Chad B's TV rankings - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #481 of 536 Old 03-22-2011, 10:43 AM
rpauls's Avatar
Originally Posted by pneumatic View Post
That is the total opposite of what I found on the 58C7000. Gray ramps showed ZERO banding on mine. Even the scrolling gray ramp moving across the screen did not have any banding. Maybe the 6500 is different in that regard?
Neither the LG or the C6500 show any banding on the standard gray ramp test patterns that go all the way from 0 to 255 across the screen. That ramp covers too much range to expose the banding. In fact, that ramp is pretty much useless as a diagnostic pattern in my experience, at least for any modern display.
You need a more gradually changing gradient to expose the differences. You might find such a pattern in a movie, for example, if there is a uniform wall in the background with a dark subtle shift in luminance from right to left. Then the bands will be evident on the Samsung, and the big ugly dithers on the LG.
rpauls is offline
post #482 of 536 Old 03-22-2011, 03:02 PM
Turrican4D's Avatar
Quoted: 739 Post(s)
Liked: 433
@rpauls
Do you have "Blade Runner" at Blu-ray-Disc or HD DVD at home?
I think, I knew, the transfer had banding besides the ugly DNR, but now I'm not so sure, that it isn' the LG-Plasmas fault.
I was able to get rid of the banding at Decker's door when Rachel visits him the first time, but I have still bandings in fires, lamps, skies and the dust in thy sky in the opening sequences, also the light/dust in Sebastian's house right after Decker kiled Daryl Hannah.
EDIT: And btw, I got banding with my first calibrationexperiences with the 20point-calibration in the 256 AVS709-greypattern, so it is "possible" to get banding even there.
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #483 of 536 Old 03-22-2011, 04:43 PM
Dathon's Avatar
The Blade Runner Blu-ray disc is one of the most impressive transfers I've seen. I have the full blu-ray collection. It doesn't have any banding on my Plasma that I've seen. If you have banding problems, more likely it is a setup issue or limitation with your equipment.
Dathon is offline
post #484 of 536 Old 03-22-2011, 06:05 PM
Turrican4D's Avatar
Quoted: 739 Post(s)
Liked: 433
I mean the Final Cut, that is plagued with lots of DNR and a medicore bitrate of only 17Mbs.
I would be happy, if you could check dust, fires in the opening sequence and lighthalos in Deckards appartement and Leo's room for banding.
post #485 of 536 Old 03-23-2011, 07:07 AM
rpauls's Avatar
So there are two versions of Blade Runner on BR? 17Mbps does seem to be too low. Aren't they usually in the 25-35Mbps range?
rpauls is offline
post #486 of 536 Old 03-23-2011, 12:36 PM
Turrican4D's Avatar
Quoted: 739 Post(s)
Liked: 433
http://www.dvdbeaver.com/film/DVDRev...laderunner.htm
There are even drops down to 12Mbps. Singlelayer-BD.
And the banding is indeed in the transfer-> http://www.dvdbeaver.com/film3/blu-r...blu-ray_1x.jpg
post #487 of 536 Old 03-30-2011, 05:34 PM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Minor update: took 2 points from LG 55LHX for the dirty screen effect issue.
Also updated the review index to include the latest 2011 reviews and the Swans loudspeaker review.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #488 of 536 Old 04-20-2011, 03:32 PM
JackOften's Avatar
Quoted: 14 Post(s)
Originally Posted by Chad B View Post
I am hoping to have a review of the 60PZ550 posted in the next few days, a week at the latest.
I only used 2D mode. The set was fresh out of the box. The owner is local, so we wanted to go back after a few months and see if there was a significant change from the break in process.
Really looking forward to this review Chad! Bring it out already
JackOften is offline
post #489 of 536 Old 04-21-2011, 02:16 AM
Nodnarbles's Avatar
I too would love to hear your findings on the pz550 series...
Nodnarbles is offline
post #490 of 536 Old 04-21-2011, 02:54 AM
realzven's Avatar
Liked: 84
+1
realzven is offline
post #491 of 536 Old 05-24-2011, 07:40 PM
Mauri's Avatar
Originally Posted by rpauls View Post
Too bad the manual is In German. I would love to learn more about this, and exactly what these adjustments are doing. VY and VA sound like voltage adjustments, but I have never heard of pots called set_up and set_dn.
Can you tell me a little more about what each adjustment does? Do all 4 affect MLL? Any way to translate that manual? Electronic form or paper?
All the documentation is available in U.S. english
This is the complete LG plasma Panel Alignment Book (quick reference), latest version (03/31/2011): http://136.166.4.200/contents/Displa...t_Handbook.pdf
LG U.S. got the explanations from the complete Training Manuals of many plasma models, and they have arranged that book. Read it carefully before start to do something. If you have never done such things before, it is better to have a look for an expert TV tech friend. The right way to arrange the tuning work, is to use a big mirror. Put the TV screen in front of the mirror and look at the mirror during tuning. Use only full plastic screwdrivers (easy available and very cheap) and remember that there could be high voltages on some circuits, so be careful. It is like to work on tube amps, you know? Only a bit more difficult because you are working on big screens, and that's the reason why you need to use a mirror (for safety reasons, at first).
For many plasma models, complete informations and training manuals (very useful) are also available. On this page there is the list: http://136.166.4.200/SubPages/Directview_PDP.htm
clic on the model you are interesting for, and on the left of the new page you will find the docs available for download. There is even the new 50PZ950 and PV450 models, as well as the PK950 and 750.
With such informations available, I think LG plasma are well worth a look. I'm going to buy a 60PK980 (same of 60PK950) during the next days. Now it has a very good price in my Country (1170 euro including shipping) and it is the right time to buy it. I'm not interesting in the actual 3D stuff.
'sorry for my bad english, and best regards from Italy
Mauri
Mauri is offline
post #492 of 536 Old 05-24-2011, 07:45 PM
Mauri's Avatar
Chad,
in case you are interesting, here is the same stuff for some LG LCDs: http://136.166.4.200/SubPages/Directview_LCD.htm
Mauri is offline
post #493 of 536 Old 05-25-2011, 02:25 AM
leftyguitar1963's Avatar
Quoted: 127 Post(s)
Liked: 172
Mauri
I don't see my 2010 PX950 model in any of the pdf documents from this link?
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
leftyguitar1963 is offline
post #494 of 536 Old 05-25-2011, 03:04 AM
Mauri's Avatar
For the panels alignment, the boards of the PX950 should be the same of the PK950 model. The procedure is always the same and the voltages are present on the label of each individual plasma panel, as explained in the Panel Alignment Book. Take a look at the PK950 procedure, and you'll understand how it works.
The pages of that web site will be updated, as well as the docs.
BTW, I don't think this is the right thread to continue to speak about this things. But I don't know what thread could be the right one
Mauri is offline
post #495 of 536 Old 05-25-2011, 05:44 AM
AVS Fanboy's Avatar
dear chad B, did u review the samsung plasma d550 or planning to review that? (if yes,plz give me a link)....i'm very new to this forum & this is my first post... if u can guide me in this,i will feel much thankful!
AVS Fanboy is offline
post #496 of 536 Old 05-25-2011, 06:30 AM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Chad,
Thanks Mauri, I appreciate the info!
Chad B is offline
post #497 of 536 Old 05-25-2011, 06:41 AM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
I haven't had the opportunity yet.
Chad B is offline
post #498 of 536 Old 05-25-2011, 06:46 AM
rpauls's Avatar
Mauri
Thanks for this info!
I don't see the LG 60PK550 listed, but I do see the 60PK750. Is that the closest match to the 550? Are there any significant differences?
rpauls is offline
post #499 of 536 Old 05-25-2011, 07:04 AM
Mauri's Avatar
The 50-60PK550 are listed in the LG plasma Panel Alignment Book (first link I gave you before).
Mauri is offline
post #500 of 536 Old 05-25-2011, 07:18 AM
BillP's Avatar
Quoted: 275 Post(s)
Liked: 219
Chad, maybe I'm doing something wrong, but the link to your overall table of all displays reviewed is missing from your signature (I can only link to your 3 most recent reviews).
BillP is offline
post #501 of 536 Old 05-25-2011, 07:25 AM
AVS Fanboy's Avatar
are u looking forward to it?...if yes, any time soon?
post #502 of 536 Old 05-25-2011, 09:06 AM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Thanks, I fixed it.
Chad B is offline
post #503 of 536 Old 05-25-2011, 09:08 AM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
I would be happy to, but I don't know very far in advance what I will have the opportunity to review.
Chad B is offline
post #504 of 536 Old 09-12-2011, 10:14 AM
Falcons023's Avatar
Quoted: 12 Post(s)
Are there any updates in your rankings?
Falcons023 is offline
post #505 of 536 Old 09-23-2011, 04:46 PM
TIMMAYY's Avatar
Please update your picture quality chart when you have time. I'm interested in seeing how the latest models you've reviewed stack up against the others. Thanks.
TIMMAYY is offline
post #506 of 536 Old 09-23-2011, 11:15 PM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Thanks. I have another busy week on my calibration tour, then I have to meet with my friend/web guy to be trained on how to update my new webpage. Hopefully soon after that.
Chad B is offline
post #507 of 536 Old 07-23-2014, 11:10 PM - Thread Starter
Chad B's Avatar
Quoted: 544 Post(s)
Liked: 1309
Updated!
After a few years of neglect, I've finally updated the rankings with all the latest models I've reviewed. I made a couple other changes, deleting the 24P bonus point, merging the depth and shadow detail categories since they are both primarily determined by gamma, and changing the MLL category to black uniformity and neutrality.
The rankings are still at the bottom of the page following the review links, which I still need to update.
eric3316 likes this.
Chad B is offline
post #508 of 536 Old 07-24-2014, 01:11 AM
Dianabol5mg's Avatar
Quoted: 353 Post(s)
Liked: 272
Thanks for this, Chad. It's about dang time!!
It's funny how a lot of the LHX owners have a F8500(ranked next to each other). Would have gotten a VT also, but missed the boat. Oh well, OLED time in October. Thanks, again!
Dianabol5mg is offline
post #509 of 536 Old 07-24-2014, 03:22 AM
chunon's Avatar
Quoted: 2444 Post(s)
Liked: 2195
Thanks Chad !!
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #510 of 536 Old 07-24-2014, 04:43 AM
Quoted: 1631 Post(s)
Liked: 693
Chad,
Link on that website for the 64F8500 doesn't take you to your review. Probably has something to do with the forum software being changed.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
