Is it possible to turn a 6020FD into an ELITE? - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #601 of 716 Old 02-15-2012, 05:20 PM
TopperMcFly's Avatar
Liked: 36
Thank you.
The resistors are smaller than a grain of rice. It is quite difficult to work with these. I am having a friend do a batch of these for me. I had him do my original 1352 board yesterday and it worked perfectly. My 5020 in now a 111FD. You can search for AWW1353 on ebay and buy them from me. This board functions exactly the same as the AWW1353 minus the sensor which most people remove anyway. You can send your board to someone offering to upgrade it, but your set will be down for that time and you will not have a backup board. Your call
Now I am going back to enjoying my Elite set
Gunga Gulunga..... Gunga Kunga Galunga..... On your deathbed you will receive total consciousness. So I got that goin' for me.
TopperMcFly is offline
post #602 of 716 Old 02-20-2012, 06:06 AM
Liked: 36
PM me with any questions
post #603 of 716 Old 02-20-2012, 10:58 AM
caunyd's Avatar
What does the IR plug do. How is the functionality affected if I get a converted 1352 rather than a real 1353.
caunyd is offline
post #604 of 716 Old 02-22-2012, 11:32 AM
Wiscoguy's Avatar
Bought a board from Jano18 & very excited to install it. I already think the picture is great so anything better is awesome. Going in a Kuro 5020.
Wiscoguy is offline
post #605 of 716 Old 02-23-2012, 01:40 AM
caunyd's Avatar
I'm looking at the back of my TV, and I don't know how to remove the first white ribbon. I don't see any latches, I just see an extremely small bit of metal on each side where the white ribbon is attached. I took a picture of what I'm seeing. Any advice on how to remove this first ribbon cable? Thanks.
caunyd is offline
post #606 of 716 Old 02-23-2012, 07:10 AM
spongebob's Avatar
Quoted: 96 Post(s)
jerk it out of there!
bob
spongebob is offline
post #607 of 716 Old 02-23-2012, 07:14 AM
D-Nice's Avatar
Quoted: 710 Post(s)
Liked: 1508
Never "jerk" a ribbon cable out of its seating. He needs to re read the instructions to get the cable out.
bob
D-Nice is offline
post #608 of 716 Old 02-24-2012, 02:22 PM
caunyd's Avatar
Anyone?
caunyd is offline
post #609 of 716 Old 02-24-2012, 08:00 PM - Thread Starter
TG_ONE's Avatar
I believe you are at step 8 here http://www.hippotechsolutions.com/?page_id=2693 there is not a latch on that connector so you carefully pull the cable. Since you got the back off I would take some compressed air and clean off all the boards. From the pictures the boards look kind of dusty and will help prolong the life of the electronics regardless if you change the board or not.
TG_ONE is offline
post #610 of 716 Old 02-24-2012, 08:10 PM
zrdb's Avatar
bob
Oh-really great advice! In case you didn't know those ribbon cables are FRAGILE.
zrdb is offline
post #611 of 716 Old 02-28-2012, 08:16 PM
fastrandstrongr1's Avatar
Anyone?
your best option is to wiggle it out. it will be tough to do, but i would pinch the cable at the sides to free it. i remember that one being the hardest to pull out. don't force it, but you DO have to apply a fair amount of pressure.
Pioneer PDP-6020FD E-lite
fastrandstrongr1 is offline
post #612 of 716 Old 02-29-2012, 08:47 AM
victor.cdn's Avatar
From your pics it looks like you are trying to pull off the 'wrong' end of the ribbon cable ??? , ie are you trying to pull the ribbon cable end which is attached to the 'vga connector board' ?, pull out the other end, the end that is attached to the audio board that you are replacing, there is no need to disassembly the other side of the ribbon. There are no latches or anything, it just pulls straight out, it is held in place in the assembly by pressure alone. It is snug, just pull evenly and steadily.
When you replace your board don't forget to install the heat sink that is on
the back of the original board, it looks like a 1" x 1/2" x 1/4" white soft rubber block.
I forgot this and went back in eventually and went through the whole procedure and put this back in.
victor.cdn is offline
post #613 of 716 Old 02-29-2012, 08:57 AM
victor.cdn's Avatar
also ... first remove the vga board from the back panel by removing 2 nuts beside the vga connector and 1 philips head screw at the other edge of the board, this will allow you to get the black metal back sub panel off that we can see in your pic, ....then you can pull out the ribbon cable ... from the socket which is on the audio board ... so you will be left with the ribbon cable still attached to the vga board socket but the other end free
post #614 of 716 Old 03-02-2012, 06:05 AM
joe_sun's Avatar
Anyone know a source for the AWW1353 boards or someone who is still doing the conversion? I've sent out a couple of PM's but not heard back from anyone yet.
joe_sun is offline
post #615 of 716 Old 03-03-2012, 12:11 PM
Liked: 36
I will have another batch of these modded and tested in about a week or so. Quantities are drying up so PM me to have one reserved.
post #616 of 716 Old 03-03-2012, 10:56 PM
SoupRknowva's Avatar
this is super cool, i dont really come to AVS that often anymore, ever since i bought my 5020, i stayed away to save my wallet.
But i finally moved out of the dorms so i was wanting to get an ISF calibration done, so i pop in real quick and see this thread, now i obviously want to do this first, then get the calibration, probably from Chad B since im just south of him in Dayton OH.
TopperMcFly youll be getting a PM shortly
Pioneer PDP 5020 E-Lite modded-Emotiva ERM-1's-Epik Sentinel
SoupRknowva is offline
post #617 of 716 Old 03-22-2012, 08:52 PM
I am victorious! got the modded board from TopperMcFly yesterday and installed it tonight
post #618 of 716 Old 03-30-2012, 08:21 AM
madpioneer's Avatar
Just completed my PDP-5020HD IO board swap last night. Took around 2 hours as I took my time.
Used a folding wood TV table to lay out the screws in the same configuration as they came out. Made it so easy at a glance to know exactly where they belonged during the reassembly.
Was slightly leary about doing this project for fear of either cracking the screen or messing up a connection and not being able to go back to stock.
But it was really an easy task. Just took my time as the instructions and everyone advised.
Re-installed the IO metal cover and main back cover with just a few screws so that I could test it before installing the multitude of the rest of the screws.
Fired up and no problems or flashing blue lights.
Now just need to get a calibrator over to make it the best it can be.
Have a PRO-111 Elite in my living room main setup and now a PDP-5020 E-lite in my bedroom setup.
madpioneer is offline
post #619 of 716 Old 04-20-2012, 07:27 AM
xxxxxx's Avatar
Quoted: 13 Post(s)
Add me to the list. Did the board swap (thanks TopperMcFly, who by the way, is a GREAT guy to deal with) and things worked out well. I thought I had more buzz after swapping the boards, but, after putting everything back together (especially putting the back panel back on), it was evident to me that there was no difference. I did the board swap with the TV in place on top of the large cabinet where it usually sits instead of moving it to another location. I'm glad that I didn't end up laying it on the floor because, at least in my case, it would have just been a lot of extra work but it wouldn't have made the job any easier (and I also was worried about having the TV laying face down, even on a comforter). I used scotch tape and taped each screw I took out right next to the hole it came out of so reassembly was child's play. The only thing to watch out for is the ribbon cables but you just have to take your time with them. Otherwise, there was nothing difficult about it at all.
xxxxxx is offline
post #620 of 716 Old 04-24-2012, 03:47 PM
mr. wally's Avatar
Quoted: 128 Post(s)
Liked: 108
it's a tricky procedure especially with that ribbon cable, but it is well worth the effort. the improvement in pq after tweaking the settings in pro is truly amazing just from this one little board.
mr. wally is offline
post #621 of 716 Old 04-29-2012, 10:56 PM
caunyd's Avatar
Hi guys, I'm having a really difficult time pulling the white connector up, as shown below.
http://www.hippotechsolutions.com/wp...side-cable.jpg
As it says in the directions in step 10, you just pull up on the white connector right? Is there any latch that I should be flipping? Or something else that I should be doing? Because I have been pulling as hard as I feel comfortable, but I can't get the white connector off. What am I doing wrong?
caunyd is offline
post #622 of 716 Old 04-30-2012, 09:39 AM
caunyd's Avatar
Anyone?
caunyd is offline
post #623 of 716 Old 04-30-2012, 09:47 AM
fishinbob's Avatar
Anyone?
For the one shown in the pic you pull straight up. The two wider ribbons above have the latch mechanisms.
fishinbob is offline
post #624 of 716 Old 04-30-2012, 10:21 AM
caunyd's Avatar
fishinbob,
I tried doing that, but it seems to be stuck. I tried using a decent amount of force pulling up, but it seems that it is lodged there. Any suggestions on how to remove that stuck white connector without damaging the board that it's on?
caunyd is offline
post #625 of 716 Old 04-30-2012, 10:35 AM
caunyd's Avatar
Is there some kind of lubricant that I can safely use on an electronic board? Because if all you have to do is pull up on the white connector, then my connector is STUCK.
caunyd is offline
post #626 of 716 Old 04-30-2012, 10:40 AM
caunyd's Avatar
Ok I got it. I had to take a sewing pin and pry it apart slowly. Thanks guys
caunyd is offline
post #627 of 716 Old 05-12-2012, 10:27 PM
locdog33's Avatar
I have a 141fd and 151fd with broken panels and when I remove both backs all the parts are the same as 6020fd parts except the I/O boards.
locdog33 is offline
post #628 of 716 Old 05-14-2012, 02:52 PM
locdog33's Avatar
Ive done the swap in my 6020fd but the picture quality isn't that great after the swap. Anything else I should do? I have the 6010fd and picture quality on my 6010fd seems better.
locdog33 is offline
post #629 of 716 Old 05-14-2012, 08:10 PM
Jano18's Avatar
I have several of the Elite I/O boards part# AWW1353 available for sale. If you are interested you can see my ad in the classified section. Feel free to PM me or use my contact information below.
Jan Simonsen
586-855-1305
jansimonsen@comcast.net
Jano18 is offline
post #630 of 716 Old 05-14-2012, 10:22 PM
trem0lo's Avatar
Have you enabled the ISF modes? They are significantly better than Pure, which resembles Movie on the non-Elites. Calibrated ISF day combines the accuracy of Pure and brightness/pop of Standard, it is quite nice.
trem0lo is offline
Pioneer Pdp 6020fd 60 Inch Class Kuro Plasma Hdtv , Pioneer Elite Pro 151fd 60 Inch 1080p Plasma Hdtv
