Where can I find link to THX fix for my G15? - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2010, 12:01 PM - Thread Starter
Turbolover's Avatar
Guys does anybody know where I can find link to THX fix for TC-PG15? I heard that its only available to techs but someone must have it here?
Turbolover is offline
Old 02-24-2010, 01:00 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
The direct links to the download and the instructions were recently posted in the THX Issues thread IIRC.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 02-24-2010, 01:05 PM
jackal2001's Avatar
http://www.avsforum.com/avs-vb/showt...5#post18031825
TC-P50V10 Build Date: April 2009
A-Board replaced on 1/4/2010 w/1.24, updated to 1.28.
Current 0% IRE: 0.034FtL
My SM Factory Numbers
Putting the 50V10 downstairs. Bought a new Elite 101FD
jackal2001 is offline
Old 02-24-2010, 01:16 PM - Thread Starter
Turbolover's Avatar
Thanks guys.
Old 03-07-2010, 10:14 AM
bokko's Avatar
TC-P46G15
Mine has a build date of May 2009.
I called Panasonic and fix was carried out by a local repair shop.
The first step was the firmware fix listed in link above installed by booting from Tech's first SD-Card provided by Panasonic.
The second step was another firmware upgrade to the "A Board" from a second SD card technician had with him...hope this info helps others. (they don't need to open up TV just enter service menu to set tv to boot from SD Card then boot from separate cards twice).
It has resolved problem for me. Previous to this fix when I tried to setup Standard mode myself using Avia 2 disk I own could never get colors and tint right. Which is now resolved. THX mode default's also did not test properly using Avia 2 for Color and Tint this is also resolved.
Happy with out of box experience now whole process was resolved by Panasonic. Wish I hadn't waited so long.
Looking forward to my visit with my ISF calibrator in April.
Folks the company stands behind it's product the repair is free just call in and get it done...this is first TV that I have owned (4th HD TV) that is pretty darn close out of box (once repaired) think most would be happy after fix is applied. I am used to looking at other two TV's in house which are also ISF calibrated so notice small differences...(also an Amateur photographer so accurate color is important for me).
PS
If your TV has been professionally calibrated this need not concern you the calibrator would have resolved issue when there.
bokko is offline
Old 03-07-2010, 11:42 AM - Thread Starter
Turbolover's Avatar
Bokko, I had a tech come in and install a fix from SD card also but only one card and I guess one fix. What does a "A board" fix fixes? Is it just a update that can be downloaded through viera cast? How can I check that I have all fixes installed?
