Panasonic GT25 - No 3D Popout effects? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-25-2010, 06:12 PM - Thread Starter
sparkstsa's Avatar
Ok, so I have bought just about every 3D Blu-ray movie currently out now and they all have great 3D depth.... i'm just not seeing the out of screen effect. Am I doing something wrong?
sparkstsa is offline
post #2 of 8 Old 12-25-2010, 07:56 PM
Paul33993's Avatar
Have you played Avatar? I was watching a 5 minute clip at Best Buy (GT shouldn't be different) and there was a ton of stuff floating outside the screen during that segment.
Paul33993 is offline
post #3 of 8 Old 12-25-2010, 08:17 PM - Thread Starter
sparkstsa's Avatar
I have Avatar and did not notice anything coming out from the screen just depth.
post #4 of 8 Old 10-16-2012, 03:13 PM
thepiecesfit's Avatar
Sadly on my new ST50 I am seeing the same thing. My old Bravia popped out I could almost grab the purple vines they were like 5 inches from my face. Hoping its a setting, calibration or firmware update that can help here.
thepiecesfit is offline
post #5 of 8 Old 10-16-2012, 03:17 PM
sbsidlov's Avatar
I don't know, pops out on my set, on Avatar and Hugo the snowflakes are outside the screen.
sbsidlov is offline
post #6 of 8 Old 10-16-2012, 03:25 PM
How far are you from your screen? I have the 50" and I am about 7 1/2 feet from the screen.
post #7 of 8 Old 12-05-2012, 07:48 PM
sbsidlov's Avatar
Isn't the pop out level effects in the bluray player? My panasonic 210 has it when the movie plays using the Display button under the Play subsection.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
sbsidlov is offline
post #8 of 8 Old 12-05-2012, 09:12 PM
Mastperf's Avatar
On my st30 there is an option to increase the 3d depth. I'm not sure if it's the same for your gt25.
Mastperf is offline
