Plasma glare/reflections: worse than with picture tubes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-16-2010, 06:00 PM - Thread Starter
el_simbolo's Avatar
I've been trying to decide if I need anti-glare plasma, but realized there was one simple question I hadn't asked yet...
Is a Plasma (Pany C2 or Samsung C450) more reflective than a curved picture tube TV? I'm buying one for the basement and really the reflections in my 2002 32" JVC picture tube haven't bothered me.
Thanks again, everyone.
el_simbolo is offline
post #2 of 4 Old 06-16-2010, 06:25 PM
gbmannc's Avatar
Those particular sets have no anti reflection filter OR coating, so the reflecting might be a little worse to about the same. However you do have to factor in the fact that a flat screen will catch reflection less than a curved tube will.
So, it most likely won't bother you at all.
gbmannc is offline
post #3 of 4 Old 06-16-2010, 06:26 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Go look for yourself. To me they are terrible without it. The S2 has a good anti-reflective coating. You should be able to see them close together where you could compare the difference. I wouldn't buy a plasma without a coating.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #4 of 4 Old 06-16-2010, 06:43 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 506 Post(s)
Liked: 770
The larger plasma has more glass area to reflect things in the room, but the curved picture tube gives a sort of "fish-eye" effect and may actually reflect more of the room in the corners of the screen so it's hard to say which would be more or less noticeable. People (especially the Plasma haters) seem to forget that we've been watching highly reflective tube TVs from the 1940's through at least the early 2000's and we just took their reflectivity for granted, and nobody complained much.
If you're not bothered by the reflectivity on your old Tube TV in your basement, then the C2 would probably be fine in it's place.
Here's and old thread that may help a bit:
http://www.avsforum.com/avs-vb/showthread.php?t=769318
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
