Scratched PLASMA = BETTER PICTURE - AVS Forum | Home Theater Discussions And Reviews
Old 04-10-2010, 07:37 AM - Thread Starter
ineedsocks's Avatar
Well last week my kids scratched the screen on my Panasonic PZ80U.
The scratch was major - approx 30" length, deep enough to catch and hold your fingernail.
The replacement glass from Panasonic is over $600 - not worth replacing.
After reading through the forums & purchasing the service manual I decided to remove & replace the filter/glare coating myself.
I removed the front glass front the plasma, laid on my work bench and removed the filter with a razor blade. The filter is approx 1mm thick - very thick, designed to prevent the screen from breaking (TUF Panel).
There are actually 2 coatings:
1 - Clear plastic with reddish/copper dots on plasma side.
This layer covers the entire glass panel.
2 - Tinted filter with antiglare coating on screen side
Covers the visible area only.
There appears to be only a tinting effect when looking though the 2 filters, colours do not appear to shift. The panel is wrapped with conductive tape which is in contact with the first layer.
I cleaned the panel thoroughly with acetone to remove residual glue.
I then applied a 35% VLT window tinting film to the viewing side of the glass and reassembled the TV.
Impressions After replacement
GOOD
  1. Picture is much more dynamic
  2. Whites are significantly brighter - particularly on full screen white
  3. Blacks are actually blacker
  4. Visible detail is improved - no scattering effect from the antiglare coating
  5. Colours are more natural - had to sift tint from 0 to -10, but according to DVE filters it is set correctly @ -10
BAD
  1. Small dust specs caught between glass & tint - unavoidable, but only visible at less the 12"
  2. Reflections from screen during full sun make viewing past 60deg difficult - not an issue with my layout
  3. Possibilty of breaking the glass is increased - no more TUF panel
Overall, I thought my kids broke my TV, but afterwards I would say they made it better!
This impression is shared with my wife - her comment after replacement was "WOW, that looks so much better than before!"
Mike
ineedsocks is offline
Old 04-10-2010, 08:02 AM
anthead's Avatar
GOOD
BAD
Mike
Ive read on here of another guy replacing the glass him self and I think he also said it made it better... Got any pics?
anthead is offline
Old 04-10-2010, 11:54 AM
surap's Avatar
"3. Blacks are actually blacker"
Very interesting.
surap is offline
