Panasonic 11G/12G/13G black levels have seemingly doubled overnight? - Page 373 - AVS Forum | Home Theater Discussions And Reviews
 337Likes
post #11161 of 11930 Old 04-16-2014, 05:02 PM
Rooster56077's Avatar
Dane, I have been watching and waiting...I'm in.   My G10 is ready for a makeover
Rooster56077 is offline
post #11162 of 11930 Old 04-16-2014, 07:05 PM
eaayoung's Avatar
Quoted: 212 Post(s)
Liked: 135
I couldn't have said it better. So is my V10.
eaayoung is offline
post #11163 of 11930 Old 04-17-2014, 05:10 AM
Dakotah's Avatar
I'm in as well. No idea what hours I have on my 54V10...but I'm sure it's well above 2000. I'd love to see a return to my original black-levels.
Dakotah is offline
post #11164 of 11930 Old 04-26-2014, 10:27 AM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
Can anyone help determine how to read hours and count on a g25? It says,
Time 50432.20
Count 0000113
Ive got some stuff
baron2 is offline
post #11165 of 11930 Old 04-26-2014, 11:21 AM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
Time 50432.20
Count 0000113
Time is the hours:minutes
Count is how many times it was turned on
whipit is offline
post #11166 of 11930 Old 04-26-2014, 11:48 AM
mironto's Avatar
Liked: 33
Unless you own a time machine, it's impossible to clock 50,000 hours on a set from 2010 wink.gif
Panasonic plasma black level restoration
Step-by-step guide for restoring the initial MLL on a Panasonic G10 plasma
mironto is offline
post #11167 of 11930 Old 04-26-2014, 12:04 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
True, his numbers must be off.
http://www.controlcal.com/forum/showthread.php?t=1006
whipit is offline
post #11168 of 11930 Old 04-26-2014, 01:16 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
By reading the time I thought 50432.20 meant 504 hours 32 minutes and 20 seconds. Looking at the count 0000113 thought that meant it was powered on 113 times.
Ive got some stuff
baron2 is offline
post #11169 of 11930 Old 04-26-2014, 01:21 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
Processed By eBay with ImageMagick, z1.1.0. ||B2
By looking at this how would you interpit how many hours are on this display and how many times has it been turned on?
Appreciate any help.
Ive got some stuff
baron2 is offline
post #11170 of 11930 Old 04-26-2014, 03:25 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
Here's a pic I just took of my 54G10 I bought in December of 2009. It was used daily until October 2013 when I got the VT60. It's showing 10595 hours zero minutes and 2281 times turned on.
baron2 likes this.
whipit is offline
post #11171 of 11930 Old 04-26-2014, 03:46 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
There was a limited period back then when it was required to divide the time by 256. I think is was for some of the 2009 and 2010 models. Check it out.
Larry
LarryInRI is offline
post #11172 of 11930 Old 04-26-2014, 04:23 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
I know its not 50k hours on it because even if it ran 24 hours a day for now 4 years straight since its an April 2010 build it could at the most have 35040 hours on it.. I took the 50432 and divided by 256 and came up with 197 hours. That would mean with the count at 115 the display was being turned on every 1.7 hours. The reason for my questions is Im thinking about purchasing this 54g25. I do appreciate the help guys.
Ive got some stuff
baron2 is offline
post #11173 of 11930 Old 04-28-2014, 12:46 PM
flycaster's Avatar
I would also like to get the black level improver but don't know how to sign up for it. Also, how does one use it, where does it attach to and how is it read?
flycaster is offline
post #11174 of 11930 Old 04-28-2014, 01:02 PM
mironto's Avatar
Liked: 33
197 hours/115 on/off cycles seem normal. I had some 5200 hours with 4400 on/off cycles.
baron2 likes this.
mironto is offline
post #11175 of 11930 Old 05-01-2014, 01:57 AM
Meisaku's Avatar
Just reset my European 65VT20E using the mironto's guide (Thanks - you Rock!). The 2010 service port connector proved to be too tiny for my fingers, but a trip to the local tv repairer and a 10 euros turned the parts into a working service cable - rest was easy enough for an electronics newbie to pull through.
My ex-demo machine has some 3500h+ on the meter, so it certainly had risen to noticeable levels of greyness. Will have to wait for night to appreciate the difference to the fullest (damn you sunshine wink.gif) but already it's looking sweet.
whipit likes this.
Meisaku is offline
post #11176 of 11930 Old 05-05-2014, 07:38 AM
Alastair E's Avatar
Not a good advertisement for Panasonic Plasmas this designed in 'fault' is it!
Here's the issue I have--Or not--as the case may be.
I'm wondering IF there's another way of doing this 'reset' as I have an old 10th gen. TH-42PZ70B. This set has exceptionally black-blacks--and is an Old set by its obvious dusty condition internally and its age, dated 2008 on a paper label internally.
--I took this set as sorta part-ex, it was faulty, so I repaired it.
I was impressed with the picture, so have kept this one for myself, replacing an old LG 720P I was using.
As I said--The blacks are VERY black, not displaying the pretty obvious issues other Pan. owners--even the earlier 10th gen sets appear to have. I also have a 42PX80, that defo has this issue--even though that set is still faulty in other ways, so cant access the SVC on that set--another long story on that one!
Here's the thing--
On Checking The Time Of Use in the SVC Menu of the 42PZ70B--even after 'factory-reset' etc.--The Time is not there--The Box Is Empty--Nothing is displayed in that box where the time should be--and Ive followed all the procedures to access many times and different ways, not forgetting the--'press mute for more than 3 seconds' etc, Nothing comes up!
--It hasn't even recorded the SOS-10 (Ten Red-Blink Of Death) issue it had, that I repaired, listing lots of -- 00. 00. 00. etc, instead of the log of that fault........
Maybe someone's 'got-at' this set before, done something to stop the time-count--and the panel age MLL function.....
I dunno, set works brilliantly anyway......
Alastair E is offline
post #11177 of 11930 Old 05-05-2014, 01:12 PM
Chia5's Avatar
Any news on the reset widget?
Chia5 is offline
post #11178 of 11930 Old 05-05-2014, 09:46 PM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
You can signup for email notifications on the PMCv1 website. Those subscribed will get an update mid-day tomorrow.. :)
Yes. :) See the links above (also in the signature line below) ..
..dane
audiodane is offline
post #11179 of 11930 Old 05-06-2014, 01:11 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Originally Posted by audiodane View Post
You can signup for email notifications on the PMCv1 website.  Those subscribed will get an update mid-day tomorrow..  smile.gif   Or you can go there now (to the development blog)..
Yes.  smile.gif   See the links above (also in the signature line below) ..
..dane
StinDaWg is offline
post #11180 of 11930 Old 05-07-2014, 03:49 AM
moondog46's Avatar
moondog46 is offline
post #11181 of 11930 Old 05-07-2014, 05:17 AM
flycaster's Avatar
Would appreciate if someone could tell me how the widget wiring will attach to the TV. Where will the wiring go?
post #11182 of 11930 Old 05-07-2014, 05:29 AM
Vader424242's Avatar
Quoted: 79 Post(s)
Liked: 68
Originally Posted by moondog46 View Post
I could not agree more. Again, thank you dane for your efforts and expertise. I would rather you take your time and do it right than to rush it.
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #11183 of 11930 Old 05-07-2014, 07:38 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
The back of the set has a service connection. Yours is mostly likely still being covered by a piece of black plastic. Look for it near all the video inputs.
You can see where mine is in this picture (where the purple wires are connected). Dane is making a dedicated connector that snaps right on to the board's headers as opposed to my make shift wire solution:
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #11184 of 11930 Old 05-07-2014, 08:17 AM
flycaster's Avatar
Thanks. Now I definitely am glad that I signed up for the widget as it will be so easy to use...
post #11185 of 11930 Old 05-07-2014, 10:25 AM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
Originally Posted by StinDaWg View Post
For a completely self-contained, plug-in-and-forget-it module, yes.  No need to wait though, Mironto has an absolutely fantastic DIY guide on his site that *many* people around the world have already been using since last fall (summer?).  He's a super fantastic guy and is very responsive if you need help.  At one time he was even mailing out his spare connectors and parts for free.
Thanks Vader.  And you're right -- I had the embedded software done in October of last year. Then I saw there was enough demand that drove me to skip the hack-up job I had originally planned (and from which my prototype was created) and move to a custom PCB design (that I'm also doing myself). And then came the fateful day when it was pointed out that very FEW sets had 3.3V (most all seem to use 5V) and had to completely rethink the power hookups.. :(  All of that and more in only 1-evening per week after work.. (I still have to pay the bills)  *I'm* of course still upset that I didn't have it done before Thanksgiving.  But as you say, better late than never, I suppose.. :(
Thanks flycaster- you nailed it on the head -- Easy to use.  No electronics experience required.  Simple Green/Red lights to show that it's working (or not).  "Plug and play." :)
cheers,
..dane
post #11186 of 11930 Old 05-12-2014, 05:54 PM
Quoted: 650 Post(s)
Liked: 432
I originally blasted my tv this past October. It started looking a bit off to me so I just performed the reset again. I took these before and after shots. its such a difference I wish id have done more on actual movie images. it was much more obvious on my camera than it is now on my properly calibrated tv smile.gif
post #11187 of 11930 Old 06-05-2014, 06:01 AM
Alex Raposo's Avatar
Any update Dane?
Alex Raposo is offline
post #11188 of 11930 Old 06-16-2014, 07:44 PM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
Originally Posted by Alex Raposo View Post
Any update Dane?
Just posted an update on the site tonight. Initial order for 100pcs placed today. Should arrive ready-for-testing in about mid-July. Will be a busy time with several work and non-work trips planned for late summer, but I will try as always to get it done as quickly as I can. Website is almost ready to accept orders. Paypal account is setup and "buy now" buttons are ready. Just waiting for the units to arrive now and start playing with them to enable purchases.
We're closer than ever.
..dane
djbrettb likes this.
post #11189 of 11930 Old 06-16-2014, 08:51 PM
djbrettb's Avatar
Just signed in to say you da man, Dane! Can't wait to order mine!
djbrettb is offline
post #11190 of 11930 Old 06-17-2014, 06:03 AM
Awesome Dane! Can't wait!!!!!
