reversing plasma burn in - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 122 Old 09-26-2012, 09:04 AM
tommyv2's Avatar
It's too bad you have to go through some much work on the Panasonics. Samsung has the decency of making the IR Scrolling infinite, which is very useful. Once a week I'll set the auto power-off to 60 minutes and let the bars run and then it shuts itself off. Simple maintenance! Panasonic should copy that functionality.
=Tommy v2=
tommyv2 is offline
post #122 of 122 Old 09-26-2012, 11:32 AM
andy sullivan's Avatar
Quoted: 754 Post(s)
Liked: 403
Originally Posted by samunoz1 View Post
Ok ... not sure what to do.
To anyone concerned with or experiencing sever IR or Burn-In I suggest you go to the thread here on this Forum titled "Panasonic ST50 Image Retention, Please Help". Go to Post # 132 by Michael2000. He details the four main causes for IR/Burn-In (Phosphorescence, Residual Charge, MGO Sputtering, and Phosphor Aging). For each cause he explains the fix. He ends by saying that "plasma displays use dynamic brightness control, so full white screen or scrolling white bar should not aggressively age your display".
andy sullivan is offline
