Insignia 42" Plasma NS-42P650A11 @ Best Buy - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-28-2012, 05:34 PM
rayoner's Avatar
I really like the picture on this TV and had it for a few days. But there is also a Panny 42ST30 open box available for $100 more. Has anyone tested the lag on this TV which is my biggest factor...Is it worth the trouble returning for the Panny?
rayoner is offline
Old 03-28-2012, 07:06 PM
rayoner's Avatar
Also for those using ksbarnes settings. Are you using just his adc result settings and keeping the wb settings at your default. Or are you inputting his WB settings as well?
rayoner is offline
Old 11-08-2013, 07:44 PM
blobula's Avatar
Quoted: 12 Post(s)
Not sure if anyone else has experienced this issue or not with this tv, but mine recently started giving three click on start up trying to turn on then stops. The red indicator stays solid after that.
If someone has had this issue what did you do to fix it?
This seems to be the same problem for me.
http://www.justanswer.com/tv-repair/6q8nl-insignia-plasma-tv-will-not-turn-on-unplugged.html
blobula is offline
Old 01-12-2017, 06:33 PM
Liked: 0
Any way to find more info on how to calibrate this TV? I assume after 7 years there might be some adjusting needed... I went off the settings in this post but I think I just made it worse. I have a PS4, PS3, cable, chromecast and I watch a lot of streaming stuff. I can never seem to get the contras, brightness black levels and what have yous perfect.
Scott Albert Lawrence is offline
Old 01-12-2017, 06:38 PM
h1pst3r88's Avatar
Quoted: 117 Post(s)
Liked: 63
Wow, I bought this TV new and it's still running perfectly in a spare bedroom to this day!
GREAT TV that I think I paid $420 for at Best Buy WITH 4 year warranty all those years ago.
Bulletproof!
h1pst3r88 is offline
Insignia 32 Inch Lcd Hdtv
