Panasonic 11G/12G/13G black levels have seemingly doubled overnight? - Page 381 - AVS Forum
 67Likes
post #11401 of 11410 Old 10-20-2014, 05:06 AM
pittsoccer33's Avatar
Quoted: 104 Post(s)
Liked: 208
I did my last reset in May (when 24 came back) and did one again last night before firing up Universal's The Mummy bluray.
I definitely did have a slight rise since then, as my tv is on at least 2 hours per day. I looked at my test patterns before and after connecting my Arduino and the levels were right where I would expect them to be. I couldn't see anything below 16 flashing black and anything above 235 flashing white. The ramps looked ok as did color gradiations.
My HTPC front end set up
Integration for whole home ATSC, CableCARD, FM radio, Blu-Ray, HD-DVD, DVD, VHS control & capture, video games, and archived & streaming media playback
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
post #11402 of 11410 Old 10-20-2014, 01:15 PM
Steve Kuester's Avatar
Liked: 25
Just want to say congrats, Dane. Its great that you were able to get this out to everyone. I didn't buy as I was the guinea pig that tried Mironto's guide on my set. But if I was unwilling to do it myself, I would have ordered from you on the first day. Nice work.
If anyone is iffy about any long term effects of the reset on their TV, I'll reiterate what I mentioned on this thread a couple months ago... I did the reset over 1 year ago on my 54V10 and have had absolutely zero issues with my set since then.
eaayoung and audiodane like this.
I turn the sharpness on my TV all the way up, because that's how I like my picture... real sharp.
Steve Kuester is offline
post #11403 of 11410 Old 10-20-2014, 06:46 PM
audiodane's Avatar
Quoted: 16 Post(s)
Liked: 50
So I've been trying to keep up with incoming links to the site (that's how I found out about the international articles about the PMCv1), but it seems all of the sudden I'm getting a lot of hits from what looks like twitter shortened urls... Wish I could find out from whom so I could thank them!
Down to about 25% of my original stock.. Depending on how long it takes for the last pieces to sell, I may have to decide how many more to make.. A good problem, but still a problem (it will probably be 8-12 week lead time for additional units to keep costs down).
..dane
audiodane is offline
post #11404 of 11410 Old Yesterday, 06:22 PM
globalgreg's Avatar
Just installed the PMCv1. Before I installed it my usage read 4,242 hours with 4,189 cycles. After installing I got the blinking green light and then power cycled one more time and the TV came on. Checked the usage again after installation and it didn't go back to zero. That normal?
globalgreg is offline
post #11405 of 11410 Old Yesterday, 07:02 PM
zhe zhang's Avatar
audiodane said that the ON time clock we can access from Vol-,info.. is not being reset by this circuit.
zhe zhang is offline
post #11406 of 11410 Old Yesterday, 08:44 PM
Champ77's Avatar
This is correct. I've used Mironto's Arduino process to reset my TV and it resets the MLL clock (it works).
I am based in Australia and have purchased the PMCv1 for my (2008) TH-65PZ850A as I prefer the process to be automated to reset the MLL clock.
This reset does not reset the clock and counter you see in the service menu and pretty much has nothing to do with it. It only resets the MLL (Black Level) Clock/Timer whatever you want to call it.
I have found a way that you can reset the clock and counter in the service menu. The HEX details are located in the Memory Editor (It's located in the EEPROM (Peaks)) in Line 6E8. I don't know about other models, but this is where it is on mine.
You can reset the last 6 values to 00. The clock and counter (how many times the TV has been switched on for) will now be reset to 0.
I have also tried resetting the first 2 values to 00, but it does nothing.
So basically you can reset the MLL clock and the Service menu clock and counter and you can have a new TV! LOL!
Don't mess with the service menu settings though, if you do you can screw the TV up, if you do then I take no responsibility. Should you proceed, then make sure you take a photo of the values before you change it.
As on another model, especially if it's in another country as well, the values could be on another line.
I've attached a file for your reference.
Name:	Service Clock & Counter Reset.jpg
Champ77 is online now
post #11407 of 11410 Old Yesterday, 11:17 PM
Liked: 1
Has anyone used this setting -forced to factory shipment setting-pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds in TV reception screen after PMCv1 black level restored?I am wondering if this procedure reset the clock and counter we see in the service menu and doesn't need to HEX editing EEPROM.
luis67 is offline
post #11408 of 11410 Old Yesterday, 11:29 PM
zhe zhang's Avatar
That clock and counter are not reset. The question was raised and answered a couple of times:
Post numbers:
11338-11339-11340
11404-11405-11406
Originally Posted by luis67 View Post
Has anyone forced to factory shipment setting pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds after PMCv1 black level restored?I am wondering if this procedure reset the clock and counter we see in the service menu and doesn't need to HEX editing EEPROM.
post #11409 of 11410 Old Today, 01:03 AM
Champ77's Avatar
Just to confirm what I posted before about the clock and counter reset.
Pics are attached.
It's been this amount of time since I did the reset with the Arduino, 135hrs.
I didn't do a reset of the MLL this time as I'm waiting for Audiodane's device.
The attachments uploaded in the wrong order. Just work your way from the last one to the first one to see.
ID:	324161   Click image for larger version
ID:	324169   Click image for larger version
ID:	324177   Click image for larger version
ID:	324185   Click image for larger version
post #11410 of 11410 Old Today, 04:55 AM
audiodane's Avatar
Quoted: 16 Post(s)
Liked: 50
I have added this question to the PMCv1 product page FAQ, since it seems to continue to confuse people:
The “service menu” and “service connector” are two very different things. The on-screen service menu (accessible by several button combinations while the TV is on) does contain an hours counter and a cycles counter (how many times the TV has been turned on), however neither of these counters affect MLL/Black Level. The counters that affect MLL/Black level are on a different area of the TV and are not accessible through the on-screen service menu.
There is no need to reset the counters in the on-screen service menu, as it has been proven to be ineffective at reducing MLL/Black Level. I rather suggest you leave it alone and it will continue to give an accurate indication of the ‘true’ age of the TV, while the PMCv1 is quietly maintaining your inky blacks behind-the-scenes.
cheers,
..dane
User Tag List
