Cheap set of stereo/virtual surround speakers for the KRP-500M - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-03-2009, 01:31 PM - Thread Starter
Nintendogs's Avatar
Hi, I just need a cheap set of stereo or virtual surround speakers (about $120, and absolute max $200) that I can use with the KRP-500M. Any quick response would be appreciated as we are about to go to Best Buy.
Thank You!
Nintendogs is offline
post #2 of 8 Old 10-03-2009, 01:47 PM
playaj's Avatar
Sony HT_CT100
playaj is offline
post #3 of 8 Old 10-03-2009, 02:08 PM - Thread Starter
Nintendogs's Avatar
Originally Posted by playaj View Post
Sony HT_CT100
Do you know of anything just a little cheaper?
post #4 of 8 Old 10-03-2009, 02:59 PM
WestTenn's Avatar
I'm not expert here, but I'm in the same boat. Awaiting delivery of a 500m, and decided to go with just bookshelves for now, plugged directly into the monitor (two Polk Monitor 30's). They are not powered speakers, as I've read you need a leveler in order to use powered speakers with this monitor. From what I understand, most soundbars are powered speakers, so you might want to do a little more research.
Hopefully, the Polks will do fine a low volumes until I get a receiver set up. I have an old Sony I can use, but we'll see.
WestTenn is offline
post #5 of 8 Old 10-03-2009, 03:23 PM
powertoold's Avatar
Those Polk will work perfectly fine. I'm very satisfied with the internal amp on the 500m. Sure, it's not mind boggling, but it's much better than any internal TV speaker.
powertoold is offline
post #6 of 8 Old 10-03-2009, 03:37 PM
another schmo's Avatar
Newegg has the Energy Take 5.0's for $180. Then you're set when you buy an AVR.
another schmo is offline
post #7 of 8 Old 01-19-2010, 09:35 PM
choptalk's Avatar
Quoted: 20 Post(s)
which imput do you plug these self powered speakers into?
choptalk is offline
post #8 of 8 Old 01-19-2010, 10:16 PM
trem0lo's Avatar
The panel has proprietary speaker inputs and it comes with it's own adapter that terminates in normal speaker wire. That's what you use.
trem0lo is offline
