65v10 Card slot? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-24-2010, 09:07 AM - Thread Starter
canadadude's Avatar
i have the 65 v10 panny and i have a sony cybershot camera and the cards are different .Does anyone make an adapter or something to get my images on the tv without hooking up wires to camera?? thanks in advance
canadadude is offline
post #2 of 8 Old 01-24-2010, 09:09 AM
hi im drummer03's Avatar
Hopefully someone will find a adapter.I get asked this question all the time.
PN58B860
TCP50GT50
hi im drummer03 is offline
post #3 of 8 Old 01-30-2010, 07:00 PM - Thread Starter
canadadude's Avatar
Someone must have run into the same problem.Does everyone buy panasonic cameras?? Let me know folks thanks alot
post #4 of 8 Old 01-30-2010, 07:48 PM
Steve S's Avatar
Liked: 46
If the set has a USB port you could transfer the pix from your computer to a thumb drive?
Steve S.
Steve S is offline
post #5 of 8 Old 01-30-2010, 07:51 PM
Steve S's Avatar
Liked: 46
Sony is the only camera mfg. that doesn't use SD cards, other than some Olympus and Fujis that use XD, I guess Panny went for the most common format--that used by Canon, Nikon, Samsung, Kodak, Vivatar, GE, and, yes, Panasonic cameras.
Steve S.
Steve S is offline
post #6 of 8 Old 01-31-2010, 09:18 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 519 Post(s)
Liked: 775
I'm not aware of any adapter that would make the Sony memory card work with the Panasonic TV, but it's possible that someone somewhere makes something. Google it.
But can't you just copy the jpg images from the Sony card to a standard SD card and plug that into the TV?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 8 Old 01-31-2010, 09:34 AM
bluewaves's Avatar
Quoted: 17 Post(s)
That'll teach you to buy anything from Sony or anything that doesn't use an industry standard part.
bluewaves is offline
post #8 of 8 Old 01-31-2010, 10:07 AM
ogbuehi's Avatar
There is no adapter that you could get. Just buy an SD card and transfer the photos onto it. That's your best bet.
ogbuehi is offline
