The Official Panasonic TC-PXXS2 Owner's Discussion Thread [NO Price talk] - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 2275 Old 08-05-2010, 02:42 PM
shady acrez's Avatar
Just got off an online chat with the concierge folks..
they asked to to check for cracks on the screen...im currently at work so couldnt do that.
asked me to get back with them when i could check the screen & provide the serial #.
Depending on what i find...they would send out a technician...then go from there...
will provide a follow-up asap
shady acrez is offline
post #362 of 2275 Old 08-06-2010, 06:54 AM
ElwayLite's Avatar
Update on the buzzing. Im now 23 hours into the break in slides, and the buzzing on white slides is all but gone.
Im still impressed with how uniform the colors, much more than my 2008 model, especially the white.
ElwayLite is offline
post #363 of 2275 Old 08-06-2010, 07:12 AM
ElwayLite's Avatar
BTW, did Panny do away with cooling fans. My 2008 had 5, but I do not see any behind the S2.
post #364 of 2275 Old 08-06-2010, 07:45 AM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
No fans on the 46S2.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #365 of 2275 Old 08-06-2010, 07:45 AM
ElwayLite's Avatar
These Neo PDP's must def run cooler then.
post #366 of 2275 Old 08-06-2010, 10:46 AM
ElwayLite's Avatar
Buzz has reduced even more since this AM. 27 hours on set.
post #367 of 2275 Old 08-06-2010, 10:53 AM
eonibm's Avatar
I never heard a buzz on mine at all.
I LOVE this TV!
eonibm is offline
post #368 of 2275 Old 08-06-2010, 10:57 AM
ElwayLite's Avatar
In my experience, they all have buzzed early on with the white slides, but it decreases. Also, the picture quality of the set is generally better once you get a couple of hundred hours on it.
I'm doing updates like this to help people out, because all you generally see is "I just got the tv and it buzzes, im taking it back. Panasonic sucks..."
This is my 3rd plasma, so i know the drill.
post #369 of 2275 Old 08-06-2010, 11:01 AM
eonibm's Avatar
Has anyone been able to update their PSXX2 firmware?
There is a firmware upgrade here from Panasonic and the instructions mention loading two SD cards, SD 1 and SD 2, but the download only contains one file not two. Also, this may be something to do with my SD card but I get an error that card can't be read when I insert it into my P65S2, but then this is the same card I used for my break-in slides (but then reformatted as you are supposed to use a clean card for the firmware). So I am thinking it might be a problem with the file.
Anyone?
eonibm is offline
post #370 of 2275 Old 08-06-2010, 11:06 AM
ElwayLite's Avatar
Already been discussed. Go here:
http://panasonic.jp/support/global/c.../down_nap.html
One file for HDMI audio issues
post #371 of 2275 Old 08-06-2010, 11:15 AM
eonibm's Avatar
Thanks. Couldn't find the discussion you were talking about. Odd that on the panasonic.com site the instructions talk about 2 files but on the link you provided they talk only about 1 file.
eonibm is offline
post #372 of 2275 Old 08-06-2010, 11:17 AM
ElwayLite's Avatar
Yeah, that "jp" site is the one I use for BR updates too, it's better.
Maybe we discussed it in the issues, thread, but I though it was this one a few days ago.
post #373 of 2275 Old 08-06-2010, 11:40 AM
racerxx's Avatar
Just curious why you chose the S2 over the LGx50?
I am looking for the best "display" for the $$. Don't care about 3d or all the stupid net-apps. Heck I don't even need a tuner, speakers, etc.. Just HDMI/other inputs. Planning to use a PS3 or DVD player for all the content.
Your set looks nice tho. Glad you are happy with it.
racerxx is offline
post #374 of 2275 Old 08-06-2010, 11:44 AM
ElwayLite's Avatar
To be honest, this is my 3rd Panny plasma and Ive always been happy with them, and their support toward tv's and br players. They build a quality product that is reliable, at least in my experience.
The LG has a very good PQ, but their reliabilty is still a question mark for me, they have the worst measured blacks out of the 3 manufacturers, and their AR filter needs improvement.
post #375 of 2275 Old 08-06-2010, 11:53 AM
spivonious's Avatar
I also looked at the LG before buying my S2. It was the glare filter that sold it. The LG was like looking into a mirror.
spivonious is offline
post #376 of 2275 Old 08-06-2010, 11:57 AM
ElwayLite's Avatar
Another note on the break in process. When I started, I'd see a slight uniformity issue on some slides (blue namely), where especially from an angle, the blue would not be a uniform shade all the way across (very small areas;not obvious). These are almost faded now too, so I would assume it's the cells aging and becoming consistent.
post #377 of 2275 Old 08-06-2010, 12:16 PM
ElwayLite's Avatar
For anyone looking for a good screen cloth, I needed a new one, and just got this 3 pack in. Very good feel, and great price.
http://www.amazon.com/gp/product/B00...ef=oss_product
post #378 of 2275 Old 08-06-2010, 12:19 PM
racerxx's Avatar
Seems like the "main" thing that's missing from the S2 (vs. G25) is the PC input. But I'd imagine if you're running a media server you'll be outputting HDMI anyhow.
The 58" S2 is certainly a bit more compelling than the 54" G25. Is the "infinite black" really that noticeable?
racerxx is offline
post #379 of 2275 Old 08-06-2010, 12:30 PM
mustangs1's Avatar
Yes, very noticeable during the day. Infinite black is a combination of new Glare filter and new pre-discharge tech. The new filter is the biggest improvement, so better black during the day. At night, the new pre-discharge control helps as well, but it is more subtle, but still a little noticeable.
mustangs1 is offline
post #380 of 2275 Old 08-06-2010, 12:49 PM
ElwayLite's Avatar
I think the better AR filter would be the most noticed. Not a big measured difference in black levels, so Im sure the AR filter helps.
post #381 of 2275 Old 08-06-2010, 05:40 PM
shadymg's Avatar
I've downloaded the Sample Slides from D-Nice's, but i came across the webapalooza burn-in images from here: http://www.avsforum.com/avs-vb/showthread.php?t=1107017
Basically both do the exact same thing, right?
_________________________
Mike Garcen
Media Center MVP
MissingRemote.com - The Home for Home Theaters and HTPCs - Reviews, Blogs, Forums & More | Twitter @missingremote
shadymg is offline
post #382 of 2275 Old 08-06-2010, 05:49 PM
ElwayLite's Avatar
Same difference, I think the web ones might be 720p, but I dont think that matters. Big thing is that its FULL SCREEN color slides to properly AND evenly age the cells. In theory, if they are aged equally, over the whole screen, it gives a consistent picture over the whole screen. I think this really only would be important to someone getting the set calibrated, because the meter reads one small point on the screen. Being that you are adjusting the WHOLE screen to this point, you want them consistent. Regular tv viewing with lights and darks would age them separately. How big of a deal this is, I know no idea
I just run the 100 hours of slides, get my calibration and enjoy.
post #383 of 2275 Old 08-06-2010, 06:04 PM
shadymg's Avatar
thanks Elway, i kinda figured after looking at images on both, but figured i'd ask since i couldn't be the only one that wondered that :-) it took me 2 days just to get through all 13 pages here, my 50S2 is arriving tuesday....honestly not sure i can hold out for 100 hours, but really going to try. :-)
Mike Garcen
Media Center MVP
shadymg is offline
post #384 of 2275 Old 08-06-2010, 06:07 PM
ElwayLite's Avatar
No problem, ask away. This is my 3rd time breaking a panny plasma in, so I know the drill.
You hear a good bit of buzz on the white slides, but it generally diminishes as you get hours on it. Screen uniformity over each color will get better too.
It is tough to do! I have mine running off the SD card 24/7, and my 32" LCD on a stand in front of it. Ill be using a calibration disc finally, Monday night!
post #385 of 2275 Old 08-06-2010, 07:09 PM
ElwayLite's Avatar
This is how you break in a plasma with patience...Does this count as picture in picture??
post #386 of 2275 Old 08-07-2010, 12:05 AM
ChristianZ's Avatar
can i run the break in slides off a usb stick via my ps3 outputting 720/1080 ? or is the sd card necessary
ChristianZ is offline
post #387 of 2275 Old 08-07-2010, 12:47 AM
jbmcfl's Avatar
How do you check the hours for a TC-PxxS2 once in the service menu?
jbmcfl is offline
post #388 of 2275 Old 08-07-2010, 01:24 AM
shadymg's Avatar
LOL @ ElwayLite
Although pretty darned clever...might have to steal your idea...worry not, i'll give you credit ;-)
Man...can it be Tuesday already?!?!?! :-P
btw, i bought mine Refurbished...so it probably already has some hours on it. That shouldn't affect my burn-in process since most likely the previous customer didn't do it, right?
Ditto the above question on any way to see how many hours it's been used?
Mike Garcen
Media Center MVP
shadymg is offline
post #389 of 2275 Old 08-07-2010, 06:09 AM
ElwayLite's Avatar
The info is here in these Panny threads, just gotta do a little hunting for how to find it. The numbers are in decimal format, or hexadecimal, or something, so when you right them down, just go on Google and convert them to hours and minutes. Also will tell you how many times you've turned the TV on.
post #390 of 2275 Old 08-07-2010, 06:22 AM
ElwayLite's Avatar
For your hours, check this (courtesy of h-i-g-h-d-e-f-j-u-n-k-i-e-s.com):
Press and hold the {VOL -} button ON THE PLASMA.
Then press the {INFO} button on the remote control 3 times.
Press the {2} button once to select "SRV-TOOL".
And press the {OK} button to access it.
Using the cursor keys, select the right side
of the last option "PTCT :00.00.00.00.00" :
| TD2Microde: 81c0000f |
| Flash ROM: 1 - 227 e |
| PTCT :00.00.00.00.00 | * HIGHLIGHT HERE *
Then press and hold the {MUTE} button for 3 seconds.
Time and Count will be displayed in red color.
TIME = Hours : Minutes of operation.
(Hours shown must be divided by 256 to get the correct value)
COUNT = Times the Plasma was powered on.
To exit, press and hold the {POWER} button
on the Plasma for few seconds.
