Any one use XBOXLive program to break ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-24-2010, 04:31 PM - Thread Starter
BigMERF's Avatar
Any one ever use this to break in there plasma?
http://marketplace.xbox.com/en-US/ga...-d8025855023a/
I have it runnning on my brand new Pannasonic TC-p42c2 since 6pm est. (yes i just came home with it)
Forgive my newbieness but is there anything i should have done to my tv to prep it for this program? I didnt touch any of the settings other than to make sure its on the standard viewing
the contrast and brightness are both at 50 percent
BigMERF is offline
post #2 of 13 Old 03-24-2010, 05:42 PM
dlplover's Avatar
Why pay for it when you can use the slides for free?
dlplover is offline
post #3 of 13 Old 03-24-2010, 06:42 PM - Thread Starter
BigMERF's Avatar
it was oponly 80 ms points, thats like a dollar.. lol
BigMERF is offline
post #4 of 13 Old 03-24-2010, 06:45 PM - Thread Starter
BigMERF's Avatar
can someone please advise me bu the way whether i should have the brightness and contrast at a 100? please
BigMERF is offline
post #5 of 13 Old 03-25-2010, 09:21 AM - Thread Starter
BigMERF's Avatar
so many views and not one piece of advice?
BigMERF is offline
post #6 of 13 Old 03-25-2010, 09:28 AM
sadmaker's Avatar
Originally Posted by BigMERF View Post
so many views and not one piece of advise?
I believe the higher the contrast, and brightness around 55, breaks the set in a bit quicker(100-120 hours as opposed to 150-200 hours). But yeah, I think your set has a SD card slot. Id use it rather than risk the xbox failing(as many have done) and getting burn-in at least or serious IR.
XBL Gamertag: RagingPhinsFan
sadmaker is online now
post #7 of 13 Old 03-25-2010, 12:37 PM - Thread Starter
BigMERF's Avatar
do you have the link for the slides? thanks
BigMERF is offline
post #8 of 13 Old 03-25-2010, 01:10 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
you leave your xbox on all day?? brave man... what if it red rings on you?? Modern plamas require no break in. Just watch the tv normally.
Goatse is offline
post #9 of 13 Old 03-25-2010, 01:22 PM - Thread Starter
BigMERF's Avatar
i found it . honestly the 3 rings wouldnt be bad, lol. microsoft would either fix it but more likely send me another for free. im still within the 3 year fix window. Plus the disc drive is not running for the break in, its not a disc. but i did cave and dl the file and use the sd card method. i forgot about 1 thing, power.. less electricity.. lol
BigMERF is offline
post #10 of 13 Old 03-25-2010, 01:29 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
xbox would freeze on one color.
Goatse is offline
post #11 of 13 Old 03-25-2010, 02:24 PM - Thread Starter
BigMERF's Avatar
it didnt freeze at all.. stood on all night cycling through the colors
BigMERF is offline
post #12 of 13 Old 03-25-2010, 02:36 PM
dlplover's Avatar
So one of the reasons I encourage the breakin slides is that they're something put together by the community to help each other out. Whoever put it on xbl basically just took something public domain and is charging people for it, plus I doubt whoever made the app has good programming form. With slides there's no potential programming glitches that could freeze things up.
dlplover is offline
post #13 of 13 Old 03-25-2010, 05:03 PM - Thread Starter
BigMERF's Avatar
i gotcha!!! its currently running as we speak. the one the community provided that is. xbox is off
BigMERF is offline
