Finally!! Mounted tc-p50s1 over media niche - AVS Forum
post #1 of 9 Old 01-07-2010, 05:36 PM - Thread Starter
aceniza's Avatar
After a couple months I finally got my monoprice mount (3725). Framed out my media niche and mounted the sucker up.
aceniza is offline
post #2 of 9 Old 01-07-2010, 06:24 PM
xb1032's Avatar
Liked: 26
Congratulations! Enjoy.
xb1032 is offline
post #3 of 9 Old 01-07-2010, 06:41 PM
cedarwood's Avatar
nice but watch the heat from the fireplace
cedarwood is offline
post #4 of 9 Old 01-07-2010, 07:12 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 33 Post(s)
Liked: 429
It's not a problem. Panasonics are officially rated for use above a fireplace. Even if they weren't, in my 8 years here i haven't seen a single post about a flat panel TV being damaged from being above a fireplace.
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR605, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 9 Old 01-07-2010, 08:23 PM - Thread Starter
aceniza's Avatar
thanks guys. Chimmeny goes up towards the right... but we've never used it, just the heater. Ahhh, San Diego.
What do you guys think of the frame-out?
I'm always overly cautious, and over-build everything. This is my first attempt of going simple. No brackets, just 3.5" deck screws, a little common sense, and finding the studs.
Needless to say I'm still paranoid about it
aceniza is offline
post #6 of 9 Old 01-07-2010, 08:52 PM
Skidpad's Avatar
I like your framing/mounting solution - good idea (here's mine). As long as everything is properly attached to the studs, you should be good.
Welcome aboard.
Skidpad is offline
post #7 of 9 Old 01-08-2010, 03:24 PM
Gandu's Avatar
Liked: 35
I think the house will fall down before the plasma. Well engineered. As for the heat, if you just use the gas, it will never get hot enough to bother anything. If you stuff a bunch of hot burning oak firewood you will probably crack the low budget chimmney liner that is common in San Diego fireplaces. (I'm in PQ)
Gandu is offline
post #8 of 9 Old 01-08-2010, 04:04 PM
Juan's Avatar
Look good, congrats.
Juan
My HT
Juan is offline
post #9 of 9 Old 01-18-2010, 01:14 PM - Thread Starter
aceniza's Avatar
thanks for the reassurance of my frame-out. I had ideas of doubling up 2x4s, deck brackets, and 45* triangulated studs to catch the next stud, but a buddy of mine reassured me that it was definitely overkill.
I actually lived in PQ most of my life, I'm right around the corner in 4s Ranch now. Parents still live in PQ (since 87).
aceniza is offline
User Tag List
