Screen Failure Panasonic TH-42PX60U Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 08-05-2010, 09:56 AM - Thread Starter
scvcs76's Avatar
So the photos below & attached show what happened to my TH-42PX60U just out of the blue about a week ago. While the TV was on, half of the screen just disappeared. 1/4 of it is all white, 1/4 of it is black with one multicolored line, the other 1/2 of the screen is fine. It's about 3 years old (S/N MD62830490) and was wall mounted before the problem occurred.
I don't think the problem was caused by watching "Life According to Jim", but that may have something to do with it....
I searched around but didn't find any info on this specific problem. I am willing to fix it myself if someone can point me in the right direction, and if it's a simple board swap or something liek that. Or if someone knows of a reasonable, reliable repair shop in Chicago I'd appreciate that as well. I'm located in the South Loop.
Thanks in advance for any help!
Stanley
scvcs76 is offline
post #2 of 29 Old 08-06-2010, 08:57 AM - Thread Starter
scvcs76's Avatar
Just wanted to add some more info. This is definitely a problem with the set and not the component - I tried all inputs (my PC, DVD, cable) and the situation is the same with all of them.
If anyone has seen this failure before please let me know. I just want to know if I can get it fixed for a reasonable price or if it's time to go TV shopping....
Thanks....
scvcs76 is offline
post #3 of 29 Old 08-11-2010, 09:54 AM
tomwil's Avatar
Liked: 26
When you press the menu button on the remote to get the OSD (On Screen Display), what do you see? Another picture with the OSD would be a big help.
Your answer will help in determining if it is a board problem, or the plasma display itself.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #4 of 29 Old 08-11-2010, 10:10 AM
ElwayLite's Avatar
Originally Posted by rkelecava View Post
This has happened to me. Panasonic is junk!
Must be samsung employee.
ElwayLite is offline
post #5 of 29 Old 08-11-2010, 02:38 PM
darstr's Avatar
Stanley
Looks like you have 1 of two problem. I am sure your panel is ok. You could have a bad c board. That is the board on the bottom of your set. Or possible a bad d board. That is the board with all the flat cables that go to the c boards. First disconnect and reconnect all the flat cables that run to the bottom of the set. If this does not fix your problem, then replace your c board that is in the area of the problem.
darstr is offline
post #6 of 29 Old 08-11-2010, 05:28 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Just to help out a bit, here is the board location information.
Larry
LarryInRI is offline
post #7 of 29 Old 08-11-2010, 05:56 PM
BWDinc's Avatar
I also have the service manual for this tv, so let me know if you need help.
BWDinc is offline
post #8 of 29 Old 08-11-2010, 07:35 PM - Thread Starter
scvcs76's Avatar
Thanks for the help everyone.
First - there is no on screen display when I hit menu - since it is on the left side of the screen and that's the side that isn't working. I forget which other menu I got to somehow, but I could only see the right side of it (the good side of the screen)
Thanks for the tips on the boards as well. Where is the best place to purchase these? I looked on Ebay and found a few C and more D boards, around $30 for C boards and up to $100 for the D board. Does that sound about right? Are there other outlets?
Also, if it's the left side of the screen that is the problem, does that mean it would be C2 as shown in Larry's diagram? I'm assuming the diagram is drawn as if you are looking at the back of the screen.
BWDinc - stay tuned I might have some questions for you once I dig into the set - probably this weekend.
Thanks again.
scvcs76 is offline
post #9 of 29 Old 08-23-2010, 10:00 AM - Thread Starter
scvcs76's Avatar
Quick Update - I replaced both C boards yesterday. The first one (C2 - on the side that had the problem) did not change the on-screen output at all - the problem looked exactly the same. I then replaced the C1 board as well (since I had both on hand) and must have had a bad one because that made the right side of the screen go bad as well.
So I ordered a D board today, I'll be installing that and the putting back the old C1 board this weekend. Hopefully that does it.
Thanks again for the help everyone.
scvcs76 is offline
post #10 of 29 Old 08-25-2010, 09:17 PM - Thread Starter
scvcs76's Avatar
Changed the D-board, didn't fix the problem at all. Any suggestions? LED's are on on both the SC and SS boards.
I'm thinking it must be the panel at this point, based on a quick look through the service manual.
Any further expertise would be appreciated!
scvcs76 is offline
post #11 of 29 Old 08-26-2010, 07:12 AM
tomwil's Avatar
Liked: 26
Changed the D-board, didn't fix the problem at all ... I'm thinking it must be the panel at this point, based on a quick look through the service manual.
Sorry that the replacement boards did not solve the problem. When the whole half of the plasma screen goes dark, it usually is narrowed down to the C-board or D-board which feeds it. Bad plasmas usually show lines or dark blocks.
In looking at Panasonic's Plasma Symptoms, your particular situation does not seem to be displayed.
Obviously someone with more experience needs to help here.
tomwil is offline
post #12 of 29 Old 08-26-2010, 03:28 PM
cyi106's Avatar
Not to hijack the thread, but I recently got the 5 blinks on my TH-42PX60U, which indicates a faulty D Board. I ordered the D Board off ebay and now i'm hoping to get more detail on how to replace it. Is it as easy screwing off the back and unplugging the current one? Any help is appreciated!
cyi106 is offline
post #13 of 29 Old 08-26-2010, 03:58 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Look up ^^^ 5 or 6 posts.
EDIT: I've attached some more detail.
Larry
post #14 of 29 Old 08-26-2010, 05:12 PM
cyi106's Avatar
Larry
You are awesome, that's exactly what i was look for. Thanks!
cyi106 is offline
post #15 of 29 Old 09-02-2010, 12:52 PM
xcel8byu's Avatar
I am having the same problem with mine, just 2 thick black lines on the left side of the screen...replaced the c2 board today and didn't change anything. Did you end up figuring it out, or give up?
xcel8byu is offline
post #16 of 29 Old 09-02-2010, 07:48 PM
tomwil's Avatar
Liked: 26
The following is from a Panasonic technical guide.
tomwil is offline
post #17 of 29 Old 09-18-2010, 03:47 PM
tomwil's Avatar
Liked: 26
I just wanted to mention that a similar problem was resolved by a C board replacement. I wonder if you had received a bad C2 board?
Also, according to this Panasonic document, a plasma display panel fault is not shown to involve the whole half of a screen.
Originally Posted by Mike Lang View Post
C1 is in the right spot, but I don't know if that means anything...
Well the C1 board seems to have done it. I had to do a bunch if dis-assembly just to get to it and wasn't even sure I'd get it all back together. Technically, I didn't since I have a few screws left over from the 60-70 I had to remove.
The tech wanted $500 just to replace the A-Board & that didn't do it. I imagine he would have charged even more to move on to the C1.
Doing it myself, the C1 cost $15 & the A-Board cost about $20 in shipping/restocking fees to rule out.
tomwil is offline
post #18 of 29 Old 01-01-2011, 07:48 PM
miguel_rx7's Avatar
My 3 years old Plasma has a thin line on the screen. The line was in the middle of the screen but it moved to the right after reset display settings. Called Panasonic, the person just gave me the number of a near service center that recommended me not to repair the TV since the problem is the panel. In other words, no support from Panasonic . Does anybody know how I can fix this problem??
miguel_rx7 is offline
post #19 of 29 Old 10-22-2011, 11:16 PM
bosanci28's Avatar
i have the same brand and model and i have
half screen working also
maybe is the C2 board?
thanks for any info!
bosanci28 is offline
post #20 of 29 Old 01-01-2013, 01:50 PM
wireman121's Avatar
Working on a TH-42PX60U. Half of the screen is not functioning with what looks like 2 blocks completely white and the rest of the half of the screen completely black. There is a thin red line down the exact center of the screen. Replaced the C1 board already. Thinking I need the D board, but want some opinions before moving forward with that.
wireman121 is offline
post #21 of 29 Old 02-23-2013, 09:26 AM
medeno's Avatar
Thanks guys,
You helped me fix my problem which was that the entire right side of the display was blank, left side was blurry and had various vertical lines. The fix was resetting all of the connectors around the D board. The ribbon connectors I found to be picky. Cost ZERO. Time 1 1/2 hours. Savings: Unknown. haha, family was impressed.
Medeno
medeno is offline
post #22 of 29 Old 03-27-2013, 05:13 PM
KOOPSA's Avatar
Silly question but does this happen to all Panasonic models ?
I have a TH-37PX60B with the right side of the screen 1/2 black (with a vertical line), 1/2 white
(exactly same as wireman121)
Following the advice on this page I have taken it apart.
Just for those who have not :
  • a powered screwdriver was essential as way too many screws
  • the ribbon cables are clamped by a different coloured plastic clamp.
  • stand support needs removal to remove C1/C2 boards,
I have tried re-seating all the C1 and SD ribbon cables and there was no change to the screen.
Is the best option is to buy a C1 board and give that a try ?
KOOPSA is offline
post #23 of 29 Old 07-21-2013, 03:39 AM
pjfrith's Avatar
Hi All,
Does anyone have a download link for the service manual for one of these.
I'm picking one up later today that I've been given as a non-worker and I'd like to have a crack at getting it up and running.
I've no idea yet what the symptoms are, but expect help requests soon :-)
Thanks everyone in advance.
Pete
pjfrith is offline
post #24 of 29 Old 07-21-2013, 04:30 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
If you need a service manual PM me, I'll get you one. I don't release them publicly here as Panasonic patrol these forums and don't like service manuals being released.
tom669 is offline
post #25 of 29 Old 05-28-2015, 12:35 PM
Liked: 0
Unhappy Panasonic th-42px60u, black and white bar on left
I have a Panasonic th-42px60u,withthe exact same symptom as scvcs76.
When you power up the set,3 vertical lines appear (red, green & blue) slightly left of center screen.Three seconds later, the TV displays a great picture on the right, but no videoon the left side, just a black and white bar. The 3 color vertical lines arestill visible.
There is no On Screen Displayof any kind, even when changing channels or switching inputs with the remote.
I first changed the C1 &C2 boards and the 3 ribbons cables connected to them, it made no difference.
Then I changed the Dboard, made on difference.
Checked all the ribboncables and tapped around for a loose connection, didn't even get a flicker.
The C board often fixes asimilar problem in these sets, but not this exact problem.
Any help would be appreciated.
brdaigle is offline
post #26 of 29 Old 09-21-2015, 08:48 AM
Liked: 0
My Panasonic I was just given by a friend has a clear burn in on the bottom panel. But, the top looks like there's a war going on. I thought he had been playing a war game, paused it and caused some kind of freaking, memory burn. From what I've read above, I'm know worried that the panel itself may be a problem. Any advice is very welcome.
Satch Bigsby is offline
post #27 of 29 Old 09-21-2015, 09:27 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Post pics. Burn in can not be fix, but stubborn image retention can be addressed.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #28 of 29 Old 10-01-2015, 09:48 PM
clickchiq's Avatar
To scvcs76 and brdaigle:
Hey there! Was searching about on the internets to troubleshoot my beloved plasma's (Panasonic TH-37PH9UK) half screen issue and came across this thread. The white and black bars on the left half screen is exactly as pictured/described in your posts. I've seen a tonnnn of illustrations already of other similar screen fault symptoms, but yours is the only one I've found that exactly matched my current screen. Were you able to eventually fix? Or did you sadly finally decide your panel was kaput?
Thanks so much for sharing your experience.
clickchiq is offline
post #29 of 29 Old Today, 05:30 PM
Liked: 0
Hi,
Would it be possible to get the service manual from you? I have the following tv, TH-42PX60U
pby27 is online now
