Samsung 2011 Plasma Lineup - Page 116 - AVS Forum | Home Theater Discussions And Reviews
post #3451 of 3464 Old 07-27-2011, 05:38 AM
Hudson1's Avatar
Originally Posted by obveron View Post
Ok. but that firmware work is already accomplished for the PAL TVs is it not?
Why not just give the whole world the "PAL" TVs? Really I should call them "play everything" TVs or something.
The only physical characteristic that is necessary to be different is the AC voltage input and related power supply.
I think you have two options:
1) Write to Panasonic, Sony, Samsung, LG, etc. and let them know they need to find a way to enable judder-free playback of 1080/50 content on NTSC TVs. Be sure to remind them they already have the firmware and it has to be a free exercise.
2) Buy your PAL TV, bring it to N. America, plug it in and let it do it's thing. After all, they are the "do everything" TVs that you speak of so I doubt you'll encounter any problems.
Hudson1 is offline
post #3452 of 3464 Old 07-27-2011, 10:16 AM
obveron's Avatar
Quoted: 30 Post(s)
Liked: 32
Cheers. Thanks for lively discussion.
obveron is offline
post #3453 of 3464 Old 07-28-2011, 03:15 PM
laterally's Avatar
I did a little research after asking my question. The "multi system" TVs I mentioned should do the trick. Samsung sells them in N. America with model numbers starting with PS (plasma), LA (LCD), or UA (LED). These TVs are supposed to be able to display 50 hz content without having to convert it.
laterally is offline
post #3454 of 3464 Old 07-28-2011, 05:27 PM
specuvestor's Avatar
What I explained in another thread, it's all about market and cost:
Originally Posted by specuvestor View Post
Hollywood is on 60Hz pull down ie NTSC or 24fps. This is the biggest movie market so you have to cater to it (though Bollywood is the biggest in terms of volume ) even if you are PAL based. Even in HD standard you only see 24p and not 25p (though BBC seemed to be trying to do 25p)
Same logic why China can have a proprietory nowhere-else 3G standard ie TDSCDMA because they are the largest mobile market. Or why manufacturers are afraid of ITC because a ban will halt their access to the largest market. Bigger speaks louder
specuvestor is offline
post #3455 of 3464 Old 07-29-2011, 12:16 AM
3reach's Avatar
IS the fluctuating very noticeable?
3reach is offline
post #3456 of 3464 Old 08-02-2011, 05:40 AM
fermau's Avatar
So since my niece threw a wiimote on my 63c7000 3d plasma, and since reparation is damn HUGE, i prefet to buy a new set.Now, since i'm pissed off and so damn upset about my 63c7000 BUZZZZZZZ , and i can't live longer with it, the doubt is if to go on less-inch like a 55" 3d led tv, or if i can go with the 64D8000 plasma. Can you just tell me a final word on the 64d8000 buzz ?is it affected or not ?i like if someone can tell me...there's no buzz at all.A...there is a very little buzz will be already too much for my sensible ears
thanks.
fermau is offline
post #3457 of 3464 Old 08-02-2011, 07:34 AM
Ph8te's Avatar
Quoted: 4749 Post(s)
Liked: 4297
thanks.
Even for my basic research almost all plasmas have a buzz of one type or another. You may have.to put your ear up to the TV but they all buzz. If any buzz at all is unacceptable then you.may want to.go with and LCD/LED TV, but then there are other issues you need to look for.
Ph8te is online now
post #3458 of 3464 Old 08-02-2011, 07:58 AM
fermau's Avatar
if i need to put the ear on the display to hear it its ok...
my 63c7000 got a very noticeable buzz even from 2.5 meters..i mean...VERY DAMN LOUD !....
fermau is offline
post #3459 of 3464 Old 08-11-2011, 10:47 AM - Thread Starter
koffas's Avatar
Added PC Mag's review of the PN51D8000 to OP. They give it the Editors Choice award, though they calculate CR in a non-realistic way (yes, it's not the most renowned TV review publication).
US Models
PC Mag - PN51D8000
CNET - Panasonic TC-PVT30 vs. Samsung PND7000/8000: Which is the best TV of 2011 (so far)?
CNET - PN59D7000
CNET - PN59D8000
TelevisionInfo.com - PN51D6500
TelevisionInfo.com - PN59D8000
Chad B - PN51D8000/PN64D8000
European Models
HDTVTest - PS51D8000 (UK)
FlatpanelsHD - PS51D8000 (Denmark)
koffas is offline
post #3460 of 3464 Old 08-11-2011, 11:01 AM
pioneer 1985's Avatar
it seems that the pc mag review site prefers led/lcd tvs rather than plasma. intresting as most other review sites normally would always pic plasma over led for overall picture quality.
pioneer 1985 is offline
post #3461 of 3464 Old 08-11-2011, 12:38 PM
Tallen234's Avatar
Guys,
I am very close to pulling the trigger on this set. I just need confirmation that "fullfilled by Amazon" truly means that you can take advantage of the Amazon return policy. From what I've read, this is correct, but I wanted to double check with you guys.
Tallen234 is offline
post #3462 of 3464 Old 08-12-2011, 01:16 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Originally Posted by Tallen234 View Post
Guys,
Best to call Amazon and ask because I have read numerous times it is a different return policy
Larry M is offline
post #3463 of 3464 Old 08-12-2011, 06:04 AM
Homebrew101's Avatar
Quoted: 53 Post(s)
Liked: 63
Guys,
you should be fine, fulfilled by Amazon does come with the same return policy as sold by Amazon
I called them about that before buying my samsung from them in July
Homebrew101 is offline
post #3464 of 3464 Old 01-18-2012, 12:19 AM
V_Pl_a's Avatar
Liked: 25
Beginning April 24, Samsung will provide two pairs of 3D active glasses for its entire 3D TV lineup at no additional cost with the purchase of any Samsung 3D LED TV or 3D Plasma TV.
Is this true still? If I buy one SAMSUNG plasma TV today, I get free 3D glasses?
V_Pl_a is offline
