The Official 2010 Panasonic Settings/Issues Thread - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 5014 Old 03-04-2010, 06:45 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE PANEL AGING THUMBDRIVE FILES****
Recommended 100 Hour Panel Aging settings for North American Panasonic TC-PxxS2/G20/G25/VT20/VT25 models (ONLY to be used with Evangelo2's Thumbdrive Files!!!!!!!!)
*****Note: This procedure is designed to equally and evenly age all pixels and ensure the reference settings listed below provide maximum satisfaction. This procedure is NOT designed nor recommended to be used as Image Retention and/or Burn-in prevention.*****
Photo Settings
Picture:
Picture Mode: Photo
Contrast: 100
Brightness: 50
Color: 75
Tint: 0
Sharpness: 50
Color Temp: Cool (Cool 2 on G20/25 and VT20/25 displays)
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Slideshow Settings
Display Interval: Slow
jackodagreat likes this.
D-Nice is offline
post #2 of 5014 Old 03-04-2010, 06:46 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
North American TC-PxxS2 Reference Settings
Picture:
Picture Mode: Cinema
Contrast: 71
Brightness: 60
Color: 47
Tint: G9
Sharpness: 0
Color Temp: Warm
x.v. Color: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Advance Options
MPEG NR: Off
Black Level: Light
3:2 Pulldown: On
Service Menu Offsets
WB-ADJ MENU
R-DRV: +5
G-DRV: -11
B-DRV: -11
R-CUT: -2
G-CUT: 0
B-CUT: +4
Note: These offsets must be entered for both Color matrixes. You access the different matrixes by using a 1080i/p signal for the HD matrix and 480i/p signal for the SD matrix. The WB Method Select option should be set to 00 instead of 03.
Calibration Report
AVS Panasonic TC-PxxS2 Post Calibration Report (Cinema).pdf 145.7607421875k . file
File Type: pdf AVS Panasonic TC-PxxS2 Post Calibration Report (Cinema).pdf (145.8 KB, 531 views)
D-Nice is offline
post #3 of 5014 Old 03-04-2010, 06:47 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
North American TC-PxxG20/25 Reference Settings
Picture:
Picture Mode: THX
Contrast: 57
Brightness: 56
Color: 49
Tint: 0
Sharpness: 10
Color Temp: Warm2
Color Management: Off
x.v. Color: Off
Photo Enhancement: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Advance Options
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 Pulldown: On
WB-ADJ MENU
R-DRV: -1
G-DRV: -8
B-DRV: +4
R-CUT: -8
G-CUT: 0
B-CUT: +3
Picture:
Picture Mode: Custom
Contrast: 87
Brightness: 68
Color: 35
Tint: -3
Sharpness: 11
Color Temp: Warm2
x.v. Color: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Pro Settings:
W/B High R: 0
W/B High B: +2
W/B Low R: +2
W/B Low B: -4
Black Extension: 0
Gamma Adjustment: 2.2
Panel Brightness: Mid
Contour Emphasis: Off
AGC: 0
Advance Options
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 Pulldown: On
Note: These settings must be used with the offsets listed for THX mode!!!!
Calibration Report
AVS Panasonic TC-PxxG20(25) Post Calibration Report (THX).pdf 144.78125k . file
AVS Panasonic TC-PxxG20(25) Post Calibration Report (Custom).pdf 147.10546875k . file
File Type: pdf AVS Panasonic TC-PxxG20(25) Post Calibration Report (Custom).pdf (147.1 KB, 467 views)
File Type: pdf AVS Panasonic TC-PxxG20(25) Post Calibration Report (THX).pdf (144.8 KB, 544 views)
D-Nice is offline
post #4 of 5014 Old 03-04-2010, 06:47 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
North American TC-PxxVT20/25 Reference Settings
Picture:
Picture Mode: THX
Contrast: 66
Brightness: 50
Color: 45
Tint: -1
Sharpness: 10
Color Temp: Warm2
x.v. Color: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Advance Options
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 Pulldown: On
WB-ADJ MENU
R-DRV: -1
G-DRV: -11
B-DRV: +4
R-CUT: +1
G-CUT: 0
B-CUT: -3
Picture:
Contrast: 90
Brightness: 57
Color: 39
Tint: 0
Sharpness: 11
Color Temp: Warm2
x.v. Color: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Pro Settings:
W/B High R: 0
W/B High B: -1
W/B Low R: 0
W/B Low B: 0
Red Hue: 0 (VT25)
Green Hue: 0 (VT25)
Blue Hue: 0 (VT25)
Red Saturation: 0 (VT25)
Blue Saturation: 0 (VT25)
Green Saturation: 0 (VT25)
Black Extension: 0
AGC: 0
Advance Options
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 Pulldown: On
3D
Contrast: 90
Brightness: 57
Color: 35
Tint: 0
Sharpness: 11
Color Temp: Warm2
x.v. Color: Off
C.A.T.S: Off
Video NR: Off
Blur Reduction: Off
Pro Settings:
W/B High R: -1
W/B High B: -5
W/B Low R: +8
W/B Low B: -2
(VT25)
Red Hue: 0 (VT25)
Green Hue: 0 (VT25)
Blue Hue: 0 (VT25)
Black Extension: 0
AGC: 0
Advance Options
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 Pulldown: On
Calibration Report
AVS Panasonic TC-PxxVT20(25) Post Calibration Report (THX).pdf 130.7880859375k . file
AVS Panasonic TC-PxxVT20(25) Post Calibration Report (Custom).pdf 135.4853515625k . file
File Type: pdf AVS Panasonic TC-PxxVT20(25) Post Calibration Report (Custom).pdf (135.5 KB, 417 views)
File Type: pdf AVS Panasonic TC-PxxVT20(25) Post Calibration Report (THX).pdf (130.8 KB, 460 views)
D-Nice is offline
post #5 of 5014 Old 03-04-2010, 06:49 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
D-Nice is offline
post #6 of 5014 Old 03-04-2010, 08:07 PM
PatEllis15's Avatar
Thanks D-Nice.
I'm expecting a 50G25 to arrive sometime next week. You've had the S2 for a little bit (Couple of week?!). When do you expect to get your hands on a G2X?
Look forward to reading your thoughts/impressions...
Pat E
PatEllis15 is offline
post #7 of 5014 Old 03-04-2010, 09:50 PM
nullpointerninja's Avatar
Sorry if this is a stupid question but why did you have your gamma target set at 1.9 for the S2?
Why not 2.22 or something close to that?
P.S. is it my idea or the cyan point was way off on a calibration report you posted some time ago? It doesn't look THAT bad now (or maybe I don't remember well...).
By the way, thanks for posting this.
nullpointerninja is offline
post #8 of 5014 Old 03-05-2010, 06:35 AM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Because the S2 is not capable of 2.2 and 2.2 is not the standard for gamma in the first place
That is a revised chart after I did additional tweaking.
D-Nice is offline
post #9 of 5014 Old 03-05-2010, 06:36 AM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Originally Posted by PatEllis15 View Post
Thanks D-Nice.
Pat E
I already have a G20. You will see any settings for that panel before next weekend.
D-Nice is offline
post #10 of 5014 Old 03-05-2010, 06:52 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Just for clarification, i presume the settings for the G20 would also pertain to the G25 correct?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #11 of 5014 Old 03-05-2010, 07:05 AM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Yes
D-Nice is offline
post #12 of 5014 Old 03-05-2010, 09:38 AM
Oh I always thought gamma should be set at 2.2-2.5. Isn't the point in calibrating the display to get as close as possible to a standard?
A gamma of 1.9 would make the display look very different to a display with 2.2-2.5, wouldn't it?
Maybe this is a bit off topic... sorry.
post #13 of 5014 Old 03-05-2010, 09:43 AM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Yes it would look different (and it does). However, there still isn't a defined gamma target (aka standard gamma) for digital displays.
D-Nice is offline
post #14 of 5014 Old 03-05-2010, 10:01 AM
Korvas's Avatar
Thanks a lot D-Nice!!!
Korvas is offline
post #15 of 5014 Old 03-05-2010, 10:06 AM
I didn't know that.
Well with a gamma of 1.9 at least the shadow detail should be good.
Thanks again D-Nice.
post #16 of 5014 Old 03-09-2010, 06:47 AM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
I presume that when using the SD Card into to display Evangelo's images, the Display Interval setting for the SD Card Slideshow should be set to "Slow" (for 30 second intervals just like the DVD has).
Randy
post #17 of 5014 Old 03-09-2010, 06:50 AM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Correct and thanks Randy. I'll add that to the post.
D-Nice is offline
post #18 of 5014 Old 03-09-2010, 02:05 PM
new plasma guy's Avatar
the settings you are going to post for the g20 . are they just for movei watching or every day hd tv programs ?? thanks
new plasma guy is offline
post #19 of 5014 Old 03-09-2010, 02:25 PM
jimthom1's Avatar
D-Nice: Sorry this is off topic, but I want to be sure you see it. Your old Elite 1140 settings were fantastic! Please see this other thread for my call for help. Also sent you a PM. Thanks!
http://www.avsforum.com/avs-vb/showt...php?p=18279904
Jim Thomas
jimthom1 is offline
post #20 of 5014 Old 03-09-2010, 04:09 PM
JREwing's Avatar
D-Nice,
I see that you suggest to change the WB Method to 00 instead of 03. Can you expand on what this does exactly and if this is only for the S2?
This is the first I have seen that so I'm curious if this applies for the 12g panels as well? I own a 54V10 and I was recently entering offsets and mistakenly changed the WB method, I did correct it back to 03 but wasn't sure what effect this would have, if any.
JREwing is offline
post #21 of 5014 Old 03-09-2010, 05:15 PM
stooge2677's Avatar
D-nice
Can you tell me if ther is any difference between G20 and G25 that would make me want to wait for one or the other. I know bout cam feature in G25 thats not avail on G20 but other than that are they same TV? I am thinking about buying the G25 tonight since the store only has that model and not G20?
stooge2677 is online now
post #22 of 5014 Old 03-09-2010, 06:28 PM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
D-Nice,
Can you tell us if there will ever be world peace?
Randy
post #23 of 5014 Old 03-09-2010, 06:45 PM
RobbyTV's Avatar
Quoted: 21 Post(s)
Randy:
do you plan on purchasing another Panasonic this year?
(a 2010 model)
and do you still fly RC airplanes?
RobbyTV is offline
post #24 of 5014 Old 03-09-2010, 08:17 PM
"Don't PM Me Bro"
Quoted: 527 Post(s)
Liked: 782
Originally Posted by RobbyTV View Post
Randy:
(a 2010 model)
Nah. My 46G10 still looks great and so far my pattern is to buy a new Plasma every two years. I'm going to hold out for a 2011 TC-P46GT40
Yup. I just flew my SR-7 Slope Sailplane in some big stormy air last Sunday and had a blast (here's a pic of someone else's SR-7 for reference):
http://static.rcgroups.com/forums/at...g?d=1228063373
Randy
post #25 of 5014 Old 03-09-2010, 08:22 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Originally Posted by JREwing View Post
D-Nice,
It allows one to calibrate Cool/Normal/Warm color temperatures independent of each other.
Yes.
D-Nice is offline
post #26 of 5014 Old 03-09-2010, 08:25 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Why would HDTV and Movie settings be different
D-Nice is offline
post #27 of 5014 Old 03-10-2010, 02:05 PM
i dont no thats why i asked . ??? your supposly the expert not me
post #28 of 5014 Old 03-11-2010, 06:38 PM
whatevs's Avatar
@D-Nice,
Thanks for posting this information.
Should I make these adjustments to my display after the 100 hour break-in, or do I use them right away.
My P50G25 arrived today! I've been running the break-in slides for a few hours.
Is there an issue with watching content that has short black bars on the top and bottom (via my VGA PC input) during this break-in period?
Thank you for your help.
whatevs is offline
post #29 of 5014 Old 03-11-2010, 06:40 PM - Thread Starter
D-Nice's Avatar
Quoted: 711 Post(s)
Liked: 1508
Originally Posted by whatevs View Post
@D-Nice,
If you are going to use my G20/25 settings, please follow post 1 to the T.
D-Nice is offline
post #30 of 5014 Old 03-11-2010, 06:49 PM
whatevs's Avatar
Just to be clear, you are recommending to not view anything else on the panel besides the break-in slides for the first 100 hours?
I have setup everything in accordance to your photo settings listed in post 1.
whatevs is offline
