The Official Samsung PNxxC6500, PNxxC7000, and PNxxC8000 Owner's Discussion Thread - Page 267 - AVS Forum
post #7981 of 7999 Old 12-07-2014, 03:14 PM
drvasek's Avatar
Quoted: 16 Post(s)
Liked: 0
Originally Posted by linflas View Post
I found this link when searching for how to get the codes into my Harmony Ultimate. The "factory" code there differs slightly from the one here so I would trust the one here since it appears to apply to our sets. Not sure what the 3Speed thing is, maybe someone more familiar with the tech details could enlighten us? I just emailed the codes to myself and copied/pasted them into the app on my HTC. Haven't gotten up the nerve to actually try using it yet so can't verify that it or the solution works. My set has had the panel replaced once and the 2nd visit a voltage adjustment was done but the pink has recently started to return again. Sad as I really like the picture on this set otherwise.
http://wiki.samygo.tv/index.php5/How...%2B3SPEED_keys
Thanks for the link, I was able to fix my set using an app on my galaxy s4 to access the firmware update and then a voltage adjustment. I will post up my details here when I get some more time.
drvasek is offline
post #7982 of 7999 Old 12-10-2014, 12:23 PM
dankfoot's Avatar
Originally Posted by dankfoot View Post
So you guys are doing this instead of the voltage adjustment on the back?
Also, I have the 63C8000 is there no fix for this yet?
Anyone??????
Sammy PN63C8000
Onkyo TX-SR605
HR44-700
HP-T5064 Still going
dankfoot is offline
post #7983 of 7999 Old 12-11-2014, 11:29 AM
Liked: 1
Hello everyone.
I have the same problem with my 58" Samsung plasma and I've been following this forum for a while. I did the voltage adjustment (changed Vs from 210 V to 213 V) and it helped a lot, the main purple band disappeared and the image is a lot better, however the problem is not 100% solved as a much lighter band remains (barely noticeable, nobody notices it but me of course). I'm considering buying the Samsung service remote control to access the 'advanced' service menu on the TV and do the firmware update, but I'm not sure if doing this will solve the problem 100%... in other words I'm not sure whether to spend the money unless it will completely solve it. For those who have done the update: what's your experience? Does the firmware update solve the purple banding completely?
Daniel
Captain Dan 8 is offline
post #7984 of 7999 Old 12-15-2014, 11:44 AM
Liked: 2
I found the service bulletin ASC20130528001, but can't find the LOGIC.bin file for me PN63C8000. Does anyone have a link for the [3D63]LOGIC.bin file?
Jim Smith 2 is offline
post #7985 of 7999 Old 12-15-2014, 07:09 PM
Myron_H's Avatar
I have a PN58C550 and need the [2D58]LOGIC.bin. Anyone have it?
Myron_H is offline
post #7986 of 7999 Old 12-16-2014, 08:07 AM
hobbs47's Avatar
Quoted: 80 Post(s)
Liked: 137
Per this post:
He stated the 3D .bin worked for his 2D model. Download link provided as well. Good luck.
I am going to try the update tonight on my 3D 58" that has been collecting dust in a spare bedroom. I programmed the HEX file into my Harmony One
and it allowed me into the extra options in the service menu. I just didn't have a thumb drive (I always have those damn things around until I need it). lol
hobbs47 is offline
post #7987 of 7999 Old 12-16-2014, 08:35 AM
Myron_H's Avatar
Originally Posted by hobbs47 View Post
Per this post:
Yes, I've already tried the update on my TV, and my TV will not take the update. Update not applicable. Which is why I need the 2D version that actually has my model of TV listed.
Myron_H is offline
post #7988 of 7999 Old 12-16-2014, 06:56 PM
hobbs47's Avatar
Quoted: 80 Post(s)
Liked: 137
Got my 58" updated. Thanks so much to the posters who shared the firmware and instructions. There is no way these updates shouldn't be available to the consumer. Anyway, appreciate the effort guys!
hobbs47 is offline
post #7989 of 7999 Old 12-16-2014, 07:56 PM
Liked: 1
No need for service remote, harmony one, etc
In the 'regular' service menu (mute-1-8-2-power):
Control > Hotel Option > Hotel Mode > ON
This will enable the 'PDP Options' and upgrade can be run as described in the service report without any hex codes, 3speed, harmony control, etc (just used the TV regular remote).
However, the upgrade did not solve the problem 100%, a barely-noticeable purple band still exists, but image is a LOT better.
Good luck.
McGriddle likes this.
post #7990 of 7999 Old 12-17-2014, 02:26 PM
Liked: 2
I have the PN63C8000 and I called Samsung for repair and referenced the service bulletin. They would not acknowledge the service bulletin but after 1.5 hours the ECR finally gave me a one-time accommodation for the repair. Today The technician came out and updated the Logic firmware and the pink band is not noticeable at all right now. He did not crank up the voltage and said the LOGIC firmware update usually fixes this problem. I have 90 days on the repair so if it comes back I'm covered for 3 more months.
post #7991 of 7999 Old 12-17-2014, 02:28 PM
Liked: 2
Here is the LOGIC.bin file for the PN63C7000YFXZA or PN63C8000YFXZA
http://www.mediafire.com/download/el...v8yb/LOGIC.bin
hobbs47 and McGriddle like this.
post #7992 of 7999 Old 12-17-2014, 10:32 PM
hobbs47's Avatar
Quoted: 80 Post(s)
Liked: 137
Good job! Although I have the 58" and have done the update successfully, lots of people looking for the 63" file.
hobbs47 is offline
post #7993 of 7999 Old 12-18-2014, 04:31 AM
esperado's Avatar
I need this as well. I already had a panel replaced under warranty about 3 years ago due to this issue. I really hate having to deal with customer service, but I might as well bite the bullet. Hopefully I can get this serviced without spending too much on the repair.
esperado is offline
post #7994 of 7999 Old 12-18-2014, 09:09 PM
McGriddle's Avatar
Good luck.
Captain Dan- I just tried this method but "PDP Options" did not come up when I turned Hotel Mode to "On." Is there some other trick to this? I'd love to be able to do this without resorting to getting a factory service remote or hex codes. Thanks!
McGriddle is online now
post #7995 of 7999 Old 12-19-2014, 08:33 AM
longfta's Avatar
McGriddle,
Select clone TV to USB under Hotel mode. After it completed you should be able to see the PDP option.
I just did it actually fixed my Purple Banding issue.
Thanks to this forum.
longfta is offline
post #7996 of 7999 Old 12-19-2014, 05:08 PM
McGriddle's Avatar
Originally Posted by longfta View Post
McGriddle,
Wow, that did the trick! Thanks longfta and Captain Dan. I can verify that this procedure worked for my 63c8000. Also, thanks again Jim Smith 2 for posting the logic.bin file for the 63 series.
This has solved almost all of the pink banding issue for my set. There's still a slight remnant of the issue, but it now looks more like slight IR as opposed to the horrid pink band! I've also noticed that the pixel shimmer and sparkle that had been present since the beginning is now almost completely gone.
Anyway, thanks everyone! I really appreciate the help (and a lot of saved money!) by the folks on this forum.
post #7997 of 7999 Old Yesterday, 10:08 AM
Myron_H's Avatar
My PN58C550 TV was still under an extended warranty through Best Buy. Geek Squad came out with the correct Logic firmware file, and updated it. TV looks good now. No more pink/purple banding.
Myron_H is offline
post #7998 of 7999 Old Today, 06:44 PM
Liked: 0
So I tried CONTROL SETUP and PDP options did not come up either.
And all options on HOTEL menu are blocked...
Any sugestions ?
ETMTOM is offline
post #7999 of 7999 Old Today, 09:00 PM
McGriddle's Avatar
Any sugestions ?
ETMTOM--From earlier posts: To get to the factory menu, first turn off your tv, then hit: mute, 1, 8, 5, and then power. The TV will turn on and the factory menu will be up. Now you should see "Hotel" under "Control." Turn Hotel to "On" and then find and hit Clone TV to USB. Now PDP options will be available and you can upgrade. Be sure to follow the instructions on the service bulletin linked a couple of pages back and use the correct Logic.bin file. Good luck!
Samsung Pn63c8000 63 Inch 1080p 3d Plasma Hdtv
