VT25 Plasma Question - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2010, 09:14 AM - Thread Starter
Gillietalls's Avatar
Quoted: 685 Post(s)
Liked: 563
Ok, so i've browsed this forum for the past coulpe months and am now ready to pull the trigger on a 65 inch VT25. This is my first plasma but I have a couple questions. I do a lot of gaming but have heard image rention and burn in are things of the past. Is there anything I can do beside run break in slides to help prevent these? I watch a lot of TNT, FX, and ESPN. Will the static images on these stations cause image retention or burn in?
LG 65EF9500, LG 55E6, Samsung 55HU9000 (sek-3500), LG 55UB8200
2 Samsung UBD-K8500s, WD 4TB NAS
Nvidia Shield, Wii U, Playstation 3
Gillietalls is offline
Old 07-26-2010, 10:51 AM
Cosmed's Avatar
I don't use my 58VT25 for gaming, but I've had it for a month now and had no IR. I didn't do anything special for break in.
Cosmed is offline
Old 07-26-2010, 02:37 PM
Dayton's Avatar
IR is definitely not a thing of the past. I guess one could say burn-in is as it can be a while before IR can be declared permanent. I babied my VT25 and even after a month's use and conservative gameplay I got some nasty IR from Demon's Souls. You will want to use caution when gaming on a new plasma. Keep gaming sessions brief and follow it up with plenty of non-static full screen content. Playing for a couple hours turning off the TV and gaming again on next use won't cut it, display of non-gaming content in between is almost required.
Doesn't hurt to be cautious. Nothing sucks more than seeing remnants of a HUD or status/health bar show up when your are watching a movie or something and have it not wash away in a timely manner.
Dayton is offline
Old 07-26-2010, 02:40 PM
dandaroy's Avatar
Did you get your IR removed yet?
dandaroy is offline
Old 07-26-2010, 02:53 PM
Dayton's Avatar
Not entirely but it does require that I put up a grey slide and walk up close to the panel to see it. Remnants of the right status icon, looks like an eye at 90 degrees, still exist. I think the glowing effect when in soul form was the culprit.
Haven't gamed in a little over a week but plan on starting in on FFXIII tomorrow. Can't imagine when I'll ever have the courage to play Demon's Souls ever again on my VT25.
Dayton is offline
Old 07-26-2010, 03:13 PM
dandaroy's Avatar
Can you see it at all from your sitting position during regular material?
dandaroy is offline
Old 07-26-2010, 03:18 PM
Dayton's Avatar
Nope not at all. I can only see it now when running slides, the greyish ones, and when standing near the screen.
Dayton is offline
Old 07-26-2010, 03:31 PM
dandaroy's Avatar
I guess you are good then. Hopefully it will go away with time.
dandaroy is offline
Old 07-28-2010, 09:30 AM
Dayton's Avatar
Started in on FFX III and boy this is a good game for a plasma in that there isn't really ever a time when static images could pose a problem. Bayonetta was also good in not having the status bars in constant display. Actually Bayonetta is a better plasma game as you also get the benefit of no input lag which really helps the gameplay. Someone should compile a list of IR friendly games.
Dayton is offline
Old 07-28-2010, 09:40 AM
ElectronicTonic's Avatar
Quoted: 63 Post(s)
Liked: 103
+1
Agreed,
I haven't come across many. RedDeadRedemtion isn't too bad.
ElectronicTonic is offline
Old 07-28-2010, 09:45 AM
motogp's Avatar
wipoutHD, battlefield1943, for ps3, are good! I haven't had any IR. I own an Lg pj350.
motogp is offline
Old 07-29-2010, 03:09 PM
ViciousToaster's Avatar
+1 Here as well.
I'm currently dealing with some nasty IR from Fallout 3 on my 50VT25. I played about 4 hours straight which was probably about 3 hours too long. My settings have stayed pretty conservative for the first month and a half of owning the set so that wasn't the issue. Apparently, bright neon green is not good for a plasma no matter what the settings are. The HP/AP bars are fading....just at a very slow rate. I read there is a setting for the HUD in the Fallout menu where you can turn brightness down. Oh well, lesson learned.
ViciousToaster is offline
Old 07-29-2010, 04:09 PM
Dayton's Avatar
I wonder if it would be easier to come up with a list of "friendly" or "cautionary" games.
Dayton is offline
Old 07-29-2010, 10:51 PM
JonW747's Avatar
Quoted: 110 Post(s)
Liked: 55
Can't hurt to play games with the orbiter enabled, even if it does decrease the sharpness of the picture somewhat.
JonW747 is offline
Old 07-30-2010, 08:46 AM
runner66's Avatar
let me ask when i run my scrolling bars on the white part on the right side i see pixels is this normal
runner66 is offline
Old 07-30-2010, 09:02 AM
I was under the assumption that the pixel orbiter only waited for static images (e.g. computer desktops, pause screens, etc.) to go to work. When gaming, static HUD's are usually mixed with moving images everywhere else on the screen, so there should be no reason for orbiter to engage. Can anyone confirm this?
Old 07-30-2010, 09:35 AM
Dayton's Avatar
You can make the orbiter timed so it will always happen independent of content displayed. However it looks like it will not stop IR due to gaming as it will just make the IR appear blurry or smeared. Stat bars and the like are usually too big for a slight image shift to make much of a difference. However it could help in making it go away faster though I haven't tested this myself.
Dayton is offline
