*The Official Samsung PNxxC8000 Owner's Discussion Thread!! - Page 197 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #5881 of 5905 Old 08-11-2014, 02:58 PM
uscpsycho's Avatar
Quoted: 141 Post(s)
Yep, I'm also having the problem with banding on a primarily white screen.
For me it's a thick band of flickering static that stretches all the way across the screen. The band is probably 8" high and it's maybe 12" from the top of the screen. I was actually giving Samsung the benefit of the doubt and assumed the flicker was being introduced by the Vizio Google TV box which I have between my receiver and the TV. If others are having the same problem then I guess it's not the GTV box but the TV itself. This is upsetting.
To be honest, it only seems to crop up during commercials where the screen is mostly white with a logo or a little bit of copy on the screen. During regular programming you hardly ever have a mostly-white screen like that. So it hasn't bothered me much yet, but now that I know that the problem is my very expensive TV it bothers me more. And now I'm worried it may get worse. Ugh.
uscpsycho is offline
post #5882 of 5905 Old 08-16-2014, 03:46 PM
mortaldivine's Avatar
My PN58C8000 finally popped while watching a show and now I get no picture. I ordered a new power board for it. Hope thats all it needs. Anyone have this problem?
mortaldivine is offline
post #5883 of 5905 Old 10-14-2014, 10:23 AM
Jnipz's Avatar
I have a PN64C8000 that has some noticeable lines that go across the entire screen. Also on a grey screen there is a pinkish tint. The lines are like some sort of ghosting. What parts would I need to repair this? Would replacing the Main PCBs correct this?
Jnipz is offline
post #5884 of 5905 Old 10-14-2014, 01:54 PM
ItzMe's Avatar
Quoted: 30 Post(s)
I'm impressed that it took this long before you got the pink banding. It happened to mine inside of a year (4 years ago?). At that time the Samsung tech looked at it and ordered me a new panel, but then Samsung told me they couldn't get one for me. Eventually they refunded me my purchase price and I bought a D8000.
You'll find similar stories in this thread, with different outcomes. Bottom line is that I'd guess you won't find anyone with a new panel, or other possible parts for a C series. sorry. Maybe others still follow this thread and have some better ideas for you.
ItzMe is offline
post #5885 of 5905 Old 10-15-2014, 11:16 PM
USCsuperfan's Avatar
Sorry if this has been posted before, but I did a search and couldn't find a mention of it:
I've had the PN63C8000 for 3+ years, and in the last few months I have been getting an intermittent problem where the screen just goes blank or black and looks like the tv is off, but it's not off because the tv speakers still work and there is no red light in the bottom left corner. The problem does not resolve itself. I have to turn the tv off and then turn it on again. It will start working again, sometimes for only two minutes, sometimes for a month before it happens again.
Anybody else have this problem? Or know of a solution?
Ryryguy likes this.
USCsuperfan is offline
post #5886 of 5905 Old 10-16-2014, 03:49 PM
Liked: 0
What page are calibration settings on for the 58"?
Southpole12 is offline
post #5887 of 5905 Old 10-16-2014, 03:52 PM
Liked: 0
I have had the TV for 5 years and have been a victim of the purple haze. I still use it bc it's not bad and my warranty cut me a check. I am trying to get the picture as good as it can be. I tried some picture settings on other sites but it just looks too dull. Any info on where to find the calibration setting would be great. Thanks
post #5888 of 5905 Old 11-11-2014, 07:11 PM
Liked: 1
I have the Samsung pn58c8000yfxza and black horizontal lines are appearing on the top panel of the TV and slowly gaining more lines going down the panel. What is the issue and is it worth fixing? I have read somewhere that it's the sustain board and some have said it's the panel and that it's not worth fixing. Any input greatly appreciated.
ssei likes this.
collins is offline
post #5889 of 5905 Old 11-22-2014, 04:41 PM
WeeJavaDude's Avatar
Sounds exactly like mine. Someone one told me that since it is happening when the screen is mostly white it is most likely a problem with power. Wondering if anyone that had this issue has a part that could be replaced to fix it. TV is not that old and looks great.
By the way. the problem seems to be getting a little worse.
WeeJavaDude is offline
post #5890 of 5905 Old 02-12-2015, 12:14 PM
JCUMV's Avatar
Guys, there's a fix for the pink banding problem. You need to go to the pink banding thread located here: http://*******/1J3Stck. There is a file you'll need to download, put on a flash stick, and install onto your TV. There's a different file for 58 vs 63 inch. You'll need to read through the last 10 or so pages of this thread and make yourself very familiar with the update process. You'll also find the hyperlink to the website where you can download the fix file.
A bunch of people have done this with their PDP's (including me) and it completely fixed the pink banding problem. Good luck.
JCUMV is offline
post #5891 of 5905 Old 02-12-2015, 12:32 PM
Larry Geller's Avatar
So what do the asterisks stand for?(http://*******/1J3Stck.) The link won't work as is.
"MMMM,Snout!"---Homer Simpson
Larry Geller is offline
post #5892 of 5905 Old 02-12-2015, 01:26 PM
JCUMV's Avatar
I was trying to use Bitly to shorten the lengthy hyperlink, but it didn't work. Just found the hyperlink feature here in Reply screen. Here you go: PN58C8000 Pink Banding.
EDIT: Okay, here's the deal, the above link is to yet another thread dedicated to fixing the pink banding issue. The option above is making an adjustment to the voltage setting. There are a lot of pics and detail about how to do this. Personally, I didn't have the electrical skills confidence to do this so I opted with the file upload fix which is a separate thread located here. This is one you'll need to review that last 10 or so pages. Good luck.
uscpsycho likes this.
JCUMV is offline
post #5893 of 5905 Old 02-13-2015, 04:55 AM
KK in CT's Avatar
Quoted: 101 Post(s)
Liked: 73
Thanks for this! I started noticing pink banding on my PN58C8000 a couple of months ago and figured I would need to start looking for a new TV. I was hoping to wait a while until the 4K OLED's were ironed out a bit more and larger flat screens were available. I will try the fix mentioned here this weekend and hope I will see the same results.
LG OLED65E6P | Oppo UDP-203 | Denon X5200W 7.2.4 | Darbee DVP-5000 | Emotiva XPA-3 | Sony PS4 | Xfinity X1
KK in CT is offline
post #5894 of 5905 Old 02-24-2015, 04:28 AM
lowpolyjoe's Avatar
Smart App Virus?
This morning my PN63C8000 ran auto-update and deleted all my apps and replaced them with a bunch of Russian stuff.
Exit/Reentering the hub ran another update, this time with more American/English sounding stuff. Another restart ran another update. It looks like about 50/50 with Russian then English stuff getting installed then deleted.
This seems very much like a virus and I'm worried about my home network. I should have pulled the network connection right away but wanted to use my HBO Go app (which still seems to be working after the first 4 or 5 rounds of updates).
I emailed Samsung tech support but fear they will not respond because my TV is too old to be listed on their dropdown box of products in the support form.
Anyone else having this issue? I'm on the East Coast, USA.
lowpolyjoe is offline
post #5895 of 5905 Old 02-25-2015, 12:46 AM
uscpsycho's Avatar
Quoted: 141 Post(s)
What do you mean auto-update?
Whenever there is new firmware available my TV asks me if I want to install it or not. Yours just installed new software without asking you first?
post #5896 of 5905 Old 02-25-2015, 05:43 AM
lowpolyjoe's Avatar
Originally Posted by lowpolyjoe View Post
Smart App Virus?
Big thumbs up for a quick and helpful reply from Samsung tech support. I"ve heard nothing but horrible reviews of their tech support so this was a great surprise. A synopsis of their response, including 4 possible solutions
1) Go into network settings, change DNS to "Manual" and set it to 8.8.8.8. Unplug the TV, plug it back in. This seems to have solved my problem so I didn't do any stuff below. I did some digging and found that this is the explicit address of Google's DNS server, which will then override/prevent your device from using your ISP's DNS.
2) Same as above but try DNS 8.8.4.4 (Google's alternative DNS)
3) Reset the internet settings via Internet@TV->Settings->SystemSetup->Reset (you may need the tv password, default is 0000). This will delete your downloaded apps.
4) Rest the TV to factory defaults from the main menu. This will clobber all your settings everywhere.
I have not tried these approaches on my Samsung Bluray player yet (which also gave me problems yesterday), but my TV seems to be working now.
I'm very relieved. I ran virus scans on my computers lastnight and everything looks good, so I'm hoping it was just some wonky with my ISP's DNS.
This was not the TV firmware update, it was just the Smart App Updater. For this, my TV does not ask for permission. When there is an update for any Apps, it automatically starts the process when you enter the Internet@TV screen. My bluray player prompted me yesterday morning to start an update (in German?!) and I declined but it would then not let me use the internet apps. I'm hoping the DNS fix resolves the bluray problem too.
Hope this is helpful for some others to avoid the virus panic that gripped me for 24hrs
post #5897 of 5905 Old 06-08-2015, 09:41 PM
jaegertc's Avatar
I have a PN63C8000 with a cracked screen. I've called a couple of shops in the Twin Cities area, but they've been no help. Am I SOL? Can repairs be made to a TV this old?
jaegertc is offline
post #5898 of 5905 Old 06-11-2015, 11:22 PM
bluSCALE4's Avatar
Having black screen issues /w audio on my TV. Tried replacing the Y and X board but still had the issue. I then replaced the upper and lower Y boards but still saw the same issue. I noticed that the upper and lower Y boards model numbers did not exactly match mine. The lower board is 001 version while my original is 002. As far as I know 002 and 004 are interchangeable but not 001. I'm returning the 001 boards but I'm not sure what to what to try now. I took readings of my power supply and caused a short leading to my new Y board (upper and lower boards were disconnected). I retook the readings and they're the same so I believe the power supply is fine but not sure about the Y-Main board (I believe I bridged the ground and the Vs 208). Any tips outside of be more careful next time?
bluSCALE4 is offline
post #5899 of 5905 Old 06-22-2016, 08:14 PM
ajsimeon's Avatar
Quoted: 20 Post(s)
Sorry to bring this thread back up. So I bought this 58 version of this set used for $200 and it does have some of the pink banding thing so I'm going to be using the usb logic update to see if that works. However, how the heck do you do a full Factory Setting on this? I cannot find this feature anywhere.
ajsimeon is offline
post #5900 of 5905 Old 06-22-2016, 08:44 PM
JcTcom's Avatar
Hi. I have had this issue repaired by a service technician 3 times. Once under the original warranty and twice under the extended Warranty. It is now out of warranty and of course it is doing it again.
Do I understand correctly from your post that there is a way for me to fix this myself? If so could you please point me to a link with instructions? Thank you.
The closes thing I could find to a "Reset" was a "Picture Reset" under each of the picture profiles and a "Sound Reset" under the Audio options.
Carl.
JcTcom is offline
post #5901 of 5905 Old 06-22-2016, 08:57 PM
ajsimeon's Avatar
Quoted: 20 Post(s)
Carl.
Yeah I'll be following directions on this thread:
I'm hoping it fixes it like others have said worked. But I'd like to do a whole factory reset but I cannot find this option.
ajsimeon is offline
post #5902 of 5905 Old 06-23-2016, 05:33 AM
ajsimeon's Avatar
Quoted: 20 Post(s)
So I did the factory reset in the Service Menu and also did the LOGIC update and it's a like a brand new set! I don't see the purple stuff anymore! Easy fix!
ajsimeon is offline
post #5903 of 5905 Old 06-23-2016, 02:34 PM
JcTcom's Avatar
Cool. Did you actually find the Firmware file?
I found a single link here:
http://www.mediafire.com/download/bg...58%5DLOGIC.bin
But being as it is not any sort of official link I am not sure how to verify if it is actually the correct file or how old or anything?
I am going to pull the back off of the TV today and adjust the VS setting at least. I did do a Firmware update from within the TV menu but I have read mixed results as to whether or not that actually updates the Logic Board component or not.
Carl
JcTcom is offline
post #5904 of 5905 Old 06-23-2016, 06:56 PM
ajsimeon's Avatar
Quoted: 20 Post(s)
Carl
Yeah I believe that's the right logic file. I would do that update before messing with voltages. Worked great for me. I'm happy with this $200 purchase.
ajsimeon is offline
post #5905 of 5905 Old 06-23-2016, 10:41 PM
JcTcom's Avatar
Well I used that file and performed the update, then set to factory settings.
Had to adjust the VS voltage a bit higher than what I have seen other people mention (213 Volts). I had to set it to 215 Volts to get rid of all of the pink banding.
But the picture looks really great now. It even seems sharper when on the computer input for text and stuff.
Carl.
JcTcom is offline
Samsung Pn50c8000 50 In 3d Hdtv Plasma Tv , Samsung Pn50c8000 50 Inch 1080p 3d Plasma Hdtv , Samsung Pn63c8000 63 Inch 1080p 3d Plasma Hdtv , Samsung Pn58c8000 58 Inch 1080p 3d Plasma Hdtv Black , Samsung Pn58c8000 58 3d Plasma Tv 16 9 Hdtv 1080p 58in Ws Plasma 1080p 3d Ready 600hz 4 Hdmi Ultra S
