How to MASTER RESET Panasonic TC-P50V10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-11-2010, 06:11 PM - Thread Starter
darshan_4's Avatar
Hey guys i bought the demo unit of TC-P50V10
every few min the tv keeps going in to demo mode...
anyway to change that? i would much rather prefer to do a MASTER reset...
the reset to default setting only does the menu and picture settings
here's the page 16 of the manual...
but its not working... this is what ive done...
1) turned off the tv
2) pressed the power button n the tv
3) unplugged from the back of the TV set it while holding the POWER button
4) pluggin in the power cord while still holding the power button
NO USE
did the exact same thing again while releasing the power button while plugging in the power cable
what am i doing wrong?
darshan_4 is offline
post #2 of 9 Old 04-11-2010, 06:31 PM
frito's Avatar
try this
menu button> setup> arrow up once > reset to default
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #3 of 9 Old 04-11-2010, 06:57 PM - Thread Starter
darshan_4's Avatar
this is the reset i was talking to you about in my initial post...
it only resets the picture settings... and stuff...
like as is i cant even access the "timer" option in menu with the "store" setting that its currently on
post #4 of 9 Old 04-11-2010, 07:45 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 498 Post(s)
Liked: 766
2) pressed the power button on the tv
4) pluggin in the power cord while still holding the power button.
NO USE. did the exact same thing again while releasing the power button while plugging in the power cable. what am i doing wrong?
I don't think you're doing it exactly as the manual says to do it.
All you have to do is turn the TV on, then either press and hold the front Power button on the front of the TV for several seconds until it reboots, OR turn the TV on and simply unplug it for several seconds then plug it back in again. Both of these methods have worked to bring up the initial Viewing Environment menu on various Panasonics.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 9 Old 04-11-2010, 09:50 PM - Thread Starter
darshan_4's Avatar
it worked!
thx ^^
post #6 of 9 Old 04-12-2010, 08:14 AM
"Don't PM Me Bro"
Quoted: 498 Post(s)
Liked: 766
it worked!
thx ^^
Yay! Which method did you use?
Randy
post #7 of 9 Old 04-12-2010, 10:32 AM - Thread Starter
darshan_4's Avatar
i pressed it and held it in place for more then 30 sec
while holding it i unplugged the tv and then let go of the power
i HEARD a click sound...
n then pluged it in after few second and voila
post #8 of 9 Old 04-12-2010, 01:23 PM
"Don't PM Me Bro"
Quoted: 498 Post(s)
Liked: 766
You still did it incorrectly then. You don't have to unplug it if you hold the power button in long enough; it will reboot all by itself. By unplugging it while holding the button in you just short-cutted the process so there was no need to hold the button in anyway.
Randy
post #9 of 9 Old 04-15-2010, 02:08 PM - Thread Starter
darshan_4's Avatar
hm... you're probbly right but the problem i was trying to fix was resolved...
which was to get rid of the demo screen that poped up every so often...
