Samsung PNXXc550 Owners Thread *NO PRICE TALK* - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2821 of 2875 Old 07-03-2015, 08:56 AM
Al Sherwood's Avatar
Quoted: 754 Post(s)
Liked: 277
Originally Posted by douglas-b View Post
Is this a row of dead pixels? Its on other inputs and it doesn't move.
Less likely to be dead pixels but rather a problem with the driver circuit or connection... generally a dead pixel is singular in nature, ie. one all by itself.
Al
Al Sherwood is offline
post #2822 of 2875 Old 07-03-2015, 01:30 PM
douglas-b's Avatar
Bummer...its already driving me nuts.
douglas-b is offline
post #2823 of 2875 Old 08-23-2015, 03:08 PM
Liked: 1
Sound-bar help please!!!
I purchased a new sound-bar and am having some issues. The component sound will not pass through the TV and play out of the sound-bar via a digital audio cable. Something so simple has caused me hours of grief and led me to this forum...
The technical info:
TV = PN58C550 running firmware version T-TDT5AUSC-1016.0
Sound-Bar = Energy Connoisseur CS-30
-Sound will play from the TV through the audio cable on another Vizio sound-bar.
-Sound will play from a Tivo box through the audio cable on the new sound-bar.
-The TV has a function "Sound Test" option in the "Self Diagnosis" menu. Sound will play from the TV to the new sound-bar with this setting.
-There is no sound from the Tivo, Samsung Blu-Ray, Chromecast through the TV to the sound-bar. The TV speakers work so I know the sound is getting through. I've gone through the settings on each component, but haven't found any settings that make a difference.
If someone out there has any ideas please let me know. I am very happy with the sound quality of this sound-bar. If I can't figure it out it's going back for another one.
t1j2f3 is offline
post #2824 of 2875 Old 08-23-2015, 03:37 PM
Quoted: 754 Post(s)
Liked: 277
The technical info:
Welcome! I think that it is a setting,
1) does the Visio sound-bar give sound when placed in the bolded situation above?
2) Does the new sound bar have setting, auto-on or something that is not sensing the incoming signal?
Al
post #2825 of 2875 Old 08-23-2015, 03:50 PM
Liked: 1
Thank you for the quick response!
1. The Vizio works as expected. Using the same settings the Vizio works and the Energy doesn't.
2. The new Energy sound bar has an auto-on setting that works. It turns on, but there is no sound from the components.
t1j2f3 is offline
post #2826 of 2875 Old 08-24-2015, 08:23 AM
Quoted: 754 Post(s)
Liked: 277
No worries.
Hmmm, that would almost lead me to believe that the sound stream coming from the TV might be in a format that the Energy sound-bar can't read?
Al
post #2827 of 2875 Old 08-28-2015, 10:04 AM
Liked: 1
Update
No worries.
First, thank you Al for your assistance and attempts to help. After hours of trying to get the TV/soundbar to communicate via the optical cable I gave up and connected it via audio cable/RCA plugs. The Energy soundbar still sounds great and is a huge upgrade over our previous setup. I picked it up 1/2 off at Best Buy for $300 and it went back up to $600 the following day. There is no better option out there for that price and I did not want to return it.
The issue I had was described as a communication problem between the software of each device. Each company, Samsung and Energy/Klipsch, blamed the other product for the issues.
Al Sherwood likes this.
t1j2f3 is offline
post #2828 of 2875 Old 09-09-2015, 05:16 PM
Liked: 0
I read some where on the forum that the [3D58]Logic.bin file can be used intstead of the [2D58]Logic.bin file for the PN58C550. Can anyone confirm this is true and have you successfully used it to update your TV?
speirss is offline
post #2829 of 2875 Old 09-11-2015, 10:12 AM
Quoted: 754 Post(s)
Liked: 277
Interesting question, what exactly would be gained? Long ago I change my C550 to a C590, I got a few more controls and menus, all was good, is there more to be had this late in the game?
Al
post #2830 of 2875 Old 09-11-2015, 12:25 PM
Liked: 0
This file refers to an update to the internal OS of the tv that seems to correct the pink banding issue common with these models.
speirss is offline
post #2831 of 2875 Old 09-11-2015, 01:11 PM
Quoted: 754 Post(s)
Liked: 277
Hmm to be honest I haven't noticed that problem on my set, maybe best not to look!
Where can you get the file?
Al
post #2832 of 2875 Old 09-11-2015, 03:00 PM
Liked: 0
There is a whole thread about this problem on this site; just search "pink banding". The file is available at
PN58C8000 Pink Banding thread on page 6
Although it says its for a 3D58; I was brave enough to load it on my 2D58 and I am happy to confirm that the update did work and that the banding has been about 098% eliminated..... happy camper!
I will probably do the voltage Vs adjustment at a later date.
speirss is offline
post #2833 of 2875 Old 09-11-2015, 03:30 PM
Quoted: 754 Post(s)
Liked: 277
And the location for that file? What is the original model of your set? Where do you see '2D58'?
Al
post #2834 of 2875 Old 09-13-2015, 06:17 AM
jhachey's Avatar
Quoted: 43 Post(s)
So has anyone tried the 3D63 file on a 2D63? I have done the voltage adjustment on my PN63C590, but I'd like to do the software update too and can't find a 2D63 file.
jhachey is online now
post #2835 of 2875 Old 12-14-2015, 11:41 AM
emerson1's Avatar
Quoted: 43 Post(s)
Liked: 25
So I went to put my trash and the dumpster and the 50" version of one of these was sitting out there (only been out for about 1.5 hours tops.
A sign on it said it works, but it has lines on the screen. I of course had to carry it (ow, my back) up to my place and test it out. I still need to get it hooked up, but I don't have much need for it.
Any chance a TV repair shop might give me $50 or something for it (parts, etc)? Or any chance it might be a sub $100 repair?
PN50C550G1FXZA is the full model number.
emerson1 is offline
post #2836 of 2875 Old 12-19-2015, 02:32 PM
Liked: 0
Hi guys. So I have a 63" Model:PN63C550G. The TV has done well over the years, however over the last 6 months a weird "curve" developed on the left side and over time, got larger and moved towards the center. You can still see through the curve imperfection, but it's got very annoying.
I waiting until this Christmas, waited for a black Friday deal and got a 65" UHD which is excellent (and it doesn't have this curve). Now I have this 63" that functions, but has this weird anomaly. I'd really like to think that with a board replacement, I can take care of this issue, but I have been on some different forums and have not had anyone able to give guidance of any sort if it's possible to repair...or worth it.
Anyone seen this type of screen failure before?
Pitster426 is offline
post #2837 of 2875 Old 12-19-2015, 02:36 PM
Liked: 0
post #2838 of 2875 Old 12-19-2015, 02:38 PM
Liked: 0
Apologies for the double post...
post #2839 of 2875 Old 12-19-2015, 03:32 PM
Quoted: 754 Post(s)
Liked: 277
Are you talking about that bright area in the middle of the screen?
Al
post #2840 of 2875 Old 12-19-2015, 09:10 PM
Liked: 0
Yes, that would be the area. It's a lighted curve from the top to the bottom.
post #2841 of 2875 Old 12-20-2015, 06:55 AM
Quoted: 754 Post(s)
Liked: 277
Wow, if it is on all the time then I would have guessed a physical hit to the screen, and if it is that, probably not worth fixing.
Hopefully someone else can chime in here.
Al
post #2842 of 2875 Old 12-20-2015, 07:07 AM
Liked: 0
Definitely not a hit. This started as a little black spot on the left side of the screen of maybe the size of a dime. It then started expanding to the right going from top to bottom, so over the course of 4-5 months, it basically grew slowly. You can see through the highlighted area. The highlighted area is noticeably HOTTER than the regular areas on the TV.
post #2843 of 2875 Old 12-20-2015, 07:12 AM
Quoted: 754 Post(s)
Liked: 277
With you comment about the affected area being hotter, I wouldn't run the display until a tech can look at it if you are hoping to have it repaired.
Keep us posted if you decide to have them look at it.
Al
post #2844 of 2875 Old 12-20-2015, 07:44 AM
Liked: 0
That's the thing..It's down and boxed now, was going to sell it on Craigslist for it to be someone elses problem, but now I am thinking about pulling it apart, looking for boards to start troubleshooting. Right now I'm looking for some direction as to others who may have had a similar issue, and what they replaced, if they went that far. Haven't had any luck in the last months though.
post #2845 of 2875 Old 11-07-2016, 11:14 AM
KingsFan6's Avatar
Quoted: 26 Post(s)
OK, this is the first post in over 10 months on this thread, so I hope people see this. Don't quite have the time to go through so many pages of the thread.
I have this PN50C550. I've had it since 2010. I have the "1014" firmware. Is this still considered the latest? I'll assume so, since it's what's available on the Samsung site.
What was the consensus regarding what the firmware does to 24p output, specifically for owners like myself who did not enter the service menu to "upgrade" to a model that has the Cinema Smooth option? Does it enhance 3:2 pull-down? I assume the set does 3:2 pull-down on 24p sources, but I'm not sure. Perhaps the firmware introduced 2:2 cadence to 24p?
I have a LG Blu-Ray player from about the same year. Would it be better to allow the BD player to output 24p and let the TV do the pull-down, or should I let the player do the pull-down instead?
KingsFan6 is offline
post #2846 of 2875 Old 11-07-2016, 03:07 PM
Quoted: 754 Post(s)
Liked: 277
You are right, not a lot of posts here of late, but then I'll bet very few of us still have these sets (I do!)... It stills has a great picture, we use this set (58C550 firmware'd to a 58C590) almost daily.
So I can't be sure but earlier in the thread I thought I had rad that on the C550 the latest firmware was 1017... Samsung PNXXc550 Owners Thread *NO PRICE TALK*
I actually went to the C590 firmware for the Cinema Smooth (24P) support, it has worked fine anytime I have used a BD player with it that fed 24p content. As for settings with your set, I would have to say try both and use the one that works the best.
Al
post #2847 of 2875 Old 11-07-2016, 04:38 PM
KingsFan6's Avatar
Quoted: 26 Post(s)
So upgrading via the service menu to C590 will give me Cinema Smooth. Will I lose anything as a result besides settings resetting to defaults? Will I end up defaulting back to whatever prior firmware I had (don't remember if I had something else before) and therefore would have to re-update again?
post #2848 of 2875 Old 11-07-2016, 05:14 PM
Quoted: 754 Post(s)
Liked: 277
As you know, this "upgrade" is not Samsung approved nor guaranteed by me, it is at your own risk... I and not sure that there would be anything else but "settings" to lose, what were you thinking?
When I did this 6 years ago it was (as mentioned) to get Cinema Smooth and access to turn on the ISF day/night settings. In one of the other threads (Calibration of the PN58C590) I posted that I saw judder with this option 'on'? But that was years ago and it might have been an interaction between the player and the TV, I think that I corrected it by using the 24P output from the player and allowing the TV to auto detect the incoming signal.
AFAIK when you change the setting to the different model your updates will be to the firmware for that model so you wouldn't default to the firmware you had, however I went only forward never back.
Best to read this thread and see what you think: Did I just turn my Samsung PN58B550 into a 560? Yes I did!
Any finally read this thread from here on, you will see my thoughts and results, it looks like there was a bit of an issue with 24p playback, but I am sorry I don't recall if we got to the bottom of it. I will say that I left the TV as a C590, the ability to save additional calibration setting was welcomed and you can always turn of CS if it doesn't work for you r configuration. Did I just turn my Samsung PN58B550 into a 560? Yes I did!
Al
post #2849 of 2875 Old 11-07-2016, 05:25 PM
Quoted: 754 Post(s)
Liked: 277
I guess that the question I should have asked at the very onset was, do you like the way the BD plays back the picture at 60p, if so why worry about 24p?
AS for the question about feeding the TV 24p or 60p why not try both and settle on what looks best, no danger that way playing with firmware, this is a very old set and as good as mine still seems to be I don't think I would mess with it too much, just enjoy it the way it is.
Al
post #2850 of 2875 Old 11-28-2016, 01:04 PM
ItzMe's Avatar
Quoted: 30 Post(s)
I have the same line going vertical, 1 pixel wide. Has anyone came up with a fix? My D8000 has a wipe tool, but I don't see anything like that in my c550. Except for that line I'm still loving this old plasma!
ItzMe is offline
