How to hook up "digital audio out" to receiver w/ RCA jacks?? - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2010, 05:05 PM - Thread Starter
57Strat777's Avatar
Panasonic-VIERA / 46" Class / 720p / 600Hz / Plasma HDTV-TC-P46C2
I just bought the above TV and have a question about hooking up the TV to a stereo receiver (2 speakers - very old school). My stereo receiver is old and it only has RCA jacks for the audio input. This TV has an audio output labeled "digital audio out". I cannot find RCA jacks on the TV that will provide a L/R audio OUT signal. How can I get the digital audio out jack to provide a signal to the RCA L/R inputs of my stereo receiver?
Thank you!! I really don't want to buy a new stereo receiver just so I can hear my TV/DVD through the stereo.
57Strat777 is offline
Old 07-25-2010, 05:42 PM
Servicetech571's Avatar
Unless you are using the TV's built in tuner just hook the RCA cords from the receiver to the source directly.
Servicetech571 is offline
Old 07-25-2010, 06:22 PM
XrstalLens's Avatar
The Gefen digital audio to analog converter will do what you want for less than $100. http://www.gefen.com/kvm/dproduct.jsp?prod_id=5279.
Lyle Corbin
www.crystalclearhometheater.com
THX Video, ISF, and HAA Level II calibrator
XrstalLens is offline
Old 07-25-2010, 06:29 PM - Thread Starter
57Strat777's Avatar
I have two sources that run through the TV, a cable box and a DVD player. I need an audio out from the TV.
Old 07-25-2010, 06:37 PM
Hook the Cable Box and DVD player up to 2 different inputs on the reciever. I know it's a PITA to change the sources on 2 devices but it will work. If the receiver is new enough to have remote control a Logitech will switch both sources at the same time. If you are going to buy a $100 adapter that's 1/3 of the cost of 5.1 AVR.
Old 07-25-2010, 10:35 PM
XrstalLens's Avatar
Since you're using a cable box and not the built in tuner, this is what I would recommend as well. I would only recommend the Gefen adapter if you are using the TV's built-in tuner.
The actual price of the adapter is $79 plus tax/shipping. Still quite a bit cheaper than even an entry AVR if money is tight, but a new AVR is of course the best option.
Lyle Corbin
