The Official Samsung PNxxC6500, PNxxC7000, and PNxxC8000 Owner's Discussion Thread - Page 272 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #8131 of 8143 Old 10-13-2016, 02:44 PM
raha613's Avatar
Originally Posted by thomasbeau View Post
I discovered that it was the logic board that bricked because the firmware failed. I found the logic board on eBay for $5.00. Took apart the TV and swapped it out. Took about an hour to do, lots of screws on the back panel but very easy. No soldering, just some ribbon cables to swap out. My wife was angry because I already replaced the TV with a new 65" LG 4K 3D. She'll get over it soon. Plasma is now in my man cave.
Tom
Wow, thank you so much for the quick reply! This stinks... at least the TVs not complete garbage but this means I have another project and have to wait for the board to be delivered
raha613 is offline
post #8132 of 8143 Old 10-13-2016, 03:21 PM
raha613's Avatar
Tom
Tom,
When you got your replacement board and installed it, did you still have the pink banding issue? Did you attempt to install the LOGIC.bin again?
Thanks for your help!
raha613 is offline
post #8133 of 8143 Old 10-13-2016, 05:53 PM
thomasbeau's Avatar
Liked: 0
Pink Banding
Originally Posted by raha613 View Post
Tom,
My pink banding was better but not cured 100%. I still see some on very white backgrounds. I didn't have the nerve to attempt another flash and wipe out the logic board for the second time. Other than extreme white backgrounds I can't see the banding so I can live with it.
Tom
thomasbeau is offline
post #8134 of 8143 Old 10-17-2016, 04:27 PM
raha613's Avatar
Tom
I got my logic board in the mail today and the TV works again. I should have access to the GSPN within the next day or two and will report back on what happens when I try to load the correct [2D58]LOGIC.bin. I also paid $5.00 for the board and I wouldn't attempt using the wrong LOGIC.bin again but I can't not try with the correct one. Obviously they released separate versions for a reason.
On another note I did move 'Vs' value up to 213 like the document specifies and the pink banding DOES mostly clear up. I turned it back down to 210 and will adjust accordingly after I apply the update. Stand by.
raha613 is offline
post #8135 of 8143 Old 10-17-2016, 08:21 PM
thomasbeau's Avatar
Liked: 0
Great! Very happy to hear the TV is working again. Keep me updated. Very interested in knowing where your next attempt gets you. Good luck.
Tom
post #8136 of 8143 Old 10-17-2016, 08:29 PM
vice86's Avatar
always wondered what that pink/purple stuff was when the screen was white! Now I know. Had some boards replaced about 4 years after buying it and don't notice it much anymore.
vice86 is offline
post #8137 of 8143 Old 10-25-2016, 08:47 AM
raha613's Avatar
It is a super PITA to obtain this file. I am a business, deal in electronics and am now a Samsung Partner but unless I have a certified Samsung TV technician on staff they wont grant access to the GSPN. I have access to the GSBN but unfortunately that is a different portal. Might just have to pay the Best Buy guys $100 bucks to get it done.
raha613 is offline
post #8138 of 8143 Old 10-27-2016, 11:17 AM
raha613's Avatar
And just when I was about to give up I saw 'Samsung' pop up on my caller id . After frying one logic board with the wrong Logic S/W file (LOGIC.bin) and countless hours spent trying to obtain this file, I finally have it.
Previous to having this file I turned the Vs up to 213 and the purple nearly disappeared however I turned it back down to 210 as set from the factory because I felt the right way to do this was to follow the documented Samsung instructions.
I applied the 2D58 Logic S/W file today using the hotel mode workaround and it worked just as expected... Perfectly! No voltage change necessary at this time, the pink banding is gone!!!
In summary I suggest that you ONLY install the CORRECT Logic S/W file for your TV unless you want to start replacing parts. While using Logic S/W files meant for other TV models worked for some people, there is no guarantee it will work for you. It didn't for me and I was left with a dead TV which was working ok before. The only reason I knew to replace the logic board is because @thomasbeau was still monitoring this thread months later and was nice enough to share what he had found. Big shout out to him. In addition thank you to the rest of the members involved in this thread, without you we would all be stuck paying $100-$300 to fix a known issue.
I leave you with the file some have been waiting a long time for. Use it at your own risk. One thing to take note of is that the upgrade process takes a few minutes. Be patient and do not unplug or turn off the TV during the process. It will restart automatically and after the restart give it approximately one minute before you do anything else (the red power light flashes during this time). Good luck!
http://www.mediafire.com/file/nvbf2qebkt7yan2/
raha613 is offline
post #8139 of 8143 Old 11-14-2016, 02:45 PM
Liked: 0
Hey guys, I just wanted to say, i've had the purple banding issue on my PL58C8000 for about three years now, and I thought it was just panel damage. I made no attempt to fix it. However, today I guess I was so pissed off that I decided I would attempt to fix the issue, and if I failed, I would buy a new tv. Well, I found the samsung service buliten and the 3D58 bin file. I got the hex code for the service menu, and plugged it into my LG G3's IR blaster. I updated through the service menu. And now, my TV has been rid of this plague, the screen purple no longer. Thanks to everyone (two years later) who got this process working!
yewunkazzo is offline
post #8140 of 8143 Old 11-22-2016, 07:59 PM
Junkhead's Avatar
Glad I checked up on this thread, been about 3 years since I have visited it. I have had my PN63C8000 since 2011 and overall pleased with it. But I have Lazo started started seeing the pink banding on the bottom of the screen during white screens.
What bothers me more is that during a dark scene, be blacks or any other color you can vaguely see like a snowy background. It seems like thousands of random pixieish flashing white off/on in a random pattern. It's most noticeable right when you turn the tv on and the screen is still black. This has been going on for years and I'm not sure if was there when I got the tv it's been happening for so long now. It's my first plasma display, is this normal?
Ordered a Samsung 65" KS8000 through the Samsung EPP site Sunday. For $1079 shipped it was to hard to pass up, waking up Sunday morning I had no clue I would be buying a new tv lol. This replaces an old Sony DLP 60A3000 that's been chugging along in my finished basement for about 10 years now. Been looking to upgrade that for awhile.
I plan on replacing the PN63C8000 with an OLED most likely in February or March. It's been awhile since I looked at new TV's obviously but it's seems like the market has changed completely. Is it just me or you don't need to spend 2-3k+ anymore? There are tons of options out there now.
Junkhead is offline
post #8141 of 8143 Old Today, 01:40 PM
Quoted: 36 Post(s)
Liked: 5
Mine does the sparkles too. I don't think its normal but I've seen others say theirs does it too. LG OLED B6 is what you should get.
Test Ickles is online now
post #8142 of 8143 Old Today, 01:49 PM
Quoted: 36 Post(s)
Liked: 5
So I went ahead and installed the LOGIC file on my 63C7000 (updated to 63C8000 via service menu) even though it didn't seem to have the pink banding. If you looked hard enough at a white background it wasn't perfect but now not a hint of any pink.
The other issue I have with this TV is the blacks are washed out. There is a bug with this set where if you go into game mode when you come out of it the blacks are washed out. I've tried the motion judder on/off trick and a factory reset but I can still tell they're washed out. I have to turn on dynamic contrast and set hdmi black level to low in order for the pic to look good. Anybody notice this or got a fix?
post #8143 of 8143 Old Today, 01:55 PM
Liked: 0
Ps58c6500
I've been living with the purple banding / hazing since I purchased my ps58c6500 second hand two years, but was slowy getting worse (where I thought it was time to replace) until I happened to stumble across this forum. All I can say is thankyou as the logic file has completely fixed the problem!!!
Just a couple of things I had to do differently:
I could get into Hotel Mode (But everything was greyed out "...").
After a trying a few things, I thought as i'm only using an external YouView HDMI set top box, try plugging ariel cable into TV and tune.
Once complete mute 1-1-9 enter and there was my fully enabled hotel mode!
Next, trying to get into the service menu PowerOff,MENU 1-8-2,PowerOn wasn't working
Found the SamyGo Engineering Codes Wiki - PowerOFF,Info,Menu,Mute,PowerOn - Bingo!
Next "Control \ Hotel \ Clone TV to USB" and the "Control \ PDP" menu appeared but no Logic USB D/L???
Finally found option appeared after doing "Control \ Hotel \ Clone TV to USB" then go to "\ SVC \ Logic USB D/L" <- Possibly because i'm still on Firmware 3005.1???
As per the service bulletin even though my PS58C6500 isn't 3D, the matrix say use [3D58]Logic.bin and confirm this worked for me!
lollett is online now
Samsung Pn63c8000 63 Inch 1080p 3d Plasma Hdtv
