TH-42pz77u 1-2 inch vertical black bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-26-2010, 04:11 PM - Thread Starter
cdeenen's Avatar
About a month ago, my 1.5 year old panasonic TH-42pz77u plasma (my bedroom set) "lost" about a 1 foot, 2 inch wide vertical strip on the right bottom of the TV. There's a permanent "black bar" on it now, regardless if I display from DVD or Cable.
I read one other post on this forum that had this happen from about a year ago.
Has anybody else had this happen? and if so, was it an easy fix, or an expensive fix ?
thanks already for any advice/ideas.
cdeenen is offline
post #2 of 3 Old 12-26-2010, 04:26 PM
Servicetech571's Avatar
Sounds like one of the C boards failed.
Servicetech571 is offline
post #3 of 3 Old 12-26-2010, 04:32 PM - Thread Starter
cdeenen's Avatar
Hi, many thanks for the quick reply !! Do you know by any chance if replacement of a "C board" is pricey or relatively "cheap" ? i.e. few hundreds bucks or less
cdeenen is offline
