PN58C500 - 58" Samsung, new model? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 162 Old 01-23-2012, 02:27 PM
dshetler's Avatar
Quoted: 74 Post(s)
Liked: 37
I bought mine from Best Buy also. I had pink 4" Ribbons mainly at the top on white scene's. I call Samsung and they were very helpful and came out in about a week and replaced my screen. Mine was under warranty by 3 weeks. I have an extented 4 year warranty but it was under the manufactures warranty.
Samsung 65JS9000
Denon AVRX2200W
PS4
Pioneer Elite Atmos SP-EBS73 Bookshelf Speakers
Direct TV
Samsung UBD-K8500
dshetler is offline
post #152 of 162 Old 01-24-2012, 12:11 PM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
I had the same thing.
scoobdude is offline
post #153 of 162 Old 02-08-2012, 08:36 AM
dshetler's Avatar
Quoted: 74 Post(s)
Liked: 37
I had mine for 11 months when I noticed a pink horizonal 4" ribbon toward the top of the screen when the screen was white. I called Samsung and they sent a tech out about 1 1/2 weeks later and replaced the screen. I was very impressed with the service I received from Samsung, because I have heard some bad war stories.
Samsung 65JS9000
Denon AVRX2200W
PS4
Direct TV
Samsung UBD-K8500
dshetler is offline
post #154 of 162 Old 02-27-2012, 02:59 AM
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
when I purchased my new Samsung TV model pn58c500 in 1-5-2011 the free over the air infor guides time was set correctly meaning it provided infor. for a show at 10:00pm that was actualley on at 10:00pm.
Since the new year the infor is now one hour in advance so the 10:00pm infor is now listed at 11:00pm.
is it possiable to reset the infor time? if so how is this done?
I have reset the TV clock back by one hour however the guide is still one hour in advance.
edit: actualley this guide infor time has never been absolutly correct like the 10:00pm example would be a minute off like 9:59pm or 10:01pm
Thanks for any help on the solution for this irrating issuse.
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #155 of 162 Old 02-27-2012, 06:22 AM
Quoted: 108 Post(s)
Liked: 25
update Samsung adviced me to hold the exit button for 10 seconds to restore TV to default settings.
then reset clock
infor guide is still one hour in advance.
in menue clock is set to manuel
post #156 of 162 Old 03-04-2012, 10:26 PM
jmilt13's Avatar
FYI
For those that might encounter this. I had this problem and a very astute technician came out and just adjusted the power supply regulator, or something to that degree. It was outputting slightly under spec. There were no problems with the screen. 15 min fix.
jmilt13 is offline
post #157 of 162 Old 03-06-2012, 02:38 AM
Quoted: 108 Post(s)
Liked: 25
I'm curious if you where feeding the TV the correct amount of AC power from the wall socket?
maybe a power conditioner would prevent this 4" pink ribbon from happening?
STB
post #158 of 162 Old 06-08-2012, 02:25 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Nope. I have had a UPS on mine the whole time and I have had my screen replaced twice for the same pink ribbons/ line bleed.
post #159 of 162 Old 09-20-2012, 05:51 PM
mike208's Avatar
Quoted: 23 Post(s)
Mine got the pink ribbon issue recently. I had the 4 year best buy black tie protection plan. They came out replaced a board, no fix. Came out again replaced that same board(Y sustain I believe) and a logic board, no fix. They also checked the voltages and they were all within spec. They said they could replace the screen, but decided just to give me a replacement. They offered me an LG 60PA6500 60" plasma currently on sale for $999. It seems to get good reviews on best buy and amazon. But I am starting to wonder if an LED wouldn't be a better option for us.
The TV is wallmounted in our apartment living room, which also has a east/north east facing sliding glass door. It also has a north facing window, but we honestly haven't noticed any glare problems with the samsung. But all that light does make it a bit bright in here during the day. We are no videophiles, but I know plasmas for now are the better picture quality displays. It just seems to me like these LED screens seem so bright and vibrant and my plasma has always seemed a bit dull.
Just not sure which is more important, the bright vivid color of LED or the picture/contrast/blacks of the plasma's.
Best buy said we can upgrade to a better display if we pay the difference, so if I go plasma I might go for the 55 inch Panasonic ST50's. Unfortunately best buy doesn't sell the 60 inch version. But from what i have read this seems to be one of the better plasma displays on the market and has the AR filter. Not sure which LED we would go for if we choose to go that route. Any suggestions?
mike208 is offline
post #160 of 162 Old 10-05-2012, 02:59 PM
dshetler's Avatar
Quoted: 74 Post(s)
Liked: 37
IF YOU GO LED, GO WITH 240 HTZ IF YOU WATCH SPORTS YOU WON'T GET SHADOWS IN FAST MOVING GAMES.
Samsung 65JS9000
Denon AVRX2200W
PS4
Direct TV
Samsung UBD-K8500
dshetler is offline
post #161 of 162 Old 10-05-2012, 03:27 PM
Quoted: 108 Post(s)
Liked: 25
I'm curious if these folks w/ the screens failing did they break the TV in?
post #162 of 162 Old 11-22-2012, 04:38 AM
Quoted: 108 Post(s)
Liked: 25
STB
T he good news is somehow this issuse w/ the TV guide infor resloved itself. bad news is after the recent daylight saving time the TV guide infor is again 1 hour in advance.
anyone here figure this issuse out yet?
Originally Posted by spimm View Post
I have just found this thread after 2 years of owning this tv eek.gif If anyone still views this thread I have one question... I changed the model to c590 in the service menu, can I update the firmware that was released for the 550 and 590 on my C500 or will I screw the tv up all together because you cannot turn back after a firmware update? Will it work or is it just not worth it? Will there be a difference in 24p playback?
are you having problems w/ the TV?
I understand you rationale about changing the model # for increased adjustment on the color. however me personalley would never take a unrevertable chance unless I had documents like a service manuel that the service people have acces to. .
STB
