 03:48 PM
mironto's Avatar
Liked: 33
Looks like you will probably have to take off the back panel to get to the service connector (if it is not located elsewhere on G20 model).
mironto is offline
post #10914 of 11918 Old 09-17-2013, 11:16 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
Huh. Well times have changed.  At least on the M24C64, the write cycles have been bumped all the way up to 4 million.  I had no idea they'd gotten that good.
I'm not positive this is the same model, but avforums had the following picture posted on one of their threads..  It looks like there may be a plastic rectangle in the upper right region of the picture?  That may be a service port?  If anybody has a service manual for the gt20 we could find out where they are pretty easily.
..dane
post #10915 of 11918 Old 09-18-2013, 11:04 AM
tomwil's Avatar
Liked: 26
Would this service manual help?
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #10916 of 11918 Old 09-22-2013, 02:48 PM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
Audiodane.....any updates on your endeavor? I am jonesin' for one!!
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Wave Crest Audio HVL-1 (L/C/R), Pioneer SP-BS 22 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #10917 of 11918 Old 09-24-2013, 12:17 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
Yes, thanks!  Taking a quick glance, on the GT20B model a least, A17 and A18 have been renamed CN0101 and CN0102.  They're located in the top-right region of the A-board, as shown in the two diagrams (taken from the service manual).  One diagram indicates where the A board is in relation to the back of the TV, and the other is a diagram indicating where on the A-board the two connectors are located.  I think, looking at our previous images a few posts back, that the little black rectangle is in the right location to be concealing the access to these connectors.
Thanks Gov! Are you checking my site (see link in sig line)?  I was on a business trip all last week.. The conference went fantastic, but I didn't have a single chance to work on the PMCv1.  I got most of the internal flash storage technique working on Sunday night though.  the I2C communication has a bug, it works in debug mode, but not in full speed mode.  I'm pretty sure what I need to fix, and I've got that on my list to do next. Wait, this should all be going on my site..  :)
Anyways, things are still moving along.  I had hoped to give myself a month, and have really tried hard to keep that, but it may slip some.  Life tends to do that when it's a side project. My wife doesn't want it dragging on forever though (neither do I), so I'm trying to get at least some work done every week.
I'll post another update later this week.  It's a busy work week though, so it may be later than sooner. But progress is being made.
cheers,
..dane
anthrojohn and whipit like this.
post #10918 of 11918 Old 09-24-2013, 02:40 PM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
Thanks Gov! Are you checking my site (see link in sig line)?  I was on a business trip all last week.. The conference went fantastic, but I didn't have a single chance to work on the PMCv1.  I got most of the internal flash storage technique working on Sunday night though.  the I2C communication has a bug, it works in debug mode, but not in full speed mode.  I'm pretty sure what I need to fix, and I've got that on my list to do next. Wait, this should all be going on my site..  smile.gif
cheers,
..dane
Thanks! I will keep checking your site. Glad to hear things are still going well biggrin.gif
Gov is offline
post #10919 of 11918 Old 10-04-2013, 11:54 PM
audiodane's Avatar
Quoted: 113 Post(s)
Liked: 70
Well I'm officially reliably reading data from the TV directly after power-up.  I'll update my site next week with a full update because I'm going to be working on it more over the weekend. Here's the most recent values I read tonight:
0x177B 0x7E90 0x12DA
However, the service menu indicates the following:
Time: 6027:0 Count 4844
In Hex, 6027 is not 177B but rather 178B.
In Hex, 4844 is not 12DA but rather 12EC.
Hours count is off by 16 hours, the middle bits may account for some of that (don't know yet).
The power cycle count however is also off by 18 cycles, which is interesting.
Did I read somewhere that the hours and power cycle counts reported in the service menu are not from the panel eeprom but rather somewhere else (peaks, perhaps)?  Maybe that accounts for the difference.
Well, it's late, and we have a lot going on tomorrow.  So this will have to do for now.
cheers,
..dane
Gov likes this.
post #10920 of 11918 Old 10-05-2013, 12:19 AM
Gov
Gov's Avatar
Quoted: 117 Post(s)
Liked: 183
cheers,
..dane
Looking forward to more of your findings! When you get it right and begin to build them for sale, put me down for the first one!!! biggrin.gif
Gov is offline
