Free KuroReader Software for Pioneer KRP-500M, KRP-600M, PRO-101FD, PRO-141FD - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 119 Old 02-07-2010, 10:46 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
^In that case the Pioneer has to be something other than 192.168.1.1. Which kind of makes sense since the message you got from KuroReader was "target machine..actively refused" which would be the response you would get from a PC or router for port 4201.
jdbimmer is offline
post #92 of 119 Old 02-08-2010, 12:14 AM
spongebob's Avatar
Quoted: 38 Post(s)
Just plugged the net cable back in. Same IP.
I'll try to power off the main power switch tomorrow.
BTW, I just remembered that I plugged the Pio directly in to my laptop before I went to buy the long net cable. Could that have caused the wrong IP?
Good night!
bob
spongebob is offline
post #93 of 119 Old 02-08-2010, 05:00 AM
switch42's Avatar
Good night!
bob
If you plug the Ethernet cable directly into your laptop from the TV you need to have a direct connect Ethernet cable. That type of cable has to have these color combos..
1)white green
2)green
3)white orange
4)blue
5)white blue
6)orange
7)white brown
8)brown
1)white orange
2)orange
3)white green
4) blue
5)white blue
6)green
7) white brown
8) brown
On a standard cable (one that would go from a device to a router or a switch) both ends will have the same pin-out.
switch42 is offline
post #94 of 119 Old 02-08-2010, 05:55 AM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
Good idea. And check that DHCP in still "On" in the Pioneer's Control menu, then wait a few minutes after you power off/on before checking the Pioneer's IP Address - DHCP takes a little time to request and assign an IP.
Not if DHCP was enabled. In that case you would get a private IP Address (assuming that your laptop supports Auto-Xover). See Method #2 in Post #41 of this thread.
jdbimmer is offline
post #95 of 119 Old 02-08-2010, 07:44 AM
spongebob's Avatar
Quoted: 38 Post(s)
Good news!
Powered off/on; Now I'm192.168.1.5
bob
post #96 of 119 Old 02-21-2010, 07:34 PM
Evangelo2's Avatar
I can't get it to connect and I have the right IP address for sure...
Is there anything special that needs to be done? My tv is not ISF calibrated yet so none of those modes are unlocked.
-Evangelo2
Evangelo2 is offline
post #97 of 119 Old 02-21-2010, 08:08 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
-Evangelo2
it won't work with a 151
jdbimmer is offline
post #98 of 119 Old 02-26-2010, 08:47 AM
ridler's Avatar
This Sw is really great! Nice job!!
Maybe you can help me with this. I have a HTPC on my 500M. My idea was that after a wake-up of the PC to send out a command on the LAN to switch on the 500M.
Would that be possible with a single html command?
ridler is offline
post #99 of 119 Old 02-26-2010, 11:02 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
If you can call another program from your HTPC application a batch script using netcat might work. Something like:
Code:
type  | nc
Alternatively you could use WSH or make the jump to ActivePerl (or something similar).
bodosom is offline
post #100 of 119 Old 03-01-2010, 04:31 AM
ridler's Avatar
Thanks for your answer!
Would be no problem to launch a script on my HTPC. I can easily insert all action on start-up / Wake-up with Eventghost.
How would the Power-on Skript need to look like?
ridler is offline
post #101 of 119 Old 03-01-2010, 09:41 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
The example above, using netcat, is close to a .bat file (i.e. it might work). That's the limit of my Windows skill-set.
bodosom is offline
post #102 of 119 Old 03-05-2010, 11:40 AM
GmanAVS's Avatar
Apologies in advance for the semi-wasted bandwith, I am desperately looking for a reasonably priced NIB KRP-500M and posting on a couple of pertinent threads...... yeah BB has the 101FDs on sale but they are still $1k out of my reach.
Please PM me if you have a lead, ty!
Gman
GmanAVS is offline
post #103 of 119 Old 04-09-2010, 11:48 PM
TheaterLover's Avatar
[quote=jdbimmer;17126290]
1. A simple solution is a wireless "gaming" type adapter or multifunction device that provides a non-WDS Ethernet-to-Wireless adapter mode. Of these, the most promising and inexpensive solution that I have seen is the Asus 330gE. In Ethernet Adapter mode, this small device provides wireless connectivity to your existing wireless network and one Ethernet port to connect to your Kuro. The advantages are its small size and easy configuration. The disadvantage is that it does not have additional Ethernet ports for other devices (e.g., your Blu-Ray player or AV Receiver) .
I am trying this method to get my KURO on the home network but I am not able to connect my browser to my monitor. The KURO is getting a valid IP address.
TheaterLover is offline
post #104 of 119 Old 04-10-2010, 07:09 AM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
Can you provide some more information on how you configured the 330gE and the Pioneer?
The first thing you need to do is connect the 330gE to an ethernet port of a PC, access it using the Asus utility or via 198.168.1.220 from a browser, and select the Ethernet Adapter mode tab. From that tab you need to connect to your wireless network and enter any security password required for WEP, etc. If everything is setup correctly, you should be able to access your wireless network (internet etc) from that PC. Once you confirm that the 330gE works on your PC, connect it to your Pioneer, enable IP Control and DHCP, wait for it to obtain an IP address, and try to connect to that address using KuroReader or IE.
jdbimmer is offline
post #105 of 119 Old 05-18-2010, 05:16 PM
Megalith's Avatar
Quoted: 20 Post(s)
WTF? I tried enabling the ISF modes and now my set is stuck on Pure and it's greyed out. I'm unable to move to other picture settings.
Megalith is offline
post #106 of 119 Old 05-18-2010, 05:58 PM
Megalith's Avatar
Quoted: 20 Post(s)
Okay, false alarm---I think I was unable to change picture modes only because I didn't have any input into the panel, so things were grayed out?
I mistakenly went into this thinking I could get the whole ISF thing set up, but this is pretty useless for that because it won't let you adjust anything under the Pro Adjust menu, correct?
Megalith is offline
post #107 of 119 Old 05-18-2010, 06:11 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Originally Posted by Megalith View Post
... I mistakenly went into this thinking I could get the whole ISF thing set up ...
Perhaps you want KuroControl.
bodosom is offline
post #108 of 119 Old 11-19-2014, 10:00 PM
tjarmusz's Avatar
I'm retarded and can't connect
First,
Thank you for making this software. It sounds spectacular.
I'm sorry to awaken this old thread, but I'm having trouble connecting. I'm not computer illiterate, but not overly tech-savy either.
I have a KPR-500M and 3 year old toshiba laptop with windows 7. I bought a cross over cable and plugged it into the ethernet port on the kuro and the cpu. I also have a spare ethernet cable if needed.
Where I get lost is the ip settings. I can find them, but what I type in doesn't work. One post said disable DCHP and another said leave it. I've tried a few different settings but it won't connect for some reason.
I'm not sure where to begin, could anyone here help?
Thank you.
tjarmusz is offline
post #109 of 119 Old 11-20-2014, 06:46 AM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
@tjarmusz
It's been a while since I tried using a crossover cable to do this. It's also much easier to connect the KRP to your home network if you can reach the router from the KRP port, but here's what I would do to connect directly.
Once everything is connected, disable your laptop's WiFi adapter as that will only confuse things. Then disable DHCP on both the KRP and laptop, and make sure you set up different private IP addresses on the KRP and laptop on the same subnet with the correct subnet mask.
For example:
Laptop
IP: 192.168.1.10
Subnet Mask: 255.255.255.0
KRP
IP: 192.168.1.11
If it doesn't work, try using a regular Ethernet cable. Most modern PCs have Ethernet MDI/MDIX Auto Cross which means a special cable is not required.
jdbimmer is offline
post #110 of 119 Old 11-20-2014, 06:58 AM
tjarmusz's Avatar
Thank you. I'll check into that.
My TV will reach the router and I have 1 ethernet cable. If the crossover cable can be used as ethernet, then I have two cables. Should I try this way and if so, plug what into what? Would I still need to disable DHCP and manually enter ip's?
tjarmusz is offline
post #111 of 119 Old 11-20-2014, 07:28 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
If you mean you can connect your Kuro to your home network then per "It's also much easier to connect the KRP to your home network" that's what you should do. Assuming you have a DHCP server plug in the Kuro into your router (or whatever you use to attached wired devices to your network), find it's IP address using the Kuro menu system and then you're good to go.
bodosom is offline
post #112 of 119 Old 11-20-2014, 02:23 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
You might be introducing more potential issues that way. There are many variations on how to do this, but you would want to use the standard cable to connect the KRP to the router (because we don't know if those devices support Ethernet MDI/MDIX Auto). Turn on DHCP on the KRP, and once it get's an IP from the router, you will be able to see it in the KRP IP settings. Then just configure and connect your laptop to your network via Wifi (like you normally do for internet/home access), and enter the KRP's IP in KuroReader.
@bodosom: Long time no see. How are things?
jdbimmer is offline
post #113 of 119 Old 11-20-2014, 07:31 PM
tjarmusz's Avatar
Not sure what I was doing wrong but the ethernet connection worked and it was really easy. Thank you all.
tjarmusz is offline
post #114 of 119 Old 11-21-2014, 08:12 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Still waiting on a reasonably priced replacement for my 500M. Lucky for me it still looks great.
bodosom is offline
post #115 of 119 Old 11-21-2014, 03:38 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
Good news!
jdbimmer is offline
post #116 of 119 Old 11-21-2014, 03:43 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
Same here. All the current 60 to 65" replacement options have their own set of compromises. And most don't have comprehensive IP control - I guess that didn't catch on.
jdbimmer is offline
post #117 of 119 Old 02-09-2015, 10:22 PM
mak99's Avatar
Quoted: 27 Post(s)
OK, after all these years I finally tried to get the software to work on my 141, but am having zero luck. The 141 is plugged directly into a TrendNet 8-port gigabit switch, which is connected to my Motorola cable modem. All other devices plugged into the TrendNet or Motorola show up on my wirelessly-connected laptop - Yamaha receiver, Roku 3 (both hard-wired and the wireless one downstairs), WDTV Live Hub, etc.
I have IP Control Enabled and DHCP on. IP address is <deleted>, but nothing happens when I try to connect via KuruReader or entering the address directly into any web browser. Not sure what to do with the Subnet Mask or Default Gateway #s .
Anyone still on this thread that might offer some advice? I'm fairly tech savvy but am a bit frustrated that I can't get this to work...
EDIT: For whatever reason I finally got the webpage loaded via IE, then Kuro Reader worked too. No idea why it didn't work when I first tried this earlier this evening. I did power-cycle with the main power button, so maybe it just needed some time to get synced up?
3,937 hours since May 2009, not even 2 hours/day. The other tabs are quite useful - quite the impressive software!
still one of my favorite bumper stickers of all time...
FREE TIBET! *
* with purchase of equal or lesser Tibet
mak99 is offline
post #118 of 119 Old 08-13-2016, 06:14 AM
Liked: 0
Is there an updated downloaded link?
Zooop is offline
post #119 of 119 Old 08-21-2016, 03:52 PM - Thread Starter
jdbimmer's Avatar
Quoted: 32 Post(s)
It's in the 1st post of this thread.
jdbimmer is offline
