James Cameron's Preferred Settings for VT25 - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 166 Old 03-12-2011, 03:26 PM
thegreatagent's Avatar
Originally Posted by ambercat View Post
The only SM adjustments on my TC-P50VT25 were done by BB Geek Squad back in June for W/B. I did not like BB user settings and have since been using D-Nice's user settings since he posted them for 2D THX, Custom and 3D Custom. Since upgrading to 3.5 firmware 20 December I still use his 2D settings but now use the James Cameron's user settings for 3D Custom. I have tried all the user settings in the spreadsheet, BB's and TweekTV's but the best since installing 3.5 are D-Nice's for 2D and James Cameron's for 3D.
I just got my VT25 and updated to 3.5 right away. I then applied D-Nice's SM Offsets and Picture Settings, against his recommendations.
Are you using D-Nice's SM Offsets or just his Picture Settings? Should I put my SM Offsets back to the factory defaults?
Thanks for your input!
thegreatagent is offline
post #152 of 166 Old 03-14-2011, 07:51 AM
ambercat's Avatar
SM was only done by Best Buy. I have not touched the SM.
ambercat is offline
post #153 of 166 Old 03-16-2011, 03:29 PM
jeffwine03's Avatar
Curious,
I just installed 3.5 on the vt25. It lists current firmware as 3.5. Yet, I'm not seeing any new menu options in 3d mode whatsoever. Avatar is in, the television is operating in 3d mode, but nothing has changed in menu options to "unlock" pro menu options under cinema mode. Perhaps I was confused regarding the actual benefits of 3.5? I thought it "dramatically improved" the initial 3d calibrated settings as well as gave acess to the pro menu in cinema mode. I still think 3d looks better with the pro modifications I made in custom mode in firmware version 3.0, which all still remain.. Hmm. Help?
jeffwine03 is offline
post #154 of 166 Old 03-16-2011, 03:51 PM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Originally Posted by jeffwine03 View Post
Curious,
3.5 doesn't change anything in the menus, it changes the back end (behind the service menu settings). So any calibration you did in 3.0 for 3D needs to be updated.
rdgrimes is online now
post #155 of 166 Old 03-16-2011, 06:14 PM
Curious,
To use James Cameron's 3D settings, you have to use the Custom picture setting, not Cinema. Be sure to have 3D content playing so you make the adjustments in the right place.
Contrast: +90
Brightness: +58
Color: +39
Tint: 0
Sharpness: +20
Color Temperature: Warm2
Color Management: Off
x.v. Color: Off
CATS: Off
Video NR: Off
Blur Reduction: Off
Pro Settings (3D)
W/B High R: +10
W/B High B: -5
W/B Low R: +2
W/B Low B: +1
All Hues and Saturation: 0
Black Extension: 0
Gamma: 2.2
Panel Brightness: Medium
Contour Emphasis: Off
AGC: 0
These settings really do improve the Avatar 3D experience. I am also using D-Nice's SM Adjustments. I tried switching back to the default SM Offsets but it didn't look as good, so anyone wondering about that can feel free to try it out and see what looks better.
*modifications to James Cameron's settings include Color, Gamma, and Panel Brightness
post #156 of 166 Old 03-16-2011, 09:27 PM
jeffwine03's Avatar
ahh, I see. service menu. thanks guys.
post #157 of 166 Old 03-17-2011, 06:20 PM
Calilotech's Avatar
Originally Posted by MovieStreet View Post
Hello All,
After much debate I decided to download the firmware update except it refused to install. After 6 trys on 3 different SD cards I called Panasonic yesterday. The code 0013 comes up and the techs at Pana had no idea their was even a firmware release of 3.5. They did however have several calls from other set owners with the same problem that I have. They have promised to get back to me. So for the moment it's a dead issue for me. Since I cannot do anything with Cameron's settings even if I want to. I will keep everyone updated as to a forthcoming resolution and what it does if I ever get it to install.
It's giving me the same message saying check code 0013 on SD card on my Pany TC-P50GT25. I formatted the sd card using FAT32 and is the only data on the card. Is there something I'm not doing?
Calilotech is offline
post #158 of 166 Old 04-08-2011, 10:12 PM
Robert311's Avatar
Contrast: +90
Brightness: +58
Color: +32
Tint: 0
Sharpness: +20
x.v. Color: Off
CATS: Off
Video NR: Off
Blur Reduction: Off
Pro Settings (3D)
W/B High R: +10
W/B High B: -5
W/B Low R: +2
W/B Low B: +1
Black Extension: 0
Gamma: 2.4
Panel Brightness: High
AGC: 0
Hey guys... I tried searching the forum regarding James Cameron's Avatar 3D settings for the 2011 Panasonic's, but I didn't find anything.
I have a TC-P50ST30 and was wondering if I could just use these settings that were made for the VT20/25. Will it work and look good or are these settings not made for a 2011 Panny?
Any help would be appreciated.
LOST is the best tv show ever.
Go Dodgers!
Go Lakers!
Robert311 is offline
post #159 of 166 Old 04-08-2011, 11:14 PM
kevin_mahaney's Avatar
Liked: 26
The short answer is, "probably not."
kevin_mahaney is offline
post #160 of 166 Old 04-09-2011, 12:17 AM
yeah, different TV... different settings... don't even think about using these settings as they also require a VT25 firmware update that changes the foundation of the Service Menu.
btw, I have found it necessary to make adjustments to the quoted James Cameron settings... see the changes in my previous post.
post #161 of 166 Old 04-09-2011, 01:37 AM
Robert311's Avatar
Ok thanks guys.
Do you think there will ever be a "recommended settings" for the 2011 ST/GT/VT's for Avatar 3D?
If not, I'll just use my own settings.
Go Dodgers!
Go Lakers!
post #162 of 166 Old 04-09-2011, 08:14 AM
Liked: 26
Ok thanks guys.
Doubt it. It was a gimmicky thing anyway when the Panasonic-exclusive release came out. I would guess that D-Nice (if you're not familiar, he's a calibrator who typically calibrates each year's Panasonics and posts reference settings on AVS) will probably do the 2011 sets, though. I haven't even looked to see if he's started a thread yet, but last year's was here: http://www.avsforum.com/avs-vb/showthread.php?t=1232441.
post #163 of 166 Old 05-07-2011, 09:15 PM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Ok thanks guys.
Or you could get your set properly calibrated by a professinal....and not have to guess.
Later
RayJr
Rayjr is offline
post #164 of 166 Old 07-02-2011, 09:39 PM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
What is the point of the 3.5 firmware ?
After applying the firmware, reading the Instructions that came along with the firmware... I still had to manually change 10 different settings...
aka set gamma to 2.4, drop contrast to 90 from 100, drop sharpness, drop brightness, turn noise reduction to off from weak, etc.
Shouldn't the firmware change those settings for custom automatically ?
This was a pristine/new TV.
defdog99 is offline
post #165 of 166 Old 08-18-2011, 03:00 PM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1773
For my buddy CC.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #166 of 166 Old 08-19-2011, 01:03 AM
cc781's Avatar
Thanks chunon. Downloaded the update. Just gotta get my hands on a copy of 3d Avatar
cc781 is offline
