Is it possible to turn a 6020FD into an ELITE? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 717 Old 09-21-2010, 08:58 AM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
Originally Posted by jeff6666p View Post
My board is coming in today. Any tips on how to cut off the color sensor and how far down to cut?
I would drill a hole in the back panel instead. It was very easy and you don't have to worry about damaging your new board. What if your new board is defective...if you cut on it I imagine you won't be able to return it.
AlanBuck is offline
post #182 of 717 Old 09-21-2010, 11:13 AM
jeff6666p's Avatar
I just got done swaping the boards I don't have pure mode why?
jeff6666p is offline
post #183 of 717 Old 09-21-2010, 12:00 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
You should have Pure mode. If you still have Dynamic mode you didn't get the right board. Dynamic mode is not available with the Elite model. Also you should see 'Pro Adjust' as an option on your picture adjustment (ie tint, color etc.) menus.
AlanBuck is offline
post #184 of 717 Old 09-21-2010, 12:20 PM
jeff6666p's Avatar
My board had the color sensor on it?
post #185 of 717 Old 09-21-2010, 12:28 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
I think that extra port is not a color sensor port..it is an IR repeater port if you look the Elite manual. So you had to cut it down or drill a hole in the back panel? If so that would be for an Elite board. If you have the extra port on the new board I can't imagine why you aren't getting Pure mode as a picture option.
AlanBuck is offline
post #186 of 717 Old 09-21-2010, 12:35 PM
jeff6666p's Avatar
I cut it down. There's no pure mode.
post #187 of 717 Old 09-21-2010, 12:38 PM
dsmdriver's Avatar
Jeff, you aren't running of a PC input are you? In that case you only get standard and user (I think those are them)
If the TV is still open it's easy to tell if it was a AWW1352 or 1353.
I do know for a fact the TV won't boot without the board installed so you can't have a bad connection or anything.
dsmdriver is offline
post #188 of 717 Old 09-21-2010, 12:39 PM
jeff6666p's Avatar
I'm using an hdmi port.
post #189 of 717 Old 09-21-2010, 12:40 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
Are you seeing Pro Adjust as an option on your picture adjust menus?
AlanBuck is offline
post #190 of 717 Old 09-21-2010, 12:41 PM
jeff6666p's Avatar
No everything is the same as before. What happened
post #191 of 717 Old 09-21-2010, 12:51 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
That is bizarre. I would be very upset! Where did you get your board?
AlanBuck is offline
post #192 of 717 Old 09-21-2010, 12:53 PM
jeff6666p's Avatar
I have a feeling I just wasted $100. I am very upset. This is the board I bought.
http://www.discount-merchant.com/PIO...-p/1114749.htm
post #193 of 717 Old 09-21-2010, 01:04 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
Totally strange.
AlanBuck is offline
post #194 of 717 Old 09-21-2010, 01:05 PM
jeff6666p's Avatar
Totally strange.
What is?
post #195 of 717 Old 09-21-2010, 01:20 PM
wrinklefree's Avatar
What is?
What's the manufacture date on your panel?
wrinklefree is offline
post #196 of 717 Old 09-21-2010, 01:23 PM
jeff6666p's Avatar
2008 jul
post #197 of 717 Old 09-21-2010, 01:24 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
What is?
Strange that your new board is not giving the Elite adjustments.
AlanBuck is offline
post #198 of 717 Old 09-21-2010, 01:24 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
2008 jul
Same date as my 6020
AlanBuck is offline
post #199 of 717 Old 09-21-2010, 01:26 PM
jeff6666p's Avatar
Could it be one of the ribbon cables might not be all the way in?
post #200 of 717 Old 09-21-2010, 01:27 PM
Irwinroad's Avatar
Quoted: 81 Post(s)
Liked: 37
Does the new board have the resistor that is on the cable side of IO4?
Irwinroad is offline
post #201 of 717 Old 09-21-2010, 01:29 PM
jeff6666p's Avatar
I think so, It's the elites board. The panel is together right now.
post #202 of 717 Old 09-21-2010, 01:38 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
Does the picture of the board on the website he bought it from show the extra resistor? It does show the extra port for the IR repeater. I'd have been furious if I went to all this trouble and ended up with a 6020! Although I guess it could be worse..at least his set still works.
AlanBuck is offline
post #203 of 717 Old 09-21-2010, 01:41 PM
jeff6666p's Avatar
I'm going to open it back up and take a pic.
post #204 of 717 Old 09-21-2010, 02:20 PM
jeff6666p's Avatar
Can't get a good pic. look like there is on r7559 and there's one on aww1353. One of the ribbon cable slots wasn't closed
post #205 of 717 Old 09-21-2010, 03:17 PM
jeff6666p's Avatar
IT WORKS. It wasn't working because the ribbon cable was loose.
post #206 of 717 Old 09-21-2010, 03:20 PM
I'm surprised it didn't throw off a code
post #207 of 717 Old 09-21-2010, 03:38 PM
Juan's Avatar
Thats great, happy for you.
Juan
My HT
Juan is offline
post #208 of 717 Old 09-21-2010, 03:42 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
Awesome! Now have fun with your new toy. One question I have for forum members...in D-Nice's suggested settings for the Kuros he mentions 'plus green' panels. Does anyone know what dates and or serial numbers this applies to. Without knowing, it is impossible to know what settings to use.
AlanBuck is offline
post #209 of 717 Old 09-21-2010, 03:50 PM
jeff6666p's Avatar
I don't know what the 'plus green' panels are but am using the 111fd settings.
Thank you all for everyone's help and Thank you TG_ONE for finding out how to make this possible.
post #210 of 717 Old 09-21-2010, 04:08 PM
AlanBuck's Avatar
Quoted: 51 Post(s)
Liked: 44
I don't know 'plus green' panels are but am using the 111fd settings.
Thank you all for your help and Thank you TG_ONE for finding out how to make this possible.
I have mine set to D-Nice 'plus green' 151fd settings. Problem is I don't know if my set is really a plus green one or not so the D-Nice settings may not be valid. It does look very nice though. I did back the color off a couple clicks...he called for +3 but I think mine looks better at +1. I am now on the fence about getting a pro calibration vs getting the ControlCal Elite profiles and messing with it myself. I can say that I was at a buddies house last night watching a Sharp LCD set....YUCK. Shadows in faces were green among many other flaws. I came back home and watched the same shows on the Kuro and what a difference! Also thanks to TG-ONE for discovering this cool upgrade for 5020/6020 owners.
AlanBuck is offline
Pioneer Pdp 6020fd 60 Inch Class Kuro Plasma Hdtv , Pioneer Elite Pro 151fd 60 Inch 1080p Plasma Hdtv
