Panasonic TH-50PZ85U HDMI issues - AVS Forum | Home Theater Discussions And Reviews
Old 12-17-2009, 08:33 PM - Thread Starter
Brian.F's Avatar
Hi,
Beginning a couple of months ago, the picture on my Pany goes blank periodically. Reaching behind and wiggling the HMDI cable almost always makes the picture come back. I've gone through the basic debug with Panasonic service via email, and they now acknowledge that I may have a problem and are planning to send service out. I thought I'd ask before I spend what I expect to be a lot of money on repairs, if anyone else has had this issue and what solution you came up with.
Brian
Brian.F is offline
Old 12-21-2009, 02:03 PM
valsuvious's Avatar
I had a similiar problem with mine, although my problem ending up being my receiver that was causing the issues. Are you going through a receiver. My receiver was a Onkyo refurbished model (can't recall the exact one now) that from what I was told, has a history of problems with the video. These problems were all associated when switching between the video modes. The audio would switch but I would have no video unless I went and toggled the hdmi cables.
Not sure if this would help you, but maybe it will help you narrow it down just a bit.
valsuvious is offline
