$600-$800 Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-24-2010, 02:56 AM - Thread Starter
deathnote's Avatar
My friend saw this TV in person and liked how it looked
Samsung UN40C5000 40-Inch 1080p 60 Hz LED HDTV (http://www.amazon.com/Samsung-UN40C5.../dp/B0036WT48S
But I hear Plasmas are the best these days. Anything around 40-42" at $600-800?
Maybe even $900
deathnote is offline
post #2 of 15 Old 09-24-2010, 02:59 AM - Thread Starter
deathnote's Avatar
sorry, you can lock the thread if need be
http://www.avsforum.com/avs-vb/annou...hp?f=167&a=119
"5) Do Not start a thread asking for the best TV for $XXXX or I have a $XXXXX to spend"
post #3 of 15 Old 09-24-2010, 07:21 AM
AK1997's Avatar
Panasonic TC-P42S2, or if you want something bigger you can get the 720p 50" TC-P50C2 for about the same price. Both are generally under $700. If you can spend a little more you may want to look into get a 50" S2.
No highs, no lows, must be Blose!
AK1997 is offline
post #4 of 15 Old 09-24-2010, 07:42 AM
motogp's Avatar
look into lg or samsung. panasonic low end tv's are nat as good. i own an lg pj350, i paid under 5 bills shipped to my house . best tv i ever owned destroys my sharp lcd, viewing angels, blacks, design 1 1/2 inches thick. under 50lbs, i own the 42inch. I use it for ps3, tv, & as a monitor.
I've had IR, but it goes away every time. the tv has an orbiter that shifts the pic around! so really burn-in is not happening. I left my ps3 on over night many times, & yes I woke up to IR, I thought it would be burn-in but nope. just IR.
IR, has stuck around for about 2hrs. most I have gamed is a 4hrs, I had IR, from god 3, but it went away. it always goes away .
motogp is offline
post #5 of 15 Old 09-24-2010, 07:46 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
The 50" S2 has been on sale within your extended range. I have the S1 and love it. great picture and AR is good on it. The S2 has an even better AR filter.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #6 of 15 Old 09-24-2010, 10:27 AM
Blacklac's Avatar
You can get a 42" Panasonic G25 on Amazon around that price. Probably the best plasma for the money. (in a 42")
Blacklac is offline
post #7 of 15 Old 09-24-2010, 10:40 AM
WTF_LED's Avatar
Check the yellow label box store before Sunday for a 50" Samsung c550 at that price.
WTF_LED is offline
post #8 of 15 Old 09-24-2010, 11:04 AM
Blacklac's Avatar
Same as Amazon also.
Blacklac is offline
post #9 of 15 Old 09-24-2010, 02:00 PM
DCunited's Avatar
I have a 50 768p Panny Plasma, 4years old, Looks good still. but i could get a 55 es500 sony for 856 or 60 ex500 for 1151, what should i do?
DCunited is offline
post #10 of 15 Old 09-24-2010, 02:20 PM
motogp's Avatar
i could get a 40inch sony ex401, for 5 biills. i never heard of it but the price is good. it's refurbished, but it usually cost 1k. im not sure what to do!
motogp is offline
post #11 of 15 Old 09-24-2010, 04:27 PM
bimmerbenz's Avatar
A few days ago I purchased a Panasonic TC-P42S2 42" 1080p Plasma for about 5.5 bills on Amazon. I just checked and it's more now but I had been looking for a few weeks and that was the best deal I found. I was also originally looking for an LED but after some research I settled on plasma. Also, I believe all the Samsung 5000 series panels are made in China and lack the quality of the Samsung made panels.
bimmerbenz is offline
post #12 of 15 Old 09-24-2010, 07:06 PM
Servicetech571's Avatar
The 42"/50" 720p Plasmas are the bang/buck kings right now.
Servicetech571 is offline
post #13 of 15 Old 09-25-2010, 02:14 PM
Plasmachick's Avatar
Panasonic 46 C2 for $500-600.
Plasmachick is offline
post #14 of 15 Old 09-25-2010, 03:39 PM
daniel'son's Avatar
Quoted: 33 Post(s)
.. "He's looking for a '40-42 model' that has them in stock. I get the sense that he doesn't really want 'a 46" model for $500-600'."
daniel'son is offline
post #15 of 15 Old 09-25-2010, 04:04 PM
BWDinc's Avatar
If you look around you may can find the panny 42g25 for a good price. If thats too much and you can handle a 50, the sammy pnc550 is a good tv and getting cheaper.
BWDinc is offline
