Samsung PNXXc450 Owners Thread *NO PRICE TALK* - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-06-2011, 05:14 AM
dawgindayton's Avatar
Got on Samsung's site and got involved in the "Live Chat"...
The person provided me a link to the Firmware Download (Not sure if it's the same as the one on the site)...And the Instructions on how to download it to a USB Memory Stick...The File is T-SAT4AUSHC.exe
Popped it in the side USB port on the Plasma and within 3 minutes???
PERFECT...Took every bit of that annoying red bloom away...
Back to Outstanding picture again...
dawgindayton is offline
Old 03-06-2011, 08:10 AM
cavu's Avatar
So what was the link provided???
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
Old 03-06-2011, 03:52 PM
mateojimmy's Avatar
I made some drastic adjustments to the white balance and came up with something a lot more natural than before....Still a bit off, but much better.
Movie, Cell light 0, Contrast 97, Brightness 56, Color 52, Tint 51/49, Warm 1, and everything else either off or out of auto. WB adjusted R gain to min (0) and then G & B gains to max (50).
It definitely turned white from a pink to almost white...
mateojimmy is offline
Old 03-06-2011, 09:08 PM
dssr01's Avatar
Post #2 (i have less then three posts, so, i am not permitted to post URL's...) BRB.
dssr01 is offline
Old 03-06-2011, 09:09 PM
dssr01's Avatar
Post #3
dssr01 is offline
dssr01's Avatar
Doing a quick Google search on the .exe file name, i got this return → http://members.driverguide.com/drive...iverid=1739386
dssr01 is offline
Old 03-10-2011, 10:58 PM
mateojimmy's Avatar
This link has version 1006, but they are on version 1008. You can find it on their site at http://www.samsung.com/us/support/do...PN42C450B1DXZA.
Old 03-13-2011, 02:41 PM
d_98se's Avatar
Dumped my C series for a D series. Here is the link.
http://www.avsforum.com/avs-vb/showt...6#post20144086
d_98se is offline
Old 03-13-2011, 03:14 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
Why? And question. Does it accept 1080P like this set did?
JukeBox360 is offline
Old 03-14-2011, 12:26 PM
Legoheads's Avatar
I too received a PN51D450 in exchange for my defective PN50C450 from B&H Photo. Have had it set up for two days now and I am thrilled with its performance so far. No buzz, no DSE/banding/streaking, minimal floating blacks PLUS you get an additional 1" of screen at no additional cost or size to the unit. A steal of a plasma for the price it is currently going for. For those on the fence between the two models I would strongly recommend going for the D series.
Legoheads is offline
Old 03-14-2011, 02:43 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
That doesn't answer the 1080P question
Old 03-14-2011, 03:19 PM
Legoheads's Avatar
I can check tonight to see if it accepts 1080p. I can't see why it wouldn't. Most 720p sets for the past 3 years could do this.
Never did understand why people choose to do this though... just ads to the processing lag and makes little/no difference to the picture.
Native resolution is always the preferred option in my book!
Old 03-14-2011, 06:32 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
So does it or does it not?
Old 03-14-2011, 06:54 PM
Legoheads's Avatar
Just tried it out and 1080p in = no problem on the d450.
Old 03-14-2011, 06:56 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
Thanks. Guess I'll be looking into this model after all. Did they fix the whole red level push issue? Or is the content still a bit red?
Old 03-14-2011, 08:34 PM
Legoheads's Avatar
Have not hooked up my color meter yet to measure grayscale so can't comment on this one.
Old 03-14-2011, 11:11 PM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
What about to the human eye. You should be able to see if there is to much red push. Skin tones would looks a bit more red then normal.
Old 03-15-2011, 05:23 AM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Great to hear! Do you notice a difference regarding black levels and color? Samsung also mentioned that they improved their motion for their 2011 plasma's.
WaveBoy is offline
Old 03-15-2011, 06:50 AM
jamesco411's Avatar
Did Samsung mention an improvement in blacks for the d450? I have a c450 and was just curious...
I know they mentioned improved daytime blacks in the 2010 c450 vs. the b450 due to the addition of small black spacers in the pixels....I can attest that my c450 blacks look quite LCDishly black in daytime / sunlight / fluorescent lighting....but once its midnight and the lights go out, you can tell the black levels aren't very inky...still black vs. the LCD purple/blue....its not an issue on 16:9 content, though...the blacks still look ok then...but on dark or dim nighttime scenes you can tell the black levels struggle in terms of depth....
jamesco411 is offline
Old 03-15-2011, 07:32 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
You can only expect so much from a budget display, but for it the class it's in, the 450 holds it's own.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
Old 03-15-2011, 10:50 AM
d_98se's Avatar
Main reason why i got the D450 was the buzzing with the C450. When walking past it i could hear it buzzing when laying in bed at low volumes 10ft away the buzz was omnipresent.
Another thing that I'm now noticing is that the D450 scrolling feature shows no vertical banding whatsoever!.
One of my break-in slides is black and in a dark room the TV appears to melt into the darkness when this slide is playing. More pix this weekend when i get a proper cam.
d_98se is offline
Old 03-15-2011, 11:01 AM
Legoheads's Avatar
It appears there is little improvement in regards to black level from what I can see. I do notice that the screen switches off when an all black signal is received and I cannot seem to disable like I could with the C450.
My guess is this is part of the more aggressive energy star requirements for 2011.
The colors on the other hand appear to have less dithering. Particularly tertiary colors appear solid and less grainy/washed out.
Skin tones look good to me on Warm2. This setting appears slightly less warm then it was on the C450 and it does not suffer from the green tint in dark areas as much.
Motion is crisp, but I never had any complaints in this category with the C450.
Speakers seem to be the same... decent.
Remote is the same but shrunken! It looks like someone shot the old one with a shrinking ray and scaled it to 80% its size. Pretty funny, but a welcome change. The old one was huge.
One less HDMI port. You now only get the two on the back.
Lastly, I've been noticing the plasma banding that plagues all plasma sets seems greatly reduced on this model from the C450. I used to clearly see this effect during car commercials when they list the terms of the lease at the end. Now it appears much less pronounced.
Old 03-20-2011, 07:09 AM
tripod39's Avatar
Quoted: 27 Post(s)
Picked up a PN51D450A2D @ BB last nite. Im planning on leaving tv on 24 hrs a day for 5 days.When I go to bed I will put on full screen HBO.Does that sound ok for breakin?
UN65JU6700FXZA TD01 3/15
PN51D6500
BD-D6500
Sony CT-100
USN Ret.
tripod39 is offline
Old 03-20-2011, 04:09 PM
Legoheads's Avatar
When I had my PN50C450 I was a extremely focused on breaking it in.
So I proceeded to run the slides 24/7 on DNice's suggested torch settings.
After close to 150 hours of break-in I felt it would be OK to use it. You know what? IR still happened. Still had to use the scroll wipe feature occasionally to clear the screen.
So after this C450 set got damaged from the 1008.2 firmware update and I received my new PN51D450 I decided to give up on the obsessive break-in nonsense. I basically run it on Movie mode and turn down the Cell Light to 6/7 and the Contrast & Brightness to 65 max. I'm much happier with this process and I love not having to wait to enjoy this beauty.
The problem with 24/7 break-ins is if something goes wrong like a power outage or a hardware failure you can really damage things. For instance I discovered the break-in slides I was using via USB stick did not fill the screen entirely so after days of break-in I had a 1/2" vertical band on both sides of the screen from uneven phosphor usage. I strongly believe the risks far out way the benefits of this type of hardcore break-in.
My advice is turn down the settings and avoid 4:3 or letter-boxed material for a few weeks. Meanwhile enjoy your new purchase with whatever content you want!
Old 03-20-2011, 04:32 PM
KJSmitty's Avatar
Liked: 34
Four plasmas later and absolutely no break in with exception to setting brightness and contrast to 50 and/or 60%. Have never had an issue with IR and/or PQ.
Pioneer Elites
Panasonic
Samsung
Cheers
Love DIY
KJSmitty is offline
Old 03-20-2011, 08:23 PM
Tag66's Avatar
Installed my 42C450 about 2 months ago. Never broke it in. Have cell light set about 50 and contrast about 75. I honestly have not yet once seen any IR. And the picture is fantastic. Love the image on this TV as much if not more than the 52" 1080p LCD I also have.
Tag66 is offline
Old 03-21-2011, 06:32 AM - Thread Starter
PENDRAG0ON's Avatar
Liked: 574
Looks like it is time for someone to start a D450 owners thread then.
Who wants to have the honors?
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
Old 03-21-2011, 06:50 AM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
I would if I were an owner lol.
Old 03-21-2011, 07:24 AM
tripod39's Avatar
Quoted: 27 Post(s)
So--This set has "plug n' play" on the menu,owners handbook says when out of the box,its ready to go.So.that's what I did.Turned contrast down to 60 and flesh tones -1.Good pic and sound is respectable.
PN51D6500
BD-D6500
Sony CT-100
USN Ret.
tripod39 is offline
Old 03-25-2011, 11:19 AM
jbserra's Avatar
Just set up my pn42c450. Initially, I heard no buzzing. Now I'm getting it, but only from my satellite source. Has anyone related this issue to the video source? Weird thing is, I passed the satellite through the tivo and I still get the buzz. It's loud and annoying.
I have an RCA switch box (setting up with the easiest connectors for now). If I hit the VCR/DVD or PS3, works fine. When I hit the satellite, loud buzz.
I'm going to see if heat is an issue with my satellite receiver because that thing gets HOT! It could be in close proximity to other noise, but I'm not sure who the culprit is. When it was sitting out by itself and hooked up directly to the TV, there was no buzz.
I'll play around a little more, but was wondering if anyone had seen this, or if maybe my set just decided to wait a couple of days before starting to buzz and now it won't go away.
jbserra is offline
Samsung Pn50c450 50 Inch 720p Plasma Hdtv Black
