TH-42PX75U . . . Sound but NO PICTURE! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 05-27-2010, 03:28 PM - Thread Starter
MikeyThumbz's Avatar
Hey everyone. First post here, been surfing around and found some good info on these forums!
I've been experiencing a problem with my 42" panasonic plasma tv (th-42px75u)
seems like it was only happening when it was EXTREMELY hot outside and ambient temp in my house was above 80F. The picture starts flashing, colors get distorted and BAM, picture goes black but I can still hear whatever I was watching.
The tv is not even used for 2 years yet and I'm PISSED!
I called a local repair center and the guy told me it's probably a cooling fan that needs to be replaced, but I did some research and came to find this model doesn't have fans inside. . .
Has any1 had a problem with their plasma like this before? If so, what did the problem wind up being?
Thanks in advance! Hopefully someone can shed a little light on my situation!
MikeyThumbz is offline
post #2 of 31 Old 05-27-2010, 03:44 PM
EG3
EG3's Avatar
I had one in the shop the other day with the very same issue. I resolved it by re-seating the LVDS cable at both ends (A5 - D5). Connector D5 is buried under the A-Board assembly. It's not too hard of a job. Just be gentle with the connectors, especially the LVDS. It has a tab on each side that you squeeze (both together) when removing and inserting. You may be able to find some manuals somewhere in these threads to help.
Let us know if you run into any snags. There are a lot of pros here that can help.
loopguru, sixfoot0, swells and 1 others like this.
EG3 is offline
post #3 of 31 Old 05-27-2010, 04:12 PM - Thread Starter
Nice man thanks for the quick reply! I'll give this a shot. I'm pretty handy so I don't think it will be a problem for me. I'll find the service manual and hopefully get to it this weekend. . .
I'll let you know how it goes!
BTW, after I power it down for a couple of minutes then turn it back on the picture comes back but soon returns to the black screen with sound (maybe 3 - 5 min). . .
Just now I actually had a fan blowing directly on the tv and had it on for about 2 1/2 hours no problems . . .soon as i unplugged the fan about 5 mins later the picture went out.
post #4 of 31 Old 05-29-2010, 05:20 AM - Thread Starter
**Bump Bump**
post #5 of 31 Old 06-04-2010, 04:21 AM - Thread Starter
Hey EG3, thanks for the advice man! I had some time to give this a shot (reseating cable a5-d5). First time I've ever tried working on a tv myself and it seems if I was successful thanks to you! It took me all of 30 mins to remove the back of the tv and loosen some slack in the cables to get to the D board, blew all the dust out, took the a5-d5 cable out and put it back.
This TV seems pretty easy to work on!
Appreciate the help man! Glad I found this place!
post #6 of 31 Old 06-04-2010, 07:58 AM
EG3
EG3's Avatar
Thats great Mikey Thumbz! Thanks for replying back with your results. Maybe this thread can be of help to others with this symptom.
sixfoot0 likes this.
EG3 is offline
post #7 of 31 Old 12-09-2010, 07:06 AM
dkennedy00's Avatar
Thank you so much. I can not believe this was all it took to fix this problem. We were ready to get a new TV but I found this forum and thought what do I have to loose? It has been working like brand new for over a week now and no blinking or blank screen. Thank you, thank you, thank you...(My husband really thanks you, football is so much better now and I can go to the spa with the money we were going to blow on a new TV ...)
dkennedy00 is offline
post #8 of 31 Old 02-28-2011, 06:46 PM
ig6888's Avatar
I have same TV, the problem that I have is that my TV shut down one day and I couldn't power it back on, the red LED light is blinking 10 times, what can I do to get it working again.
ig6888 is offline
post #9 of 31 Old 09-03-2011, 12:34 PM
PanasonicTVowner's Avatar
EG3,
Just wanted to say THANK YOU for your post. Man, you are a real lifesaver!!!!
I had the same problem with my Panasonic Viera TH-42PX75U - no picture, only sound. Was about to look for a new board, but tried to figure out which one to try to replace... Saw your post, gave it a try, and it worked!!! Just disconnected (gently!) and reconnected back A5-D5, and now for a couple of weeks the TV has been working like new!!!
THANK YOU! THANK YOU! THANK YOU!
PanasonicTVowner is offline
post #10 of 31 Old 09-07-2011, 10:24 AM
EG3
EG3's Avatar
Good job PanasonicTVowner!!!
Glad to hear it was just a bad connection.
EG3 is offline
post #11 of 31 Old 01-01-2012, 09:53 AM
onlyme1016's Avatar
Happy New Year to you EG3!
Last night we wanted to watch some New Year festivities and the TV would not cooperate at all. It had been acting oddly off and on, but the other week it started to work flawlessly up until last night. When we experience the problems in the past I stumble upon this site and the connector fix, so this morning I got right to it and the TV is working like new.
Thank you so much for share your wisdom.
onlyme1016 is offline
post #12 of 31 Old 06-15-2012, 02:13 PM
sixfoot0's Avatar
Hey Just wanted to THANK YOU EG3 for this info. I just had the same problem. took off the back. re set the wires .I'd like to ad that there is small black tape that holds these wires together.I took them off so the wires could breath.I'm sure they conduct some type of heat source. anyways koo koo ka choo. everything is still on.biggrin.gif
sixfoot0 is offline
post #13 of 31 Old 05-17-2013, 08:19 PM
Donqi's Avatar
I opened up the back of my 42PX75U and I can't tell one par from the other. I don't know where this A5 to D5 connection is.
Can someone post a pic of this?
John
Donqi is offline
post #14 of 31 Old 05-17-2013, 08:43 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Larry
loopguru likes this.
LarryInRI is offline
post #15 of 31 Old 05-17-2013, 08:59 PM
Donqi's Avatar
Holy F'n Shizzz.
I found the A5 to D5, unconnected that cable, reconnected and it is working now. It didn't seem disconnected though. I just don't get. I'm waiting for the pic to go black, but it isn't.....
I'm speechless.
Donqi is offline
post #16 of 31 Old 05-17-2013, 09:00 PM
Donqi's Avatar
Thanks Larry!
Donqi is offline
post #17 of 31 Old 05-17-2013, 09:01 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Larry
post #18 of 31 Old 05-18-2013, 05:03 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Hah, reminds me of the cheap TH-46PZ80 I picked up. Faulty, half the screen missing, other half flickering. Same loose cable. Very common on these models.
tom669 is offline
post #19 of 31 Old 07-10-2013, 04:43 PM
swells's Avatar
Same results for me also! Wonder how many folks tossed these sets into landfills. THANKS A TON FOR THIS THREAD.
swells is offline
post #20 of 31 Old 07-14-2013, 08:07 AM
Nascar#43's Avatar
I think I am having this problem on my panel. I switched the HMDI to see if it makes a difference.
How easy is this to fix, can I get a little instructions...Thanx
UPDATE: Switching from HMDI 1 to HMDI 2 worked for now. A lot of screws on the back of this panel to take off.
Nascar#43 is offline
post #21 of 31 Old 08-15-2013, 03:00 PM
woopie's Avatar
My Panasonic Viera TX-L42E5B has no picture but has sound i dont have a clue what to do someone please help
woopie is offline
post #22 of 31 Old 08-16-2013, 03:59 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
...this is the wrong thread. Post a new one, in the LCD forum. Badcaps.net is a good forum for troubleshooting LCDs, if this forum doesn't give you any luck.
tom669 is offline
post #23 of 31 Old 09-02-2013, 07:24 PM
lynchee's Avatar
Well it's been about 4 hours since I tried this fix and so far so good.
I just wanted to say THANK YOU!!!!!
lynchee is offline
post #24 of 31 Old 09-03-2013, 03:19 AM
inkyky's Avatar
Hi I have a TH42PA60E with the same problem as everyone else but the internal setup of the tv is different to the picture of the other model. By any chance would you have the drawings to point me to the correct area so that I can fix this ? Many thanks, your post is very helpful.
inkyky is offline
post #25 of 31 Old 09-03-2013, 05:23 PM
technologic80's Avatar
Always can count on AVSforum.com!!!
Came here years ago for my Panasonic TH-42PX75u when I was having problems.... problem reared its ugly head again today, so I came back, found this thread, reseated my cable and its working great biggrin.gif
Thanks again!!
(although secretly I was sooooo ready to go out and buy a new LED set to replace the TH-42PX75u...maybe next time) cool.gif
technologic80 is offline
post #26 of 31 Old 09-08-2013, 07:14 PM
tbot's Avatar
Thanks, this saved my bacon. Don't take the shortcut and just reseat the D5 connector. That doesn't work. You have to reseat both ends for this to work. I laid the panel flat using a mattress also easy on the back, then you can take out the screws for the D-board to get access to the A-board. You can't completely take out the D-board because of the other cable connections but you can open it just enough to reseat the A5 connector on the A-board. Again, it helps if the panel is laying flat so you can access it from the top. Thanks to LarryInRI, the diagram is the bacon royal.
tbot is offline
post #27 of 31 Old 11-20-2013, 12:10 AM
workingMom's Avatar
Need help with my txauxo1ursu. No picture only sound.
workingMom is offline
post #28 of 31 Old 12-07-2013, 06:16 AM
ag2013's Avatar
Hey !!! thanks I had the same problem and tried your tip and it worked instantly, i was trying since one week, bought new remote as well nothing worked, but today googled it and found this site, thanks again !!! :)
ag2013 is offline
post #29 of 31 Old 05-18-2014, 01:54 PM
00Ref's Avatar
I just did this to my th-42px75u manufactured in 2007 (2014 now) and it worked! Follow the diagram, took me way to long to find it without.
00Ref is offline
post #30 of 31 Old 10-21-2014, 10:32 PM
Liked: 0
I just fixed my Panasonic Viera 50" using this method and it's working great!
joevalle0940 is offline
Panasonic 42 Inch Th 42px75u Plasma Hdtv
