The Official Samsung PNxxC6500, PNxxC7000, and PNxxC8000 Owner's Discussion Thread - Page 266 - AVS Forum
post #7951 of 7964 Old 09-15-2014, 12:01 PM
RUBiK's Avatar
My PN63C8000 purchased in September 2010 has had the pink banding issue for over a year (maybe longer, honestly can't remember when I first noticed it) and had been progressively getting slightly worse over time (wider/taller pink banding on white backgrounds).
I meant to look into the self-fixing a few times but never got around to it.
Anyway, last night, while my wife was watching TV, she said the screen "went all white" and then shut off on her. She thought a fuse might have popped in the circuit breaker in the garage and asked me to check, but that wasn't it -- AVR, DTV receiver and everything else plugged into same outlet still got power.
It was late at night and I didn't get a chance to test much but it looks like the TV still powers on/off and responds to remote commands (because I can see the red LED go on/off/flicker properly) but the screen no longer lights up.
Now, I've obviously had the TV for 4 years and there's no extended warranty (even if there was, it would have ran out by now), I'm not sure what to do.
Should I just call Samsung and see how much it costs to have a technician come out and take a look? How much does the initial visit cost (just to have it looked at)? If it's more than $100 or so, I'm not sure it's even worth it at this point? Ugh... kind of bummed that this TV only made it 4 years but if it's going to need a new panel, it's definitely cheaper to just buy a new TV, right?
Any opinions/feedback on this or any what-would-you-do advice would be greatly appreciated.
Thanks much in advance.
khaosic_lord likes this.
RUBiK is online now
post #7952 of 7964 Old 09-16-2014, 07:39 AM
smpte's Avatar
I was able to program the access codes into a universal remote. The Logic USB D/L fails however. The tech that came out prior had the same result. Must be doing something wrong...
smpte is offline
post #7953 of 7964 Old 09-17-2014, 05:30 AM
Randy Carbone's Avatar
SMTPE - Can you share the access codes here. I would like to try on my set.
Randy Carbone is offline
post #7954 of 7964 Old 09-17-2014, 02:55 PM
smpte's Avatar
The hex code for the service IR code is:
0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0689
Use the info button on the TV's remote and then hit the above service code.
Needless to say use this access at your own risk. Playing around in the service menu can do irreversible harm.
smpte is offline
post #7955 of 7964 Old 09-19-2014, 05:21 PM
jskang's Avatar
Ruh-roh
So, the other day, I turned on my PN50C7000 and saw the attached image. It's on all inputs as well as on the TV. I had hoped disconnecting the power for a time and turning it back on might help (wishful thinking I know). It shows up as a black line here. But, depending on the content on the display, the color changes. This means the panel is going bad, right?
jskang is offline
post #7956 of 7964 Old 09-23-2014, 07:24 PM
Liked: 1
Purple banding fixed!
I believe I have fixed the purple banding issue with my Samsung! Note this works for my 58 inch because that is the only USB file currently available.
Read over the "service bulletin"
I needed the previous post to get the USB file on a stick found here:
Originally Posted by BigMiggen View Post
Well here you go. Samsung tech was just here and brought the firmware for pink banding on his usb drive. He forgot to create a folder as the service bulliten says so he had me do it while he was playing in the service menus. When he wasn't looking I copied the file. it is the 3d 58 inch firmware. I have a pn58c6500 and the 3d version does indeed work on my tv as stated in the service bulliten(although my tv isn't 3d). Sorry for all you guys with the 64 inchers. I only have the 58 inch 3d firmware. By the way, the firmware was enough, didn't need to adjust the voltage. Mine is 209.4v from the factory by yhe way.
This site wont let me attach a bin file so here is an external link to download it.
I believe you need a factory remote for the firmware update but here it is anyways.
Not able to post link. It is a couple of posts back.
READ THIS: Make sure cross check the service bulletin for your model #. This is the [3D58]logic.bin version. Dont forget to create a folder on your usb drive and also rename the file according to the service bulliten.
Then I needed to add the hex code into my harmony remote using this:
Instructions for applying hex code to Harmony remotes here: (But there are other ways with other remotes)
http____forums.logitech.com/t5/Harmony-Remotes-Programming/Adding-Pronto-Hex-codes-myself/td-p/406224
Plug your USB stick into your TV's USB.
Enter Factory mode by using the TV remote and while powered off hit - MUTE, 1, 8, 2, POWER.
The factory menu pops up.
Hit the programmed hex code on your Harmony (or other programmable remote)
Screen will flash some solid colors on the screen.
Hit the programmed hex code a second time to escape the color flashing screens.
When the Factory menu comes back you find that there are new submenus that were not there before.
Enter Control/PDP Option
Turn Logic Connect to ON.
Scroll down to Logic USB D/L and right arrow to upgrade.
When the upgrade is complete the TV will turn off.
Best of Luck
ambesolman likes this.
khaosic_lord is offline
post #7957 of 7964 Old 09-23-2014, 08:46 PM
ambesolman's Avatar
Quoted: 246 Post(s)
Liked: 397
^^^^ make that a sticky!
Sent using Tapatalk since the mobile version is still [emoji107]
ambesolman is online now
post #7958 of 7964 Old 09-24-2014, 04:09 AM
smpte's Avatar
I can get into the menu just fine but when I try to update it comes back fail. Tried 2 different sticks still no love. Did you do something special when you copied on to the stick. I must be missing a step even though I followed directions and turned on the Logic connect. Any help is appreciated.
smpte is offline
post #7959 of 7964 Old 09-24-2014, 04:22 AM
Liked: 1
Did you rename the file to exclude the brackets? The file should be called Logic.bin and it should be in a folder called PDP_LOGIC
I also formatted the stick to FAT32 with nothing else on it.
Hope this helps.
post #7960 of 7964 Old 09-25-2014, 07:07 AM
smpte's Avatar
Tried Fat32, reboot TV, 2 sticks still no joy. Comes back fail. There must be another factor or setting interfering. Has anyone else had success?
smpte is offline
post #7961 of 7964 Old 09-25-2014, 04:58 PM
Liked: 1
I would try two other things:
Under Options/Factory Reset (this should reset to how the TV arrived originally)
Under Control/Config Options I would make sure that Num of USB is not at zero (mine is at 2). USB might have been disabled at one point.
One more thing that I was curious about. When you are in normal TV mode and you plug in the stick does it recognize it and a pop-up menu asks you it you want to play media from it?
post #7962 of 7964 Old 09-26-2014, 06:39 AM
smpte's Avatar
USB does pop up fine and mine is set at 2. Tried factory reset still failed.
smpte is offline
post #7963 of 7964 Old 09-26-2014, 02:37 PM
RUBiK's Avatar
Finally had authorized service place come out to take a look.
Seems like Y (Sustain) Main board and the 2 (Buffer?) boards attached to it need replacing to get the screen to come back on.
Was quoted ~$450 for the parts (which seem to be ~$100 ordered brand new online) and ~$200 for the labor.
I don't think there's any way I'm going to spend $600+ to have them fix it but I am very tempted to spend the ~$100 to order the boards myself and put them in.
Has anyone replaced some of these boards themselves? It just looks like it's a few screws and ribbons and doesn't look too difficult of a task to replace...
Also thinking about giving Samsung another call to complain (about the red banding issue) and see if there's any way they'd cover any of these board replacements out of warranty but I'm guessing they'll just laugh at me?
RUBiK is online now
post #7964 of 7964 Old 09-28-2014, 10:31 PM
toddcurry's Avatar
Have had purple band for a while.
Just switched picture mode from Dynamic to Standard and turned Eco mode off. Purple band is now gone.
Can others confirm that this works? And/or advise on why this isn't a decent "solution" given hassle / cost of Sammy service (and fully respecting others' opinions -- just want to know trade-offs here).
TC
toddcurry is offline
Samsung Pn63c8000 63 Inch 1080p 3d Plasma Hdtv
