Plasma Break-In (Slides/DVD): Purposeful or Pointless? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 129 Old 01-06-2010, 09:33 AM
DaBreeze's Avatar
Which break in slides/dvd to use ? Seems like D-nice has expertise with Panasonic. Are his slides for break in specifically for Panny Plasma's ? Evangelos DVD are more inclined for Samsung Plasma's correct ? I've ordered Evangelos DVD for my 58B650 arriving tomorrow. Right Choice ? Will the Sammy instruction manual state how to transfer the DVD to memory card ? I'm new to memory card is this the best way to use the DVD for breaking in ? Does the dvd play on a loop ? Can I use a Oppo 970 DVD Player to play the DVD over a prolonged session ? Will it hurt the DVD Player ? I also have a Panny BD-35 any preference as to which DVD player. Or, is the memory card the best way ? How do I do the memory card ? Ethernet cable to TV ? Will I need to download anything ? Help please from tho's in the knows.
DaBreeze is offline
post #122 of 129 Old 01-06-2010, 11:41 AM
jonesro's Avatar
I just down loaded the slides you can find on this thread and put it on a usb and used that. the t.v. will run them as a slideshow.I ran the slides all night and watched normal programming during the day with the contrast turned down for 150 hrs
jonesro is offline
post #123 of 129 Old 01-08-2010, 02:51 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Perfect plan!
wase4711 is offline
post #124 of 129 Old 01-09-2010, 07:27 AM
panabolic's Avatar
My sig has a link to the 120 slide set which some techy people reported are better than D-Nices because of the gradation between slides and the ordering
panabolic is offline
post #125 of 129 Old 02-13-2011, 07:59 AM
stalwart105's Avatar
could someone please check this link, i tried it doesnt work. please advise another link if there is any. i am looking for sildes thaT are already 16:9.
thanks for the help.
stalwart105 is offline
post #126 of 129 Old 10-14-2011, 06:59 PM
Marco79f's Avatar
I everyone,i am fairly new to this forum and I was looking for d'nice slides and break in guidelines. Anyone could direct me to the right direction?
Marco79f is offline
post #127 of 129 Old 10-15-2011, 08:37 AM
bazlog's Avatar
I would put your plasma into THX or Cinema sit back and enjoy as there is no point in slides, then after about 500 hours maybe consider a calibration.
bazlog is offline
post #128 of 129 Old 10-17-2011, 03:47 PM
lungclops's Avatar
I want to log some break-in hours on my new ST30 while I sleep. Anyone see a problem with playing a movie in super slow-mo, so that it takes a good 8 hours to get through the whole thing? My DVD player doesn't let you automatically loop movies, is why I ask.
lungclops is offline
post #129 of 129 Old 05-19-2013, 10:59 PM
jyoung117's Avatar
Wouldnt the scroll bar be static?
kkirsche likes this.
jyoung117 is offline
