elevation limit for new Panasonic plasma HDTV - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2011, 05:12 PM - Thread Starter
Katzen's Avatar
For the past couple of months I've been researching the replacement for my 36" Toshiba CRT, and had narrowed my interest down, but a nagging question lingered: altitude limitations for plasma HDTV's from Panasonic. A search here brought up the thread from 2007, but I thought to post the question to Panasonic. Here's their reply:
Thank you for contacting Panasonic e-mail. We can assist with your inquiry. The maximum elevation for the TCP50V10 is 8500 ft. The pressure may be too high at your current elevation for the TV to work properly. Thank you for contacting Panasonic.
As my front door is considerably higher than that ( +900ft), it looks like I'll be focusing solely on LCD displays. Yes, I have the same inquiry out to Samsung also, but no reply yet (though I'd be astonished if theirs was certified to 9,500ft).
Mediocrity is so common, so forgiven.
Katzen is offline
Old 01-12-2011, 05:38 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
In another forum they said the v10 was rated by panasonic to 9100ft.
May have to mount some fans as it will run hotter up there.
whipit is offline
Old 01-12-2011, 05:41 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Panasonic Plasma panels are rated for 9,100 feet according to Panasonic documents, and have been for a few years now.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 01-13-2011, 10:14 AM - Thread Starter
Katzen's Avatar
Many thanks for the replies, though I am a little confused when their customer support email answer sets a lower elevation limit than you assert.
Randy, are the documents to which you refer available for download from Panasonic?
Katzen is offline
Old 01-13-2011, 02:06 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
One link that i saved was a PDF of a 2008 Pro model brochure. I remember an earlier document where they raised the altitude rating from whatever it was previously to the current 9,100 rating. The Pro models use the same plasma panel as the consumer models so the altitude rating would carry over to all models of the same size range.
ftp://ftp.panasonic.com/pub/Panasoni...og_2008-10.pdf
OPERATING ENVIRONMENT
Temperature 32°F 104°F (0°C 40°C)
Humidity 20% 80% (Non condensation)
Altitude 0 9,100 feet (0 2,800 m)
Randy
Old 01-13-2011, 05:32 PM
theanimala's Avatar
9500ft? Where do you live?
theanimala is offline
Old 01-13-2011, 06:00 PM - Thread Starter
Katzen's Avatar
Not too far from the Continental Divide.
Lots of really fresh air, loads of wildlife (including apex predators); a bit more than a rock's throw from the tree line. ( UV Index is probably about the same as the Australian outback - flatlanders typically turn medium-rare in half an hour in the summer in their shorts, etc.)
No paved roads for miles, no street signs to speak of, not a popular area for tourists either (no ski slopes/resorts).
Paradise!
Katzen is offline
Old 01-13-2011, 06:09 PM - Thread Starter
Katzen's Avatar
Thank you for contacting Samsung Electronics.
We understand you want to know the altitude of the plasma TV. You want to know the panel life for the TV.
Plasma TVs do not operate properly above 6500 feet (approximately 1950 meters) and in most cases will
buzz loudly at or above that altitude. Consequently, Samsung does not sell a Plasma TV designed to be used
above 6500 feet. The life span for the TV is 60,000 viewing hours.
If you require any further information, feel free to contact us.
Thank you,
Samsung Online Support.
Okay, that definitively takes any Samsung plasma out of the decision-making remaining!
Katzen is offline
Old 01-13-2011, 08:13 PM
3Dhereicome's Avatar
Paradise!
hahahaha! +1 :-D
3Dhereicome is offline
