Looking for a 50-52 inch Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-06-2010, 10:49 PM - Thread Starter
maGs925's Avatar
Hey all,
I looking to buy a new Plasma TV within the next week or so, and am kind of overwhelmed with choices and am looking for guidance.
My price range for the TV is around $1,500 with a size of around 50-52 inches. The TV is going to be pretty much only for TV and movies.
Thanks for any help you all can provide!
maGs925 is offline
post #2 of 6 Old 10-07-2010, 07:41 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by maGs925 View Post
Hey all,
By TV do you mean HD programming or regular basic cable stuff? And by movies, do you mean regular DVDs or HBO/Showtime HD movies or Blu-Ray? How many feet will there be between your eyeballs and the screen? Will there be a lot of light in the room while watching? Will you be buying online or limited to buying at a local store? Are you looking for great picture quality, or are you not all that picky about PQ?
If you're not looking for the absolute best picture quality, you can get a lower-end Panasonic 50" X24 series from Costco for less than half of your budget. Samsung and LG also have some decent lower end 50" models in the same general price range.
Or, you can get the excellent and highly-rated Panasonic TC-P50G25 from Amazon for under a thousand bucks, or the larger 54" version for a few hundred under your budget (nobody makes a 52" plasma BTW). The G25 is Panasonic's best non-3D model.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 10-07-2010, 09:59 AM
Mikey_C's Avatar
Go with the Panny TC-P50G25 (http://www.amazon.com/Panasonic-VIER.../dp/B003924UCK)
It's their best non-3D screen in my opinion. I have the 54-inch version and I'm still floored by the PQ.
Mikey_C
Mikey_C is offline
post #4 of 6 Old 10-07-2010, 03:03 PM
cosmos5861's Avatar
Does the G25 have the floating black issue and buzzing sound still?
cosmos5861 is offline
post #5 of 6 Old 10-08-2010, 07:48 AM
Mikey_C's Avatar
So far I have not encountered either problem.
Mikey_C
Mikey_C is offline
post #6 of 6 Old 10-08-2010, 02:56 PM
esquire415's Avatar
Watch out for the increasing black levels in the Pannys. They said that they have addressed these problems for the 2010 models and in so doing they opened a new can of worms with the floating blacks. Also, TweakTV just released a report that Panny is still having trouble with the blacks.
Might as well go with the Samsungs since they do not have this problem. In fact, Samsung only lost one major category against Panasonic which is the black but that's not an advantage for Panny anymore with their problems. The buzzing for Sammys may be a concern but those are isolated cases. Here's the shootout:
Samsung won in 9 out of 10 categories:
http://www.3d-tvbuyingguide.com/3dtv...-shootout.html
esquire415 is offline
