Which one to get? - AVS Forum | Home Theater Discussions And Reviews
Old 09-06-2009, 10:15 AM - Thread Starter
ddtstartrex's Avatar
Hello all, you must get these type of questions all the time but everyone's case is a little different. So here is mine lol.
Room about 10 x 20 semi bright
seating about 7 feet in front all so angle seating
I have digital cable not HDTV
I have right now a 42" rear projection tv
dvd player not blue-ray
I watch a variety of shows, movies etc.. but no sports
So what all do you think?
ddtstartrex is offline
Old 09-06-2009, 10:58 AM
MikeBiker's Avatar
Quoted: 12 Post(s)
You don't mention what your budget is or what exactly you are trying to fix/improve, so I'm going to make some assumptions.
The rear projection gives poor off-axis picture quality (I'm sure that you've noticed). LCDs also have problems with off-axis viewing, so a plasma is what you need.
The newer plasmas work very well in semi-bright conditions. Just get one with an anti-reflective screen (all but the very bottom models have one).
At 7 feet, you would be better off with a 50" set than a 42", so upgrade the size.
I prefer the 1080P sets, but a 720P would be fine at 7 feet distance. Get the 1080P if your budget allows.
You will need at least one HD source. I suggest contacting the cable company and getting a package with some HD. Get a Blu-ray player if your budget allows.
The choice of which plasma manufacturer's set to buy depends upon your personal preference. Any will be good.
Lastly, start watching sports!
MikeBiker is offline
Old 09-06-2009, 11:05 AM
gwsallen's Avatar
gwsallen is offline
