Connecting PC to Samsung HP-S4253 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-14-2009, 04:57 AM - Thread Starter
willise's Avatar
Hi All,
I am trying to connect my laptop to the PC input connection on my Samsung 4253 plasma. The TV has a dedicated PC input of a VGA and I'm assuming a SPDIF input.
Anyway, the video looks great. The problem is that I cannot get any audio. The optical SPDIF cable is transmitting the signal (I can see the red light at the end of the cable).
I guess the first question would be is the Audio input on the TV an SPDIF input. It does take the 3.5 mm Toslink adapter fine. Secondly, do I have to set anything up in the TV for the audio input to work?
Thanks!!
willise is offline
