Did I just turn my Samsung PNxxC7000 into a PNxxC8000, why yes I did - AVS Forum | Home Theater Discussions And Reviews
post #1 of 326 Old 04-14-2010, 08:54 AM - Thread Starter
aim1126's Avatar
Instructions:
- Turn off tv
- Press Mute-1-8-2-Power in sequence
- Once the tv is on, the service menu should appear at the top left corner.
- Go to options
- Change the model to c8000
- Press reset to factory default to exit out of the menu.
- Tv will turn off and back on, once is back on, a massage should appear saying, board has been change, don't worry, just click ok and everything should be fine.
- To get rid of the message, just go back into the service menu and change the front color to T-C-Black
You will notice that now under picture options- film mode- you will have a cinema smooth option
Also you will have a motion judder canceler option.
And last you will have two new presets, cal-day and cal-night
Also works with the c6500
DISCLAIMER
I will not be held responsible for any damage done to your set. Do so at your own risk
Good luck, i would take pictures but the only way i know how to get out of the service menu is to reset to factory defaults, and i dont wanna have to change all my settings again sorry
aim1126 is offline
post #2 of 326 Old 04-14-2010, 09:23 AM
Warrior668's Avatar
Is "reset to factory default" really necessary?
I don´t think so. But i could be wrong.
Warrior668 is offline
post #3 of 326 Old 04-14-2010, 09:44 AM - Thread Starter
aim1126's Avatar
i really dont know, but i couldnt find a way to get out of the service menu, maybe turning the tv off and on again
aim1126 is offline
post #4 of 326 Old 04-14-2010, 10:13 AM - Thread Starter
aim1126's Avatar
i just realized that the tv will go bad to factory settings no matter what, even if you just turn off the tv and turn it back on to get out of the service menu
aim1126 is offline
post #5 of 326 Old 04-14-2010, 10:17 AM
gti303's Avatar
what about when you are flashing firmware then...
it would be a bit of a pain if you need to restore it back to the 7000 and lose all your settings.
gti303 is offline
post #6 of 326 Old 04-14-2010, 10:25 AM - Thread Starter
aim1126's Avatar
i think you could probably use the c8000 firmware because even when i activated the tv with netflix, netflix recognized it as a samsung 8 series 2010 model
aim1126 is offline
post #7 of 326 Old 04-14-2010, 10:50 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Hey all,
I came across a support page dedicated to sammy plasma's. It's a repeat of the OP procedure but dives into more details about service menus, firmware and whatnot.
http://samsungplasmatvfaq.com/index.php/Service_Menu
Enjoy
Gaugster
Gaugster is offline
post #8 of 326 Old 04-14-2010, 10:56 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Just reposting my earlier comments in regards to firmware updates. Sounds like your initial experience is leaning towards # 3 which is good.
Does anyone have any thoughts on what this "mod" would do in regards to future firmware updates? Has this been debated elsewhere on AVS? All we can do is guess but I can think of a few ways to go about it.
1 - Do nothing special. Have a c7000 that is converted to c8000 but upload the available c7000 firmware update(s) for better 3D etc....
2 - Change the converted c8000 back to a c7000 prior to any firmware updates.
3 - Have a c7000 that is converted to an c8000. Upload any c8000 firmware updates as they become available.
Gaugster
Gaugster is offline
post #9 of 326 Old 04-14-2010, 11:21 AM
PENDRAG0ON's Avatar
Liked: 574
I wonder if you could enable 3D onto the lower sets like the 4 and 5 series? I would bust a gut laughing if you could.
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
post #10 of 326 Old 04-14-2010, 01:27 PM - Thread Starter
aim1126's Avatar
doubt it, since the 3d tvs have a special engine in them that does the 3d rendering
aim1126 is offline
post #11 of 326 Old 04-14-2010, 02:28 PM
The.Highlander's Avatar
Something to keep in mind when people are doing this... it does more than likely change a few things internal settings wise and that may include an increase in heat. It's like overclocking your PC, your making it do something that particular model wasn't intended to.
Just saying...
Loving the Blu-Revolution
The.Highlander is offline
post #12 of 326 Old 04-14-2010, 02:35 PM - Thread Starter
aim1126's Avatar
could somebody go into their service menu in their c7000 and type their "type" number thats located under options?
aim1126 is offline
post #13 of 326 Old 04-14-2010, 03:45 PM
buzzard767's Avatar
Quoted: 1655 Post(s)
Liked: 2436
This is going to look very bad for Samsung if it turns out to be what it "appears" to be - merely a click in the software. I suspect this is going to get ugly....
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #14 of 326 Old 04-14-2010, 04:09 PM
ystasino's Avatar
The "C8000 selection" on the C7000 brings memories of threats by Canon of voiding a warranty of the Digital Rebel if we installed a hacked firmware version that enabled some software-suppressed features 5-6 years ago.
I wonder if Samsung reads this and sends an automatic update to disable the cinema smooth and judder canceler while people are sleeping... Soviet style
Canon never enforced their threat and the whole thing was forgotten when the newer models came up.
ystasino is offline
post #15 of 326 Old 04-14-2010, 04:31 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2709 Post(s)
Liked: 2930
It happened all of last year with no issues in this thread "Did I just turn my Samsung PN58B550 into a 560? Yes I did! "<<< Click Here >>>
One thing that has not been mentioned but should be, Going into service menus and not being a service tech, can in some cases void the warranty. Be careful.
Cleveland Plasma is offline
post #16 of 326 Old 04-14-2010, 11:19 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
highly likely you are correct regarding the C4xx and C5xx lines, but it would not surprise me if the C6500 had the same processing (albeit maybe missing the IR emitter).
dougri is offline
post #17 of 326 Old 04-15-2010, 11:44 PM
Bulls729's Avatar
Note to OP, If you want this message to stop displaying, then go back into the service menu, got to the option byte, go to Front Color and change it to T-C-Black, if you want to know why its simple, this TV has Samsungs Touch of Color (T-C) and it is Black(-Black)
Also having done this since FW 1012/1014 (My unit shipped with FW 1009) and have been using FW upgrade files to the current 1017, everything is working fine (Knock on wood)
Bulls729 is offline
post #18 of 326 Old 04-16-2010, 06:26 AM
whitetrash66's Avatar
Quoted: 66 Post(s)
Liked: 42
again, just so i can clarify, this always resets itself after the tv is powered off?
whitetrash66 is offline
post #19 of 326 Old 04-16-2010, 08:44 AM
JoeSony's Avatar
Quoted: 53 Post(s)
Liked: 30
Good point Chris.
JoeSony is offline
post #20 of 326 Old 04-16-2010, 11:02 AM
aidoroboo's Avatar
Here is a question...
What about extended warranties from BB and other retailers? If you screw up the TV with the service menu how will they know before you get a replacement?
aidoroboo is offline
post #21 of 326 Old 04-16-2010, 11:06 AM
aidoroboo's Avatar
I guess it doesn't really matter since those warrenties cost more than the difference between the MRSPs
But that being the case I would guess that the TVs themselves are nearly identical, the C7000 and C8000 both look to have the same bezel, dimensions and weight. It would seem cost effective that only a setting in the service menu raises the cost between the sets.
post #22 of 326 Old 04-16-2010, 02:01 PM
Industry Insider
Liked: 2930
They probably would not, but one does not want to go poking around in service menus for no reason.
post #23 of 326 Old 04-16-2010, 06:59 PM - Thread Starter
aim1126's Avatar
the c8000 has the real black filter while the c7000 does not
aim1126 is offline
post #24 of 326 Old 04-21-2010, 12:11 PM
harris613's Avatar
I used this on the service menu on my PN58C6400 and it has the option to change the model to the 7000 or 8000. Will this work?
harris613 is offline
post #25 of 326 Old 04-23-2010, 08:46 PM
jgcec's Avatar
Quoted: 60 Post(s)
it already says 8000 series with Netflix before the change in the service manaul
I went to netflix day 1 that I got it, the pnc7000 and it said 8000 series
Video Display - Samsung PN60&51 F8500, PN50C7000, Sony KV-36HS500 Trinitron
Video Source - Samsung BD-P3600 BR, Apple TV2, Harmony 650 Remote
Sound - Yamaha RX-V377 AV, Monoprice 108247, Bose Quietcomfort 15
Bought and Returned - HU8550, LG EC9300, Oppo 103D, Sony MDR-HW700DS Headphones
jgcec is offline
post #26 of 326 Old 05-01-2010, 05:52 AM
TheD0m's Avatar
Any updates on using C7000 or C8000 firmware post-"upgrade" ?
TheD0m is offline
post #27 of 326 Old 05-03-2010, 11:59 AM
NJChris's Avatar
Quoted: 29 Post(s)
Liked: 37
I have the 58C7000. The firmware is 115 on it. I've changed the model to C8000 to unlock the extra menu items.
Is the firmware for the 50C7000 usable on the 58? Or do I need to wait? And does using the C7000 firmware keep the changes / extra menu items?
Sony 940C
NJChris is offline
post #28 of 326 Old 05-03-2010, 05:31 PM
sedream128's Avatar
i own the pn58c7000 and changed the firmware and all is good!
sedream128 is offline
post #29 of 326 Old 05-03-2010, 09:39 PM
NJChris's Avatar
Quoted: 29 Post(s)
Liked: 37
You used the firmware file for the 50c7000 on your 58c7000 that you changed to a C8000 and the C8000 stayed?
Sony 940C
NJChris is offline
post #30 of 326 Old 05-04-2010, 01:14 AM
sedream128's Avatar
went from c7000 firmware to c8000 with no problems!
